tình hinh em nhận con máy 6303 rm443 mở nguồn lên nokia rồi màn hình đen thui xong rồi lại trắng, rồi lại đen lặp lại 3 lần rồi mất nguồn, đã flash lại ver 10.12 nhưng vẫn vậy, phoenix, best tool, mxbox, jaf đều không được. bác nào nào gặp qua xin chỉ giáo. thank
đây là log bus check em nó
đây là log flashCode:MXKEY [MxKey Team HTI PLUS Flasher Interface 6], SN: C087FC4E Using device: USB ROM and HTI, FW ver: 00.50, SN: 01011FE1 Connection status: UHCI:HUB:HUB::USB 2.00 (Full-speed) Driver: NMWCD, ver: 7.1.32.84 Module ver: 1.0.0.21719(09-05-2013), Library ver: 1.0.0.14397(09-05-2013) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.0] CMT EM0 ID: 00000296 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 0920020DBEA68D56AC46708785216C462B762D6A CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID: 273F6D55DFAAF68F Flashing CMT Update Server Data, ULO: 0x3900 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, UPDAPP: 0x69180 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, PASUBTOC: 0x77780 bytes Update Server code succesfully sent to phone. Waiting for USB device removal ... Device connected: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 2B966540 Verifying communication to device OK. Waiting for USB device removal ... Waiting for device boot up ... Phone not found, retrying ... Warning: Phone did not reboot to normal mode. Market items is empty, please select the correct products path !
thank các bác đã quan tâmCode:MXKEY [MxKey Team HTI PLUS Flasher Interface 6], SN: C087FC4E Using device: USB ROM and HTI, FW ver: 00.50, SN: 01011FE1 Connection status: UHCI:HUB:HUB::USB 2.00 (Full-speed) Driver: NMWCD, ver: 7.1.32.84 Module ver: 1.0.0.21719(09-05-2013), Library ver: 1.0.0.14397(09-05-2013) Processing MCU file: rm443__10.12.mcusw [BB5,BB5 ALGORITHM] size: 24.67 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.0] CMT EM0 ID: 00000296 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 0920020DBEA68D56AC46708785216C462B762D6A CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID: 273F6D55DFAAF68F Flashing CMT Update Server Data, ULO: 0x3900 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, UPDAPP: 0x69180 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, PASUBTOC: 0x77780 bytes Update Server code succesfully sent to phone. Waiting for USB device removal ... Device connected: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 2B966540 Verifying communication to device OK. Erase size: 28.25 MB CMT FLASH,NOR area [00000000-0001FFFF] erased in 0.828 s CMT FLASH,NOR area [00040000-0005FFFF] erased in 0.688 s CMT FLASH,NOR area [00060000-0007FFFF] erased in 0.750 s CMT FLASH,NOR area [00080000-0015FFFF] erased in 4.968 s CMT FLASH,NOR area [00160000-0023FFFF] erased in 5.000 s CMT FLASH,NOR area [01740000-0191FFFF] erased in 11.844 s CMT FLASH,NOR area [00240000-0173FFFF] erased in 2 min 8.719 s CMT FLASH,NOR area [022E0000-0261FFFF] erased in 19.906 s Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent Selecting first CMT PAPUB block with matching RootKey. CMT PAPUBKEYS: E8E6E2AB [RAP Certificate 140 v.1] sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent CMT ISA+DYNSW block sent Programming completed in 1 min 15.141 s Processing PPM file: rm443__10.12.ppm_ctm [BB5,BB5 ALGORITHM] size: 7.36 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 9.75 MB CMT FLASH,NOR area [01920000-022DFFFF] erased in 59.469 s Flash programming ... Programming completed in 22.281 s Processing CNT file: rm443__10.12_ISM_009.image_c_de_steel_tmo_de [BB5,BB5 ALGORITHM] page size: 128 K size: 11.89 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 25.62 MB CMT FLASH,NOR area [02620000-029BFFFF] erased in 26.468 s CMT FLASH,NOR area [029C0000-03FBFFFF] erased in 2 min 38.688 s Flash programming ... Programming completed in 35.969 s Total time for flashing process(boot+erase+write) was 9 min 55.860 s Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Phone not found, retrying ... Warning: Phone did not reboot to normal mode. Market items is empty, please select the correct products path !
