Kết quả 1 tới 10 của 12
    Thành viên chính thức quanlon's Avatar
    Mặc định 2700 cần giúp
    Tình hình la em mới thay con fash 2700 chạy lại log rất đẹp không lỗi lầm nhưng bật nguồn lên nokia bấm vào menu là contac mất nguồn luôn. imel vẫn đẹp em chạy bằng atf bác nào có ý kiến gì không xin giúp em với.thanks mọi người
    ATF Software Version v9.80
    ATF Nitro FBUS Flash Started...
    Number of Image Files: 3
    Processing Image File :
    C:\Program Files\Nokia\Phoenix\Products\RM-561\rm561__09.98.mcusw
    CMT Type : BB5
    CMT Algorithm : BB5 ALGORITHM
    Secondary Sending Speed : 3250000 Hz
    Algorithm Sending Speed : 6500000 Hz
    Program Sending Speed : 6500000 Hz
    Message Reading Speed : 98000 Hz
    Number of Blocks : 1256
    Entry Point : 0x5047
    Page Format : 128K
    Maximum Page Size : 0x00004000
    Changing MODE : FLASH
    Booting Phone via FBUS...
    AdvanceBox SendBootCodeEx
    InitialiseBootstrap_DCT5 DIR
    BootFlashMode_DCT5
    TIME STARTS HERE
    Number of Sub Blocks 7 (0x07)
    1 SYSTEM_ASIC_ID 01
    Block Length : 21 (15)
    BB ASIC Index : 0 (00) CMT
    ID DWORD 0 : 00000001
    ID DWORD 1 : 00000226
    ID DWORD 2 : 00010006
    ID DWORD 3 : 030C1921
    ID DWORD 4 : 01033000
    2 EM_ASIC_ID 02
    Block Length : 5 (05)
    ID DWORD 0 : 00000296
    3 EM_ASIC_ID 02
    ID DWORD 0 : 00000B22
    4 PUBLIC_ID 12
    ID DWORD 0 : 24800106
    ID DWORD 1 : 648F0F56
    ID DWORD 2 : A84C1966
    ID DWORD 3 : 453DDFA5
    ID DWORD 4 : 5AD15014
    5 ASIC_MODE_ID 13
    Block Length : 2 (02)
    Mode Id : 00
    6 ROOT_KEY_HASH 14
    Block Length : 17 (11)
    Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23
    7 ROM_ID 15
    Block Length : 9 (09)
    CRC 0 : 273F6D55
    CRC 1 : DFAAF68F
    Checksum 9A
    SearchForBootstrap_DCT5..
    C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg
    Boot File - Version 010.042.00
    Boot File - Revision 0x0000 (0)
    eBB5ProtocolType == Original
    Secondary Loader Sent...
    MessageID : 03
    SubBlocks : 03
    Block Length : 0B
    BB ASIC Index : CMT 00
    Device Type : NOR 00
    Device Index : 00
    Manufacturer Code : 0001 ->
    Device ID : 003F -> Type not in database
    Extended/Fixed ID : 0000
    Revision ID : 8A21
    2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5
    Block Length : 13
    Device Index : 00
    Device Contents : 00000000000000000000
    Block Length : 0B
    Device Type : MMC 04
    Device Index : 00
    Revision ID : 0000
    Checksum : B5
    FLS1SendAlgoCodeEx..
    SendAlgoCode_DCT5..
    SearchForAlgorithm_DCT5..
    Looking for ALL Devices...
    Searching Algorithm Files NOR (00) ManID :0001 DevID :003F ExtID :0000 RevID :8A21
    Flash Descriptor
    Device ID : 003F
    Revision ID : 0000
    Size : 04000000 (64 MB)
    VPP Info : 0009
    Erase10s : 28
    Block1s : 32
    BErase1s : 02
    Reserved0 : 00
    Reserved1 : 00
    Reserved2 : 00
    VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK
    C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg
    Algorithm File - Version 010.040.00
    Algorithm File - Revision 0x0000 (0)
    SearchForAlgorithm_DCT5 : No Error - 0 (0x00)
    TransmissionTypeRequest_DCT5...
