các bác ngó em con 2700 lên bắt tay rùi trắng treo
Init Service mode... Wait...
Init Service mode Failed! Skip AfterFlash
Connect phone on selected interface...
Core : v1.51 , FlashEngine : v1.8
Selected FlashSettings : Manual
Files Set for Flashing :
MCU : rm561__09.98.mcusw
PPM : rm561__09.98.ppm_v
CNT : rm561__09.98.image_v_blac
Check FlashFiles, Please, wait...
-> SWversion check skipped : Dead mode selected
Backup enabled, Will read Certificates now...
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT ASICID : 000000010000022600010006030C192101033000
CMT EM0 ID : 00000296
CMT EM1 ID : 00000B22
CMT PUB ID : 29300111164F05567E9E214BF3D0FB1AA0D9829C
CMT MODE ID : 00
CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723
CMT ROM ID : 273F6D55DFAAF68F
CMT : Sending 2nd loader...
Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0
CMT Loader sent, Boot Ok
MCU Configuration
MCU Cfg Ok , 03
FLASHID : 240000EC , CMT , NOR
CMT Flash ID : 240000EC < SAMSUNG => K81259ETF
FLCNT : 00000000000000000000000000000000000000
FLASHID : 0000FFFF , CMT , MMC , EXT
CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok
Sending ALGO....
Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0
CMT Algo sent
CMT PAPUB : 3EA22A1DDA660002E56108DB5072A10F8709443FA8
Transmission mode : Dual (Ddr, TX2)
Boot Done!
CMT : Read NPC certificate...
Cert size : 20480 byte(s)
IMEI : 357405045551793
CMT : Read CCC certificate...
Cert size : 30600 byte(s)
CMT : Read HWC certificate...
CMT : Read VARIANT certificate...
Cert size : 0 byte(s)
Cert Read done!
CRT308 Backup Created
SLx Simlock Data read ... ok
SL3 Simlock Sign read ... ok
WMDRM read ... ok
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
SimLock Data saved...
SimLock Key saved...
WMDRM_PD Data saved...
RPL saved : D:\PHOENIX\Infinity Best\Backup\Cert\357405045551793.rpl
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT MODE ID : 00
MCU Configuration
MCU Cfg Ok , 03
Sending ALGO....
CMT Algo sent
Boot Done!
Erase : Processing rm561__09.98.mcusw
Found 6 areas to erase, erase group
Asic : CMT , Sub : NOR
CMT , NOR , Area : 0x00000000 - 0x000006BF
CMT , NOR , Area : 0x000006C0 - 0x0001FFFF
CMT , NOR , Area : 0x00040000 - 0x000BFFFF
CMT , NOR , Area : 0x000C0000 - 0x0013FFFF
CMT , NOR , Area : 0x00140000 - 0x0137FFFF
CMT , NOR , Area : 0x01380000 - 0x0151FFFF
Using TimeOut : 7 min ( 430 sec )
Erasing, wait.....
CMT : Group erase Ok
TIME : Erase time : 00:01:24
PrReq : NOR , 00
Write : Processing rm561__09.98.mcusw
CMT: Writing Hash CERT [NOLO]
CMT: Writing Hash CERT [KEYS]
CMT: Writing Hash CERT [PRIMAPP]
CMT: Writing Hash CERT [PASUBTOC]
CMT: Writing Hash CERT [PAPUBKEYS]
CMT: Writing Hash CERT [UPDAPP]
CMT: Writing Hash CERT [DSP0]
CMT: Writing Hash CERT [MCUSW]
Total writen 1247 blocks
TIME : Write time : 00:02:29
PrReq : NOR , 00
Erase : Processing rm561__09.98.ppm_v
Found 1 areas to erase, erase group
CMT , NOR , Area : 0x01520000 - 0x01DBFFFF
Erasing, wait.....
TIME : Erase time : 00:00:30
PrReq : NOR , 00
Write : Processing rm561__09.98.ppm_v
Total writen 442 blocks
TIME : Write time : 00:00:53
PrReq : NOR , 00
ConvertImage: Processing rm561__09.98.image_v_blac
ConvertImage: Page Size is 128K, no need convert
Erase : Processing rm561__09.98.image_v_blac
Found 2 areas to erase, erase group
CMT , NOR , Area : 0x01DC0000 - 0x0215FFFF
CMT , NOR , Area : 0x02160000 - 0x03FBFFFF
Erasing, wait.....
TIME : Erase time : 00:01:35
PrReq : NOR , 00
Write : Processing rm561__09.98.image_v_blac
Total writen 872 blocks
TIME : Write time : 00:01:45
PrReq : NOR , 00
Reading Phone Info....
Connected phone - Nokia 2700 classic
Software Info: V 09.98
06-09-10
RM-561
(c) Nokia
IMEI: 357405045551793
Product code: 059D1B4
Checking...
SimLock status : SimLock is Ok
Security status : Security is Ok
Read Info Done!
Checking User Certificates...
Total - 0 certs
Uploading certificates...
Writen 21 certs!
AfterFlash operations done ;D
Phone found!
Series 40 Device detected!
read info... - Ok
Resetting selected items...
Check phone mode...
Phone in Local mode
Seting Test mode... wait...
Test mode set
Settings Full Factory Defaults...
Set OK!
Settings User Data Defaults...
Set OK!
Elapsed: 00:01:59
Phone disconected!
Phone found!
read info... - Ok
Phone disconected!
			 các bác xem họ em log con 2700
			 Được post bởi vanngocmobile
