Như tiêu đề máy trước khi được xóa full em đã backup full file pm và rpl , nhưng khi xóa full xong em đã nạp lại file pm báo lỗi đây là log của em nó anh nào đã gặp qua xin giúp dùm em tk nhìu :
ATF Software Version v10.11
ATF Nitro FBUS Flash Started...
Number of Image Files: 5
Processing Image File :
C:\Program Files\Nokia\Phoenix\Products\RM-675\RM-675_111.040.1511_79u_prd.core.fpsx
CMT Type : BB5
CMT Algorithm : XSR 1.6
Secondary Sending Speed : 650000 Hz
Algorithm Sending Speed : 6500000 Hz
Program Sending Speed : 13000000 Hz
Message Reading Speed : 98000 Hz
Number of Blocks : 535
Entry Point : 0x0222
Page Format : 128K
Maximum Page Size : 0x00040000
Changing MODE : FLASH
Booting Phone via FBUS...
VBATT Powering Down <<<<
VBATT Powering Up >>>>
SET VCCIO Level Done
SET BSI Load Done
AdvanceBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
TIME STARTS HERE
BootFlashModeDCT5Ex Succeeded after 3 Attempts
Number of Sub Blocks 7 (0x07)
1 SYSTEM_ASIC_ID 01
Block Length : 21 (15)
BB ASIC Index : 0 (00) CMT
ID DWORD 0 : 00000003
ID DWORD 1 : 00000226
ID DWORD 2 : 00010007
ID DWORD 3 : 600C1921
ID DWORD 4 : 02031104
2 EM_ASIC_ID 02
Block Length : 5 (05)
ID DWORD 0 : 00001040
3 EM_ASIC_ID 02
ID DWORD 0 : 00001030
4 PUBLIC_ID 12
ID DWORD 0 : 27D00014
ID DWORD 1 : CED80344
ID DWORD 2 : 185F977E
ID DWORD 3 : 70416CB3
ID DWORD 4 : 071640ED
5 ASIC_MODE_ID 13
Block Length : 2 (02)
Mode Id : 00
6 ROOT_KEY_HASH 14
Block Length : 17 (11)
Hash : 91 6F 75 21 7F 32 08 12 48 B1 5C 38 DF C8 E8 1B
7 ROM_ID 15
Block Length : 9 (09)
CRC 0 : E693EF0D
CRC 1 : AC22615B
Checksum 9D
SearchForBootstrap_DCT5..
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_2nd.fg
Boot File - Version 012.014.00
Boot File - Revision 0x0003 (3)
eBB5ProtocolType == New
PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0"
PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0"
Secondary Loader Sent...
TransmissionTypeRequest_DCT5_NewProtocol
TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0
FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX
TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C
Transmission Type Request Sent...
MessageID : 06
SubBlocks : 06
Block Length : 0B
BB ASIC Index : CMT 00
Device Type : RAM 05
Device Index : 00
Manufacturer Code : 0000 -> Flash
Device ID : 0000 -> not detected
Extended/Fixed ID : 0000
Revision ID : 0000
2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MMC 04
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Type : NOR 00
Device Index : 00
Manufacturer Code : FFFF -> BAD FLASH VENDOR
Device ID : FFFF -> Type not in database
Revision ID : 0000
4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Index : 01
Manufacturer Code : 0000 -> SPANSION
Device ID : 0001 -> not used
Revision ID : 0000
5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MuxOneNAND 03
Device Index : 00
Manufacturer Code : 00EC ->
Device ID : 0060 -> Type not in database
Revision ID : 0032
6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5
Block Length : 09
Data : XSR 1.6
Checksum : FC
FLS1SendAlgoCodeEx..
SendAlgoCode_DCT5..
SearchForAlgorithm_DCT5..
Looking for ALL Devices...
Searching Algorithm Files MuxOneNAND (03) ManID :00EC DevID :0060 ExtID :0000 RevID :0032
Flash Descriptor
Device ID : 0060
Revision ID : 0000
Size : 40000000 (1024 MB)
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_XSR17_alg.fg
Algorithm File - Version 012.014.00
Algorithm File - Revision 0x0003 (3)
Algo Loader Sent...
SendCodeStart_NewProtocol :
SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00)
FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
FUR control Ok...
VPP Enabled by Software
Using Internal VPP
FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4
PAPUB_KEYS_HASH_REQ_BB5
No PAPUBKeysHash Returned
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
Certificate 1
ASIC Index : CMT 0
Certificate 2
ASIC Index : CMT 0
Certificate 3
ASIC Index : CMT 0
Certificate 4
ASIC Index : CMT 0
Certificate 5
ASIC Index : CMT 0
STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 2B 0D 50 41 52 54 4E 45 52 43 00 00 00 00 00 3B
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5...