    SuggestedType : 01 16BIT
    TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC
    ReturnedType : 01 16BIT
    TransmissionTypeRequest_DCT5 : No Error - 0 (0x00)
    Uploading ALGO File...
    PAPUB_KEYS_HASH_REQ_BB5
    PHONE_INFO_RESPONSE_BB5
    PAPUB_KEYS_HASH_RESP_BB5 2A
    BB Asic Index : 00
    CMT PAPUBKEYS HASH:
    3EA22A1DDA660002E56108DB5072A10F8709443F
    Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
    Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
    Certificate 1
    ASIC Index : CMT 0
    Certificate 2
    ASIC Index : CMT 0
    Certificate 3
    ASIC Index : CMT 0
    Certificate 4
    ASIC Index : CMT 0
    Certificate 5
    ASIC Index : CMT 0
    STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 56 41 52 49 41 4E 54 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 85
    STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
    VPP Enabled by Software
    Using Internal VPP
    StartErase_DCT5...
    BlockLength : 0x36 (54)
    ERASE Blocks : 0x01 (1)
    0 ERASE_AREA_BB5 0x12
    Block Length : 0x33 (51)
    BB ASIC Index : 0x00 CMT
    Device Type : 0x00 NOR
    Device Index : 0x00
    0 : 00000000-000006BF
    1 : 000006C0-0001FFFF
    2 : 00040000-000BFFFF
    3 : 000C0000-0013FFFF
    4 : 00140000-0137FFFF
    5 : 01380000-0151FFFF
    Erase_SendEraseBlock_BB5_NOR
    Task in Progress... Please Wait...
    STATUS_REQUEST_BB5...
    1 Sub Block ID : 14 STATUS_NOR_OK_BB5
    Block Length : 01
    BB ASIC Index : 00
    Successfully erased..
    Time Taken to Erase : 00:01:12
    TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9
    ReturnedType : 04 DDR & 2TX
    Flashing Speed: 5.00 Mhz
    Processing : rm561__09.98.mcusw
    Total blocks to write : 1256
    FBUS Cable RX2 PIN Diagnostics
    Block Length : 01
    BB ASIC Index : 00
    INFO: RX2 PIN is OK
    >> CMT Rootkey Hash CERT : NOLO
    >> CMT Rootkey Hash CERT : KEYS
    >> CMT Rootkey Hash CERT : PRIMAPP
    >> CMT Rootkey Hash CERT : PASUBTOC
    >> CMT Rootkey Hash CERT : PAPUBKEYS [3EA22A1DDA660002E56108DB5072A10F8709443F]
    >> CMT Rootkey Hash CERT : UPDAPP
    >> CMT Rootkey Hash CERT : DSP0
    >> CMT Rootkey Hash CERT : MCUSW
    ContinueFlash_DCT5 Complete
    Block Length : 01
    BB ASIC Index : 00
    FlashInfo.RestartMode : 1
    Continue Flash Complete : : No Error - 0 (0x00)
    Time Taken to Flash : 00:01:22
    Making delay between files for 5000ms
    C:\Program Files\Nokia\Phoenix\Products\RM-561\rm561__09.98.ppm_v
    CMT Type : BB5
    Number of Blocks : 442
    Entry Point : 0x00B6
    Page Format : 128K
    BootFlashMode_DCT5
    TIME STARTS HERE
    1 SYSTEM_ASIC_ID 01
    2 EM_ASIC_ID 02
    3 EM_ASIC_ID 02
    4 PUBLIC_ID 12
    5 ASIC_MODE_ID 13
    Mode Id : 00
    6 ROOT_KEY_HASH 14
    7 ROM_ID 15
    CRC 0 : 273F6D55
    CRC 1 : DFAAF68F
    Checksum 9A
    MessageID : 03
    SubBlocks : 03
    Block Length : 0B
    Device Index : 00
    Revision ID : 8A21
    Block Length : 13
    Device Index : 00
    Block Length : 0B
    Device Index : 00
    Revision ID : 0000
    Checksum : B5
    SendAlgoCode_DCT5..
