This image has been resized. Click this bar to view the full image. The original image is sized 800x675.
29/06/13 - Micro-Box&Dongle V2.1.7.4 - MIXED UPDATE
ADDED NEXT NEW MODELS:
- SAMSUNG Galaxy M919
- T-MOBILE M919
- SAMSUNG I317
- AT&T I317
- ZTE MF626
- ZTE MF628V
- ZTE F160
- ZTE BLADE 3 new version
BUG FIX part :
-Repaired ZTE unlock by Log ( was only by activation )
-Repaired Support button ON/OFF for allways able
-Added 9 round Banner
-Repaired go support problem
-Repaired when you select path for samsung flashes point to local folder and if you select desired folder for first file, other will point same folder
-Repaired port problem, default comport is now MicroBox
-Repaired apple check Error
-Repaired in HTC buton, that text show HTC and BLACBERRY
-Repaired SAMSUNG S3550 FLASH MODE WRITE FLASH: START! > SET DATA: ERROR!
-Repaired HTC wildfire buzz picture
-Repaired when sl-box is connected down at "micro-box aio version - sl-box connected" can't be displayed all message.
-Repiared if micro-box is connected and you get error, that spash screen will remain until make end process from task manager
As all know, on 1st July our Support start, so , all AIO Software release before today can be used any time.
All futur software will not allow you to use them if you are out of Support period.
If you are inside your support Period, then nothing change for you
Support can be buyed here : MICRO-BOX THE BEST MULTI PLATFORM UNLOCKING TOOL !
#1 CHECK IT HERE =>#1 SUPPORT WITH VIDEO TUTORIALS !!!
#1 CHECK IT HERE =>#1 REALTIME update of SUPPORTED MODELS list ! INCLUDED VIDEO LINKS !
MICRO BOX V2.0 THE BEST MULTI PLATFORM UNLOCKING TOOL ! - MICRO-BOX FULL ACTIVATED
			 29 06 13 - Micro-Box&Dongle V2.1.7.4 - Importante Update : Many added, Many Fixed