Partition Info
Partition Blocks : 1
1 PARTITION_INFO_BB5
BB ASIC Index : 0x00 CMT
Device Type : 0x03 MuxOneNAND
Device Index : 0x00
Partition Version : 00020000
Spare : FFFFFFFF
Num Partitions : 00000005
Partition 1
Attribute : 00000002 RO
Start Address : 00140000
Partition 2
ID : 00000004 DEMANDONOS
Start Address : 02B60000
Partition 3
ID : 00000008 FILESYSTEM
Attribute : 00000001 RW
Start Address : 0E980000
Partition 4
Start Address : 2E100000
Partition 5
Start Address : 3E600000
PARTITION_INFO_REQUEST_BB5 : 64012F5F00030000020000FFFFFFFF00000005000000030000 00020014000002A20000000000040000000202B600000BE200 0000000008000000010E9800001F7800000000002700000001 2E100000105000000000000A000000013E600000004000000D
PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5 : No Error - 0 (0x00)
StartErase_DCT5...
BlockLength : 0x57 (87)
ERASE Blocks : 0x02 (2)
0 ERASE_AREA_BB5 0x12
Block Length : 0x23 (35)
Device Index : 0x00
0 : 00040000-0007FFFF
1 : 000C0000-008BFFFF
2 : 00DC0000-0E97FFFF
3 : 2E100000-3E5FFFFF
1 FORMAT_PARTITION_BB5 0x19
Block Length : 0x2F (47)
Device Index : 0x00
Format Info ID : 0x02000000
Format Info : 000000000000000A0000000000000002000000640000000B00 000002000000010000000000000000
Erase_SendEraseBlock_BB5_NAND
Task in Progress... Please Wait...
Erase_SendFormatPartition_BB5_NAND
Successfully erased..
Time Taken to Erase : 00:00:02
Flashing Speed: 5.00 Mhz (AUTO)
Processing : RM-675_111.040.1511_79u_prd.core.fpsx
Total blocks to write : 535
>> CMT Rootkey Hash CERT : ADA
>> CMT Rootkey Hash CERT : KEYS
>> CMT Rootkey Hash CERT : PRIMAPP
>> CMT Rootkey Hash CERT : RAP3NAND
>> CMT Rootkey Hash CERT : SOS+PMML
>> CMT Rootkey Hash CERT : SOS+DECOMP
>> CMT Rootkey Hash CERT : PASUBTOC
>> CMT Rootkey Hash CERT : PAPUBKEYS [95A68E9FA27B2BFA89EA204FC846EB73DEF1D93F]
>> CMT Rootkey Hash CERT : GENIO_INIT
>> CMT Rootkey Hash CERT : SOS+IVE3A
>> CMT Rootkey Hash CERT : SOS*UPDAPP
>> CMT Rootkey Hash CERT : SOS*DSP0
>> CMT Rootkey Hash CERT : LDSP
>> CMT Rootkey Hash CERT : SOS*ISASW
>> CMT Rootkey Hash CERT : SOS+CORE
>> CMT Rootkey Hash CERT : SOS+ROFS1
ContinueFlash_DCT5 Complete
Continue Flash Complete : : No Error - 0 (0x00)
Time Taken to Flash : 00:01:09
C:\Program Files\Nokia\Phoenix\Products\RM-675\RM-675_111.040.1511_C02.01_SEAP_79u_prd.rofs3.fpsx
CMT Type : BB5
Number of Blocks : 6
Entry Point : 0x0103
Page Format : 128K
Maximum Page Size : 0x00004E00
StartErase_DCT5...
BlockLength : 0x16 (22)
ERASE Blocks : 0x01 (1)
Block Length : 0x13 (19)
Device Index : 0x00
0 : 01378000-0139FFFF
1 : 0DA80000-0E97FFFF
Time Taken to Erase : 00:00:00
Processing : RM-675_111.040.1511_C02.01_SEAP_79u_prd.rofs3.fpsx
Total blocks to write : 6
>> CMT Rootkey Hash CERT : SOS+ROFS3
>> CMT Rootkey Hash CERT : SOS+IVE3B
Time Taken to Flash : 00:00:00
C:\Program Files\Nokia\Phoenix\Products\RM-675\RM-675_111.040.1511_19.01_Vietnam_79u_prd.rofs2.fpsx
CMT Type : BB5
Number of Blocks : 149
Entry Point : 0x00FB
Page Format : 128K
StartErase_DCT5...