    Flash Descriptor
    Device ID : 003F
    Revision ID : 0000
    VPP Info : 0009
    Erase10s : 28
    Block1s : 32
    BErase1s : 02
    Reserved0 : 00
    Reserved1 : 00
    Reserved2 : 00
    BB Asic Index : 00
    CMT PAPUBKEYS HASH:
    No RESTORE CERTIFICATE FOUND IN IMAGE FILE
    Using Internal VPP
    StartErase_DCT5...
    BlockLength : 0x0E (14)
    Block Length : 0x0B (11)
    Device Index : 0x00
    0 : 01520000-01DBFFFF
    Block Length : 01
    BB ASIC Index : 00
    Time Taken to Erase : 00:00:30
    Processing : rm561__09.98.ppm_v
    Total blocks to write : 442
    Block Length : 01
    BB ASIC Index : 00
    FlashInfo.RestartMode : 2
    Time Taken to Flash : 00:00:36
    C:\Program Files\Nokia\Phoenix\Products\RM-561\rm561__09.98.image_v_blac
    CMT Type : BB5
    Number of Blocks : 872
    Entry Point : 0x00C8
    Page Format : 128K
    BootFlashMode_DCT5
    TIME STARTS HERE
    1 SYSTEM_ASIC_ID 01
    2 EM_ASIC_ID 02
    3 EM_ASIC_ID 02
    4 PUBLIC_ID 12
    5 ASIC_MODE_ID 13
    Mode Id : 00
    6 ROOT_KEY_HASH 14
    7 ROM_ID 15
    CRC 0 : 273F6D55
    CRC 1 : DFAAF68F
    Checksum 9A
    MessageID : 03
    SubBlocks : 03
    Block Length : 0B
    Device Index : 00
    Revision ID : 8A21
    Block Length : 13
    Device Index : 00
    Block Length : 0B
    Device Index : 00
    Revision ID : 0000
    Checksum : B5
    SendAlgoCode_DCT5..
    Flash Descriptor
    Device ID : 003F
    Revision ID : 0000
    VPP Info : 0009
    Erase10s : 28
    Block1s : 32
    BErase1s : 02
    Reserved0 : 00
    Reserved1 : 00
    Reserved2 : 00
    BB Asic Index : 00
    CMT PAPUBKEYS HASH:
    Using Internal VPP
    StartErase_DCT5...
    BlockLength : 0x16 (22)
    Block Length : 0x13 (19)
    Device Index : 0x00
    0 : 01DC0000-0215FFFF
    1 : 02160000-03FBFFFF
    Block Length : 01
    BB ASIC Index : 00
    Time Taken to Erase : 00:02:03
    Processing : rm561__09.98.image_v_blac
    Total blocks to write : 872
    Block Length : 01
    BB ASIC Index : 00
    Time Taken to Flash : 00:01:03
    Total Flash Write Time (Flashing Only) : 00:03:02
    Total Flashing Time (Booting + Erase + Flashing) : 00:06:51
    Waiting for Phone to Go Online...
    Elapsed Time: 1s
    Elapsed Time: 2s
    Elapsed Time: 3s
    Elapsed Time: 4s
    Elapsed Time: 5s
    Elapsed Time: 6s
    Elapsed Time: 7s
    Elapsed Time: 8s
    Elapsed Time: 9s
    Elapsed Time: 10s
    Basic Phone Information
    MCU Version: V 09.98 06-09-10 RM-561 (c) Nokia
    IMEI Plain : 358256042104998
    IMEI Spare : A358256042104990
    IMEI SV : 33582560421049955F
    Phone Model: Nokia 2700 classic
    Category : Classic Phone
    Phone Type : RM-561
    Extended Phone Information
    Product Serial Number: 0
    Product Code : 0579808
    Long Production SN : 0
    PPM SW Version : V 09.98 06-09-10 RM-561 (c) Nokia V
    BT MCM Version : 2222-302
    MCU SW Version : V 09.98 06-09-10 RM-561 (c) Nokia
    RFIC Version : 06560601
    DSP Version : ICPR72_09w26
    LCD Version : SHARP
    Content Pack Version : Content: v_black V 09.98 06-09-10 RM-561 (c) Nokia
    AHNE Version : 30
    RETU Version : 16
    TAHVO Version : 22
    Bluetooth ID : 48C:FB:5B:52:34
    CS Type : GSM850, GSM900, GSM1800, GSM1900
    Simlock Information
    Unable to read SP Data..
