    Thành viên chính thức yenmobile88's Avatar
    Dec 2009
    Mặc định X2 02 cần giúp
    tình hình là e nhận con x2 02 bật nguồn nên đến đoạn chập nhận lắp thẻ sim ,nhấn ok lại tắt nguồn luôn ,e chạy lại rồi nhưng không hết ,ae chỉ dáo với
    V.I.P duykhanh_gsm's Avatar
    Aug 2011
    khu đèn đỏ
    chạy rồi thì quăng cái lock lên ae xem thế nào
    Dec 2009
    chờ mình chút ,mình tắt tool mất rồi !
    Dec 2009
    Device synchronized.
    CPU: XGOLD 213
    Using embedded SBL from MCU.
    Sending EBL Loader...OK
    Sending EBL ...OK
    Getting EBL Version ...
    Boot mode: 0xCC
    EBL version major/minor: 10.46
    EBL version: Quantum_Bootloader_10.46_M1S1
    Protocol version suggested by phone: 3
    Set baud rate to: 6.50 Mbit/s
    Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits]
    CFI information:
    Flash settings: 0/1024, size: 0x04000000
    1 Block regions:
    512 x 0x00020000 = 0x04000000
    EBL ready !
    Original IMEI: 35169705268764
    RPL backup already exist (C:\mobileEx\3.5\data\backup\XGOLD_35169705268764_ back.RPL)
    Processing file: rm694__11.79.mcusw
    Downloading item CODE:rm694__11.79.mcusw_ebl_psi.fls, num block: 4, size: 26.25 MB
    Erasing area 0x40000000-0x4001FFFE ...OK
    Programming completed in 0.340 s
    Erasing area 0x40040000-0x4005FFFE ...OK
    Erasing area 0x40060000-0x4015FFFE ...OK
    Programming completed in 1.537 s
    Erasing area 0x40280000-0x41B7FFFE ...OK
    Programming completed in 32.336 s
    Checksum verified (0x7D76)
    Processing file: rm694__11.79.ppm_v
    Downloading item CUSTackage_v.ppm_ebl_psi.fls, num block: 1, size: 5.95 MB
    Erasing area 0x41C00000-0x421F2D62 ...OK
    Programming completed in 7.763 s
    Checksum verified (0x4B75)
    Processing file: rm694__11.79.image_v_059H3B7
    Downloading item CUSTackage_v_059H3B7.image.fls, num block: 1, size: 14.38 MB
    Erasing area 0x42300000-0x43E1FFFE ...OK
    Programming completed in 21.171 s
    Checksum verified (0x96E8)
    Total time for flashing process(boot+erase+write) was 7 min 48.692 s
    Waiting for USB device removal ...
    Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: CFFE83E
    log cua em nó đây ,ae nào làm qua chỉ dáo
    Aug 2011
    khu đèn đỏ
    lock thấy chưa đồng bộ được . cho qua box khác hay phonix flash lại coi sao a
  6. ( duykhanh_gsm ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    yenmobile88 (20-06-2013)
    Thành viên chính thức whanh2005's Avatar
    Oct 2011
    Con này bạn chạy phoenix là ok nhất. Chúc bạn thành công.
  8. ( whanh2005 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  9. #7
    Thành viên chính thức tho hoc nghe's Avatar
    Dec 2012
    chạy được nhưng không đồng bộ được
  10. ( tho hoc nghe ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  11. #8
    Mar 2012
    nam định
    mx box gặp phải con nàycos mà ngang gặp cướp
    lấy best hoặc phoenix flash lại xem.hay lại dính trưởng contac sevicer rồi
    HÃY HẾT LÒNG VÌ KHÁCH HÀNG
  12. ( A & T Mobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  13. #9
    Dec 2009
    Mình đã đem qua phoenix rồi ,nhưng không ăn thua gì hết .e hơi gà máy xgold ,có phải e chạy fw cao hơn EBL của nó nhi ?