BlockLength : 0x0E (14)
Block Length : 0x0B (11)
Device Index : 0x00
0 : 09F40000-0DA7FFFF
Processing : RM-675_111.040.1511_19.01_Vietnam_79u_prd.rofs2.fpsx
Total blocks to write : 149
>> CMT Rootkey Hash CERT : SOS+ROFS2
Time Taken to Flash : 00:00:20
C:\Program Files\Nokia\Phoenix\Products\RM-675\RM-675_111.040.1511_U03.01_79u.uda.fpsx
CMT Type : BB5
Number of Blocks : 871
Page Format : 128K
StartErase_DCT5...
Device Index : 0x00
0 : 0E980000-2E0FFFFF
Processing : RM-675_111.040.1511_U03.01_79u.uda.fpsx
Total blocks to write : 871
Time Taken to Flash : 00:02:08
C:\Program Files\Nokia\Phoenix\Products\RM-675\rm675_ENO_v_0.0514_APEONLY.fpsx
CMT Type : BB5
Program Sending Speed : 6500000 Hz
Number of Blocks : 21
Entry Point : 0x0138
Page Format : 128K
StartErase_DCT5...
Device Index : 0x00
0 : 008C0000-00DBFFFF
Processing : rm675_ENO_v_0.0514_APEONLY.fpsx
Total blocks to write : 21
>> CMT Rootkey Hash CERT : SOS*ENO
Time Taken to Flash : 00:00:03
Total Flash Write Time (Flashing Only) : 00:03:42
Total Flashing Time (Booting + Erase + Flashing) : 00:03:48
STATUS_REQUEST_BB5...
1 Sub Block ID : 15 STATUS_NAND_OK_BB5
Block Length : 0F
BB ASIC Index : 00
Device Type : 05
Device Type : 0F
Num Bad Blocks : 0000000A
Additional Bad : 0000FFFF
Correctable ECC : 0000FFFF
Forcing Test Mode via BUSCHECK...
BootFlashMode_DCT5
TIME STARTS HERE
1 SYSTEM_ASIC_ID 01
2 EM_ASIC_ID 02
3 EM_ASIC_ID 02
4 PUBLIC_ID 12
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : E693EF0D
CRC 1 : AC22615B
Checksum 9D
MessageID : 06
SubBlocks : 06
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 01
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0032
Block Length : 09
Data : XSR 1.6
Checksum : F8
SendAlgoCode_DCT5..
Flash Descriptor
Device ID : 0060
Revision ID : 0000
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
Algo Loader Sent...
FUR control Ok...
Using Internal VPP
PHONE_INFO_RESPONSE_BB5
PAPUB_KEYS_HASH_RESP_BB5 2A
BB Asic Index : 00
CMT PAPUBKEYS HASH:
PHONE FIRMWARE VERSION:
111.040.1511
Scanning Simlock Applet Type...
OK
PA_SIMLOC30 Applet detected
Use "Scan Phone" Button to Check if this Phone
uses a 15-digit NCK or a 20-digit NCK...
* Firmware Version Downgrade will KILL PHONE !!!
* Manual Full Erase WILL KILL PHONE!!!
* Simlocks are in PM 120 Only...
* PM 308 is Write Protected...
Waiting for Phone to Go Online...
Elapsed Time: 1s
Elapsed Time: 2s
Elapsed Time: 3s
Elapsed Time: 4s
Elapsed Time: 5s
Elapsed Time: 6s
Elapsed Time: 7s
Elapsed Time: 8s
Elapsed Time: 9s
Elapsed Time: 10s
Basic Phone Information
Selected PM File: C:\AdvanceBox Turbo Flasher\Nokia\Backup\357395046838317\3573950468383 17_RM-675_0-400_113953.pm
Start Uploading PM...
SET BSI Load Done
BootFlashMode_DCT5
TIME STARTS HERE
1 SYSTEM_ASIC_ID 01
2 EM_ASIC_ID 02
3 EM_ASIC_ID 02
4 PUBLIC_ID 12
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : E693EF0D
CRC 1 : AC22615B
Checksum 9D
MessageID : 06
SubBlocks : 06
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 01
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0032
Block Length : 09
Data : XSR 1.6
Checksum : F8
SendAlgoCode_DCT5..
Flash Descriptor
Device ID : 0060
Revision ID : 0000
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
Algo Loader Sent...
FUR control Ok...
Using Internal VPP
BB Asic Index : 00
CMT PAPUBKEYS HASH:
111.040.1511
OK
Elapsed Time: 1s
Elapsed Time: 2s
Elapsed Time: 3s
Elapsed Time: 4s
Elapsed Time: 5s
Elapsed Time: 6s
Elapsed Time: 7s
Elapsed Time: 8s
Elapsed Time: 9s
Elapsed Time: 10s
ERROR: Write PM Failed
NO PHONE DETECTED/PHONE DISCONNECTED