    Elapsed Time: 1s
    Elapsed Time: 2s
    Elapsed Time: 3s
    Elapsed Time: 4s
    Elapsed Time: 5s
    Elapsed Time: 6s
    Elapsed Time: 7s
    Elapsed Time: 8s
    Elapsed Time: 9s
    Elapsed Time: 10s
    Phone Type : RM-561
    LCD Version : SHARP
    AHNE Version : 30
    RETU Version : 16
    TAHVO Version : 22
    Simlock Information
    SECURITY_TEST : PASSED
    SECURITY_CODE : 12345
    PHONE_MODE : TEST
    Dynamic Camera Configuration
    DCC ID : NIMMIIIIRRFF094B2F01
    DCC Ver: 002009
    Status : OK
    FACTORY SET TO : Full Factory Set
    OK
    FACTORY SET TO : User Data
    OK
    FACTORY SET TO : Leave Factory
    OK
    FACTORY SET TO : Service Center
    OK
    FACTORY SET TO : Software Upgrade
    OK
    FACTORY SET TO : Production Tune
    OK
    RESET LIFE TIMER TO : 0000:00
    OK
    May 2012
    đưa cái log lên cho dễ người anh em. nói vậy sao mà đoán bệnh cho bác được
    Trích Được post bởi LÊ_TRUNG Xem bài viết
    log đây bác
    uppppppppppppppppppppppppppppppppppppppppppppppppp ppppppppppp
    Xem lại nội qui nha bạn .Không được up bài theo kiểu kí tự hàng rào
    Thành viên chính thức manhteen's Avatar
    Jun 2011
    kiến hưng hà đông hà nội
    kiểm trai file back up xem có pm file ko wire 120 và 308
  6. ( manhteen ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    quanlon (28-05-2013)
    Jun 2011
    simlock của bác mất rồi còn đâu
  8. ( manhteen ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  9. #7
    Trích Được post bởi manhteen Xem bài viết
    thế bây giờ phải làm sao hả bác em chỉ có pm full thôi em chưa làm cái này bao giờ nên *** quá
  10. #8
    V.I.P duykhanh_gsm's Avatar
    Aug 2011
    khu đèn đỏ
    nhấp vào read info rồi cho lên lại lock xem chưa thấy simlock đâu
  11. ( duykhanh_gsm ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  12. #9
    Trích Được post bởi duykhanh_gsm Xem bài viết
    dây anh
    Phone Type : RM-561
    LCD Version : SHARP
    AHNE Version : 30
    RETU Version : 16
    TAHVO Version : 22
    Simlock Information
    Phone Type : RM-561
  13. #10
    đã làm xong tks tất cả mọi người
  1. Xin giúp em 2700
    By tuantu0103 in forum BB5
    Trả lời: 19
    Bài viết cuối: 02-01-2013, 11:29
  2. 2700 cần giúp đở
    By sonfa139 in forum BB5
    Bài viết cuối: 28-12-2011, 18:13
  3. 2700 cần giúp
    By quanlon in forum BB5
    Trả lời: 21
    Bài viết cuối: 01-08-2011, 19:12
  4. 2700 mât loa xin ae giúp đỡ
    By ducmobi_1990tq in forum BB5
    Bài viết cuối: 11-05-2011, 17:12
  5. 2700 Liệt phím xin đc giúp đỡ
    By thanhhungcb in forum DCT4 - WD2
    Bài viết cuối: 04-04-2010, 20:05
