Kết quả 1 tới 10 của 15
    Thành viên chính thức dzuylzoi90_mobile's Avatar
    Feb 2013
    Mặc định 2700 lên nguôn hiện NOKIA bắt tay xong trắng màn rồi tắt
    em đã flash lại rồi chạy vẻ 9.97 và 9.98 chuân vẫn not ok
    log của em nó đây
    MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C08804DF
    Using device: USB ROM and HTI, FW ver: 00.50, SN: 01012305
    Connection status: UHCI:HUB::USB 2.00 (Full-speed)
    Driver: NMWCD, ver: 7.1.32.84
    Module ver: 1.0.0.21719(09-05-2013), Library ver: 1.0.0.14397(09-05-2013)
    Processing MCU file: rm561__09.98.mcusw
    [BB5,BB5 ALGORITHM] size: 19.41 MB
    Waiting for USB ROM device ...
    CMT SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.0]
    CMT EM0 ID: 00000296
    CMT EM1 ID: 00000B22
    CMT PUBLIC ID: 2500020510800F567DF9A6DD02ECE2964558E588
    CMT ASIC MODE ID: 00
    CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
    CMT ROM ID: 273F6D55DFAAF68F
    Flashing CMT Update Server Data, ULO: 0x3900 bytes
    Update Server code succesfully sent to phone.
    Flashing CMT Update Server Data, UPDAPP: 0x4B340 bytes
    Flashing CMT Update Server Data, PASUBTOC: 0x59980 bytes
    Waiting for USB device removal ...
    Device connected: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 2EAF9543
    Verifying communication to device OK.
    Erase size: 21 MB
    CMT FLASH,NOR area [00000000-000006BF] erased in 0.515 s
    CMT FLASH,NOR area [000006C0-0001FFFF] erased in 0.500 s
    CMT FLASH,NOR area [00040000-000BFFFF] erased in 1.907 s
    CMT FLASH,NOR area [000C0000-0013FFFF] erased in 2.062 s
    CMT FLASH,NOR area [00140000-0137FFFF] erased in 1 min 11.172 s
    CMT FLASH,NOR area [01380000-0151FFFF] erased in 6.750 s
    Flash programming ...
    CMT NOLO block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT PASUBTOC block sent
    Selecting first CMT PAPUB block with matching RootKey.
    CMT PAPUBKEYS: 3EA22A1D [RAP Certificate 202 v.1] sent
    CMT UPDAPP block sent
    CMT DSP0 block sent
    CMT MCUSW block sent
    Programming completed in 1 min 35.922 s
    Processing PPM file: rm561__09.98.ppm_v
    [BB5,BB5 ALGORITHM] size: 6.90 MB
    Erase size: 8.62 MB
    CMT FLASH,NOR area [01520000-01DBFFFF] erased in 35.719 s
    Programming completed in 34.078 s
    Processing CNT file: rm561__09.98.image_v_blac
    [BB5,BB5 ALGORITHM] page size: 128 K size: 13.64 MB
    Erase size: 34 MB
    CMT FLASH,NOR area [01DC0000-0215FFFF] erased in 15.703 s
    CMT FLASH,NOR area [02160000-03FBFFFF] erased in 2 min 7.454 s
    Programming completed in 1 min 5.375 s
    Total time for flashing process(boot+erase+write) was 8 min 14.906 s
    Waiting for USB device removal ...OK
    Waiting for USB device arrival ...OK
    Device connected: nmwcdc\Nokia 2700 classic USB Phonet, PORT_ID: 1ADE7419
    Phone type: RM-561 (Nokia 2700 classic)
    SW version: V 09.98 06-09-10 RM-561 (c) Nokia
    Imei plain: 35861204104772-1
    Product code: 059D1B4
    Battery voltage: 3840 mV, current: 128 mA
    Language Pack:
    - not available.
    Imei net: 358612041047721
    Version: SIMLOCK SERVER
    Counter: 0/3, 0/10
    CONFIG_DATA: 2440700000000000
    FULL FACTORY... OK
    USER DATA... OK
    LEAVE FACTORY... OK
    SERVICE CENTER... OK
    SOFTWARE UPGRADE... OK
    PRODUCTION TUNING... OK
    Reset User Code (to default:12345) ... OK
    Completed in 1.219 s
  2. ( dzuylzoi90_mobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    hoasimtim (30-08-2013)
    May 2012
    lắc nhà lầu đi bạn ,nếu ko được làm chân đóng lại sẽ ok , bệnh truyền kiếp của mấy con này là vậy đó
    Feb 2013
    vậy hả đê mình xem nhưng con này hai tâng ma anh đóng lại ca hai con ha anh
    May 2012
    uk đúng rồi đóng lại cả 2 nhé bạn . nó cũng khó chết nhưng cũng phải cẩn thận về nhiệt độ cho chắc nhé bạn. chúc bạn thành công
    Thành viên tích cực NGUYỄN BẢO's Avatar
    Dec 2011
    long hải
    trước hết bạn nên tìm họp atf để phục hồi lỗi image trước đả,đôi khi mình chạy ver cao quá nó bị lổi file đó bạn
    CHÂU THÀNH-AN GIANG
    kt áp cấp cho flash trước nếu ko đc nữa thì nhà lầu là thẵng tiến
    V.I.P Lão_Đại's Avatar
    hải phòng
    Log quá ngon 90% bệnh này là em flash bị lỗi , đóng lại không ăn thua , Thay cặp là DON
  9. #8
    PHÚ ĐIỀN-TÂN PHÚ-ĐỒNG NAI
    backup full lại trước khi đụng tới nhà lầu ,rồi đá chân flash hoặc làm chân lại cặp luôn not ok thay con flash write những gì backup lại =done thôi bệnh truyền kiếp 2700 ,5130 mà
    yahoo :nhathuy_mobile2009
  10. #9
    Thành viên tích cực dongdt's Avatar
    Jan 2013
    chết flast rồi bác ak backup lại sau đó thay flast là ok thôi bác bệnh truyền thế kỷ
    yahoo : diemhentinhyeu469
    dt:0944788081
  11. #10
    V.I.P Chaunv.Mobile's Avatar
    Tiền Giang
    90% là thay cặp khác
    Học Học Nữa Học Mãi
    chaunv78@yahoo.com 0945.618.618
  1. Trả lời: 9
    Bài viết cuối: 30-09-2014, 21:50
  2. nokia N70 nạp Flash xong máy báo ok nhưng mở nguồn lên chữ Nokia xong tắt luôn
    By huuphucmobile2012 in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 09-04-2013, 18:47
  3. Trả lời: 14
    Bài viết cuối: 03-10-2012, 08:52
  4. 1280 mở nguồn lên nokia xong trằng màng hình
    By PHÁT TÀI in forum DCT4 - WD2
    Bài viết cuối: 03-06-2012, 08:38
