    Thành viên chính thức BăngChâu_Mobile's Avatar
    Jun 2013
    Mặc định xin giúp nokia 5130c lỗi máy ảnh sẵn sàng
    em thay camera , giờ vào chụp ảnh " máy ảnh đã sẵn sàng " anh cho em xin file fix lỗi camera . em xin cảm ơn
    Jun 2013
    em chạy phoenix . anh xem log giúp em nha . cảm ơn anh
    Flashing started
    Creating product data items list
    Product data items list created
    Backup not required
    Flashing phone
    Initializing
    Scanning image files...
    Waiting for USB device...
    Loading secondary boot code: 14592 bytes
    Secondary boot loaded
    Loading update server code: 308032 bytes
    Update server loaded
    Asic CMT: Verifying communication to device...
    Asic CMT: Start programming 39531 KB...
    Asic CMT: Erasing rm495__07.97.mcusw
    Asic CMT: Erasing area 1...
    Asic CMT: Erasing area 2...
    Asic CMT: Erasing area 3...
    Asic CMT: Erasing area 4...
    Asic CMT: Erasing area 5...
    Asic CMT: Erasing area 6...
    Asic CMT: Erasing rm495__07.97.ppm_v
    Asic CMT: Erasing rm495__07.97.image_v_red
    Asic CMT: Programming rm495__07.97.mcusw
    Asic CMT: Programming 0%
    Asic CMT: Programming 2%
    Asic CMT: Programming 4%
    Asic CMT: Programming 6%
    Asic CMT: Programming 8%
    Asic CMT: Programming 10%
    Asic CMT: Programming 12%
    Asic CMT: Programming 14%
    Asic CMT: Programming 16%
    Asic CMT: Programming 18%
    Asic CMT: Programming 20%
    Asic CMT: Programming 22%
    Asic CMT: Programming 24%
    Asic CMT: Programming 26%
    Asic CMT: Programming 28%
    Asic CMT: Programming 30%
    Asic CMT: Programming 32%
    Asic CMT: Programming 34%
    Asic CMT: Programming 36%
    Asic CMT: Programming 38%
    Asic CMT: Programming 40%
    Asic CMT: Programming 42%
    Asic CMT: Programming 44%
    Asic CMT: Programming 46%
    Asic CMT: Programming rm495__07.97.ppm_v
    Asic CMT: Programming 48%
    Asic CMT: Programming 50%
    Asic CMT: Programming 52%
    Asic CMT: Programming 54%
    Asic CMT: Programming 56%
    Asic CMT: Programming 58%
    Asic CMT: Programming 60%
    Asic CMT: Programming 62%
    Asic CMT: Programming 64%
    Asic CMT: Programming 66%
    Asic CMT: Programming rm495__07.97.image_v_red
    Asic CMT: Programming 68%
    Asic CMT: Programming 70%
    Asic CMT: Programming 72%
    Asic CMT: Programming 74%
    Asic CMT: Programming 76%
    Asic CMT: Programming 78%
    Asic CMT: Programming 80%
    Asic CMT: Programming 82%
    Asic CMT: Programming 84%
    Asic CMT: Programming 86%
    Asic CMT: Programming 88%
    Asic CMT: Programming 90%
    Asic CMT: Programming 92%
    Asic CMT: Programming 94%
    Asic CMT: Programming 96%
    Asic CMT: Programming 98%
    Asic CMT: Programming 100%
    Phone flashing completed. Waiting for phone to boot up
    Bootup successful
    Verifying communication to product (before flash finalizing)
    Communication verified
    Product code changed
    Doing factorysets
    Factorysets complete
    Reading Dynamic Camera Configuration ID 1
    Updating configuration of camera with ID 1
    Dynamic Camera Configuration updating failed: 0x84167501 - AudioVisual: No configuration file matching the camera name string NIMMIIIIRRFF01035420 was found.
    Loading default data to phone
    Getting Data Package
    Reading product state
    Starting backup/restore sub-procedure: data item pre-delay
    data item pre-delay
    data item pre-delay
    Sub-procedure completed: Succeeded., result code: 0
    Starting to backup/restore data item: ProductProfile, version: 1.1
    Data Item backup/restore completed: Succeeded., result code: 0
    Starting backup/restore sub-procedure: data item post-delay
    data item pre-delay
    data item pre-delay
    Starting to backup/restore data item: Certificates, version: 1.0
    data item pre-delay
    data item pre-delay
    Starting to backup/restore data item: ISSVariantActivator, version: 1.0
    Backup/restore result: 0 out of 3 items were not backed up
    Default data loading complete
    Stopping all operations, returning phone to default mode
    All operations completed
    Firmware updating succeeded.
    XML log written
    Thành viên tích cực oh_mobile's Avatar
    Oct 2012
    bác kiếm cái camera good nâng tiếp xúc lên lắp vô là được mà,
  4. ( oh_mobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    BăngChâu_Mobile (15-07-2013)
    Thành viên tích cực TRUONGMOBILE-123's Avatar
    Aug 2012
    bạn tham khảo cái này nhá
  6. ( TRUONGMOBILE-123 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    V.I.P duykhanh_gsm's Avatar
    Aug 2011
    khu đèn đỏ
    thay cam thì cần file fix lại ok . chứ câu áp thay cam khác cũng dậy thôi
    chủ thear có lock mx cho lên hay info cho id cam up file cho chứ lock phonix e nhìn k nỗi
  8. ( duykhanh_gsm ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  9. #6
    Thành viên mới cunamobile's Avatar
    Nov 2010
    Anh thử đệm thêm xung quanh camera coi sao
  10. ( cunamobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  11. #7
    Jun 2013
    dạ vâng . em xin cảm ơn nha , em đo áp vẫn đủ mà , để em kiếm cái camera khác xong fix lại xem sao , em mới làm nên chưa có hộp anh ạ
  12. #8
    Mar 2012
    nam định
    thay cam thì fix lại cam chứ câu kéo gì cho mệt người
    HÃY HẾT LÒNG VÌ KHÁCH HÀNG
  13. ( A & T Mobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  14. #9
    Thành viên tích cực TUẤN ANH's Avatar
    May 2013
    sài gòn _vĩnh phúc
    đem máy đến chỗ linh kiện test camera luôn bạn . dòng này sài chung camera với 2700 mà rất kén . bữa test đến hơn chục cái camera mới được 1 cái ok .
    sài gòn _vĩnh phúc . saigongsm.vn https://www.facebook.com/profile.php?id=100004696661455
  15. ( TUẤN ANH ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  1. 5130c camera sẵn sàng new cho ae
    By Trường_Mobile in forum BB5
    Bài viết cuối: 02-10-2013, 08:18
  2. Trả lời: 8
    Bài viết cuối: 05-08-2012, 12:32
  3. Nokia 5220 báo máy ảnh sẵn sàng
    By 0979328238 in forum BB5
    Bài viết cuối: 20-05-2012, 19:11
  4. 5130c máy ảnh sẵn sàng.
    By viethuy_mobi in forum BB5
    Bài viết cuối: 15-02-2011, 20:53
  5. nokia c3 báo camera sẵn sàng
    By LÂM GIA mobile in forum BB5
    Bài viết cuối: 31-12-2010, 11:43
