Kết quả 1 tới 3 của 3
    Thành viên tích cực caokyit's Avatar
    Nov 2010
    468 Hùng Vương-Tam Kỳ - Quảng Nam
    Mặc định Nhờ AE xem dùm cái log. lắp sim báo nhập mã hạn chế.
    Tình hình là mình nhận của khách đem vào báo nhập mã hạn chế.mình chạy lại nhưng vẫn vậy.ae có cách giải quyết nào khác không?
    MXKEY [MxKey Team HTI PLUS Flasher Interface 0], SN: C0874A13
    Using device: HTI, FW ver: 00.50, SN: 01014799
    Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed)
    Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7600.16385
    Module ver: 1.0.0.21724(14-05-2013), Library ver: 1.0.0.14397(09-05-2013)
    Processing MCU file: rm217__07.30.mcusw
    [BB5,BB5 ALGORITHM] size: 14.50 MB
    Supported Ids: 0103192101001101, 010C192101001101
    CMT Data :
    SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAP3G ver: PA 1.x]
    EM0 ID: 00000232
    EM1 ID: 00000353
    PUBLIC ID: 21400216BD346F568BF0C09DDFAA63E58E8D7AE9
    ASIC MODE ID: 00
    ROM ID: 191EC665DFAAF68F
    eBB5ProtocolType: OLD
    Storage0: 00EC 2208 - 0000 6921 [Samsung K8F5615ETM,256 Mbits] type: FLASH,NOR, asic:CMT
    TransmissionMode: 16Bit
    CMT PAPUBKEYS HASH: 7F7E6491E8D30494B45630BB3A8599F4E1C674C9
    TransmissionMode: DDR&TX2
    Storing certificate [NPC, VARIANT, R&D] ...OK
    Erase size: 16.37 MB
    CMT FLASH,NOR area [00000000-000006BF]
    CMT FLASH,NOR area [000006C0-0001FFFF]
    CMT FLASH,NOR area [00020000-0007FFFF]
    CMT FLASH,NOR area [00080000-000DFFFF]
    CMT FLASH,NOR area [00100000-001FFFFF]
    CMT FLASH,NOR area [00200000-0031FFFF]
    CMT FLASH,NOR area [00320000-0105FFFF]
    CMT FLASH,NOR area [01060000-01067FFF]
    CMT FLASH,NOR area [01068000-0107FFFF]
    erased in 43.376 s
    Prog.status for Asic CMT ...
    NOR: OK
    Flash programming ...
    CMT NOLO block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT PASUBTOC block sent
    CMT PAPUBKEYS: 7F7E6491 [RAP Certificate 52 v1] sent
    CMT UPDAPP block sent
    CMT DSP0 block sent
    CMT MCUSW block sent
    CMT PMM_CONF block sent
    CMT SBIF_CONF block sent
    NOR: OK
    Programming completed in 1 min 11.712 s
    Processing PPM file: rm217__07.30.ppm_r
    [BB5,BB5 ALGORITHM] size: 5.16 MB
    CMT Data :
    EM0 ID: 00000232
    EM1 ID: 00000353
    ASIC MODE ID: 00
    Erase size: 5.50 MB
    CMT FLASH,NOR area [01080000-015FFFFF]
    erased in 15.270 s
    NOR: OK
    NOR: OK
    Programming completed in 28.019 s
    Processing CNT file: rm217__07.30.image_ctv_cn_black
    [BB5,BB5 ALGORITHM] page size: 64 K size: 4.57 MB
    NOR page size in the phone is 128 K.
    CMT Data :
    EM0 ID: 00000232
    EM1 ID: 00000353
    ASIC MODE ID: 00
    Erase size: 9.87 MB
    CMT FLASH,NOR area [01600000-01FDFFFF]
    erased in 25.970 s
    NOR: OK
    Converting UCP blocks to 128 K.
    NOR: OK
    Programming completed in 23.454 s
    Total time for flashing process(boot+erase+write) was 4 min 5.702 s
    Phone type: RM-217 (Nokia 6300)
    SW version: V 07.30 07-05-09 RM-217 (c) Nokia.
    Imei plain: 35293902445987-0
    Product code: 0563812
    Battery voltage: 4981 mV, current: 99 mA
    Language Pack:
    - not available.
    SLPA ver[1]: PA_SL (15 digit NCK)
    SIMLOCK seems to be valid
    CMLA_KEY seems to be valid
    WMDRM_PD seems to be valid
    SIMLOCK_TEST passed
    SECURITY_TEST passed
    Imei net: 352939024459870
    Version: SIMLOCK SERVER VERSION 63
    Counter: 0/3, 0/10
    CONFIG_DATA: FFFFFFFFFFFFFFFF
    PROFILE_BITS: FFFFFFFFFFFFFFFF
    BLOCK1: 1=CLOSED(MCCMNC), DATA=00101F
    FULL FACTORY... OK
    USER DATA... OK
    LEAVE FACTORY... OK
    SERVICE CENTER... OK
    SOFTWARE UPGRADE... OK
    PRODUCTION TUNING... OK
    Reset User Code (to default:12345) ... OK
    Completed in 1.621 s
    Thành viên mới duymobilegsm's Avatar
    Nov 2012
    repai sd xong nói đòi sx4 thì sx4 wire 1-309 vào ok
    Dec 2012
    SX4. Write PM 1 & 309 là done nhé.
    Những kẻ trí tuệ tầm thường thường hay lên án những gì vượt quá tầm hiểu biết của họ. ...
  1. Trả lời: 6
    Bài viết cuối: 21-09-2013, 16:56
  2. Trả lời: 13
    Bài viết cuối: 15-09-2012, 21:10
  3. Trả lời: 4
    Bài viết cuối: 08-10-2010, 07:51
  4. Trả lời: 5
    Bài viết cuối: 04-03-2010, 14:20
  5. Trả lời: 4
    Bài viết cuối: 09-01-2009, 15:27
