VolcaoBox 2.1.8
Whats new ?
World's 1st Added SPD Android Verification system
World's 1st Added SPD Android Verify your phone is Safe for format
World's 1st Added SPD Android Verify your phone is Safe for Root
World's 1st Added SPD Android Verify your phone is Safe for READ INFO
Added MTK 6260 Read Flash
Added MTK 6260 Write Flash
Added MTK 6260 Imei Repair
Added MTK 6260 Read privacy code
Adjust MTK Android One-key Root(Solve some phones failed to root)
Adjust coolsand Read flash bug
Read Instructions VERY CARE FULLY !!
About this Update Please Read very Care Fully before you operate any operation !!
VolcanoBox 2.1.8 Launched world's 1st SPD Android Verify Partitions System. for this Function you can Verify you mobile is SAFE for ROOT or Format or Read info. for this you must have Mobile in Powered ON condition & with Usb Debug mode ON !!. What you have to do it Simply Plug usb cable and click on Partition from Volcano soft and run it. it will tell you is your Phone Supported for SAFE format / ROOT etc or not. If software tell you is safe it will become log in GREEN color and if software tell you is not safe it will show you log in RED color. so here we start...
If software software show you log like this in GREEN COLOR.... This mean your phone is Supported for SAFE Root, format etc..
If software show you log like this in RED COLOR.... This mean your phone is NOT supported for SAFE Root, Format etc...Code:Partition as follows. It's supported to format and ROOT the mobile phone. >>mtdparts=sprd-nand:256k(spl),512k(2ndbl),256k(params),512k(vmjaluna),10m(modem),3840k(fixnv),3840k(backupfixnv),5120k(dsp),3840k(runtimenv),10m(boot),10m(recovery),200m(system),190m(userdata),60m(cache),256k(misc),1m(boot_logo),1m(fastboot_logo),3840k(productinfo),512k(kpanic)
How to do it ?Code:Partition as follows. It's NOT supported to format and ROOT the mobile phone. >>mtdparts=sprd-nand:256k(spl),512k(2ndbl),256k(params),512k(vmjaluna),10m(modem),3840k(fixnv),3840k(backupfixnv),5120k(dsp),3840k(runtimenv),10m(boot),10m(recovery),200m(system),190m(userdata),60m(cache),256k(misc),1m(boot_logo),1m(fastboot_logo),3840k(productinfo),512k(kpanic)
Download & Run 2.1.8
click on SPD
Select 6820
Select One Key Root
Select Partition
untick auto pinout
Plug normal usb cable to mobile in powered on condition
Usb debug must be Enabled
Click on run.
wait few sec it will Show you Logs as i describe above
Q: what is usefull if phone have pattern lock or any other problem and it have not usb debug Enabled then this option is useless how we can do that ?
A: Yes it's true that if phone have pattern lock or any other problem and usb debug not Enabled this function is really useless but infact it's not useless. many time we can't found factory files and many time Same working phone we can get from market so here is hint . Take same working phone, Should be 100% same, plug phone with usb and check is it Safe to format or not. if it's safe then you can do it without any problem and if phone is not safe then you simply don't do. so basically we make this function just to verify is phone is SAFE for format, Root etc or not...
Q: I plug phone but software not recognized or Software hang on "<<" then what to do ?
A: Perform these Steps
MAKE SURE YOUR PHONE IS CONNECTED IN POWERED ON CONDITION AND USB DEBUG ENABLED AND ADB ANDROID DRIVERS ARE INSTALLED AND YOU CAN SEE ADB ANDROID PHONE IN DEVICE MANGER !!!!!!
go to start
go to run
type "CMD"
clck on run
( go to Volcanobox 2.1.8 Folder/Tools ) for exmaple you have Volcano 2.1.8 in C: Drive so you should type this these commands. ( write all command without "" and right after every command you should press Enter button from keyboard)
"C:\" ( Press Enter )
it will become here
C:/>
then type
"cd VolcanoTool_v2.1.8\tools" ( Press Enter )
it will become here
C:/VolcanoTool_v2.1.8\tools>
then type
"adb devices"
now check what it's show to you
if it's show like this
* daemon not running. starting it now on port 5037 *
* daemon started successfully *
List of devices attached
this mean your phone is not detecting by your computer's ADB.exe
19761202 device
This mean your phone is detect by your computer's ADB.exe
Type this command
"adb kill-server" ( press enter button )
and again
so here you have to do totally two different ways to work with it.
so we will start
if you phone not detecting by your computer's ADB.exe then you have to do this
Keep phone connected
go to ( in windows Explorer )
C:\Documents and Settings\"Your name"\.android ( Your name should be your profile name here for exmaple "Jhon", "Anglina" etc )
there you can see some files
check do you have "adb_usb.ini" file in that folder or not
If you have then open it in note pad if not then create new file named "adb_usb.ini" and save it.
Be sure you save .INI extension not safe in any other format
for confirm open C: Drive in Windows Explorer
go to Tools
click on Folder Options
click on view
Untick Hide extension for known file type
click on ok
now see that file is exactly "adb_usb.ini" be sure it's not "adb_usb.ini.txt" etc
so as you done open it in note pad, ( if you already have this file then don't create new one just open it )
type this in new line and save it
"0x1782" ( write without "" )
so after you save file
open CMD again ( which already opened previously )
Type these commands
and again
now type
"adb devices" ( press enter button )
now it should show like this
19761202 device
now you are ready to go.
so right after this disconnect phone and connect it again and type these commands
"adb kill-server" ( press enter )
"adb device" ( press enter )
as it's show
19761202 device
Keep this CMD open and go to Volcanobox and perform these steps to know is my phone Supported for SAFE format or not !!
click on SPD
Select 6820
Select One Key Root
Select Partition
untick auto pinout
click on run
now it will show you your phones details in just 1 sec
after you can do what ever you want !!
so from now no more SPD ANDROID PHONE WILL BECOME DEAD IF YOU VERIFY IT BEFORE FORMAT OR ROOT.... Keep in mind we had tested over 110 phones non of phones become dead while verifying !!Code:Partition as follows. It's supported to format and ROOT the mobile phone. >>mtdparts=sprd-nand:256k(spl),512k(2ndbl),256k(params),512k(vmjaluna),10m(modem),3840k(fixnv),3840k(backupfixnv),5120k(dsp),3840k(runtimenv),10m(boot),10m(recovery),200m(system),190m(userdata),60m(cache),256k(misc),1m(boot_logo),1m(fastboot_logo),3840k(productinfo),512k(kpanic)
Very special Thanks to Stanner
Download link
Download MediaFire
			 VolcanoBox 2.1.8 Verification System for SPD Android &MTK6260 Read/Write/Imei/Privacy
