Kết quả 1 tới 10 của 11
    Thành viên tích cực uyếnhà's Avatar
    Oct 2011
    Mặc định các bác xem dùm em cái log x3-02
    ASIC MODE ID: 00
    ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B
    ROM ID: E693EF0DAC22615B
    SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 12.14.0 revision: 3.0 size: 0x3B40
    Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104
    eBB5ProtocolType: NEW
    TransmissionMode: DDR&TX2
    Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
    Storage4: 00EC 0030 - 0000 0431 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: FLASH,MuxOneNAND, asic:CMT
    Suggested algorithm: XSR 1.6
    Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 12.14.0 revision: 3.0 size: 0xD4569
    CMT PAPUBKEYS HASH: 23B57C26A0C7A9C34544727AA1D2FC8F3265329C
    Original Imei: 35538004080411
    Original Product code: 0598419
    Bluetooth ID: 94205354EA1B
    SIMLOCK PA identifier:
    [0] PA_SIMLOC30
    Phone type: RM-639 (Nokia X3-02)
    SW version: V 07.16 13-01-12 RM-639 (c) Nokia
    Imei plain: 35538004080411-1
    Product code: 0598226
    Battery voltage: 4486 mV, current: 80 mA
    Language Pack:
    - not available.
    SLPA ver[5]: PA_SIMLOC30 (20 digit NCK)
    Camera config: 0A4E2007008005, ver:
    RPL saved to "C:\mobileEx\3.5\data\backup\BB5_RM-639_355380040804111_19_09_13_160018_SIM.RPL"
    SIMLOCK seems to be valid
    WMDRM_PD seems to be valid
    SIMLOCK_TEST passed
    SECURITY_TEST passed
    "C:\Program Files\Nokia\Phoenix\Products\RM-639" folder created.
    Imei net: 355380040804111
    Version: SIMLOCK SERVER
    Counter: 0/3, 0/10
    CONFIG_DATA: 2440700000000000
    hiên tại máy kep dòng treo ở mức 2a
    0972648789
    Thành viên tích cực hUNGSUAKA's Avatar
    chạy lại file khác xem sao!!Language Pack:
    - not available.
    cuộc sống thay đổi khi chúng ta thay đổi
    Oct 2011
    Trích Được post bởi hUNGSUAKA Xem bài viết
    - not available.
    ok mình đang chạy
    0972648789
    sao rồi chú !!!
    V.I.P duykhanh_gsm's Avatar
    Aug 2011
    khu đèn đỏ
    lock ok đây k phải lỗi này
    Language Pack:
    - not available.
    Oct 2011
    Processing MCU file: rm639__07.51.mcusw
    [BB5,XSR 1.6] size: 30.61 MB
    Supported Ids: 0003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104
    Storing certificate [NPC, CCC, HWC, R&D] ...ERROR: Packet Error(0xAA), code 0xA4000002
    Error
    chạy tới đây báo lỗi
    0972648789
    hiện máy có lên nguồn hay không? kiếm file đụng nóc chạy cho nó, nếu not ok thì kiểm tra phần cứng thôi
    Oct 2011
    Trích Được post bởi HQDuan_GSM Xem bài viết
    hiên tại máy ko lên nguồn?
    0972648789
    Nov 2010
    chạy lại chi trời log trên là ok rồi
    giờ chạy lại file cũ đi chứ log trên là ok rồi á
    test cái bo phím khác xem hôm gặp 1 con thay bo phím thì ok
    gmail: Doanhtruong_090
    Agribank STK:3503205057189
  1. Anh em xem dùm con 6085 bus check bị lỗi gì dùm em với
    By hunglangtu_qb in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 23-08-2013, 09:11
  2. Xin a/e check dùm con 3gs và tư vấn dùm e
    By keylove779 in forum iPHONE 3Gs
    Bài viết cuối: 03-08-2013, 11:47
  3. Anh em chỉ dùm hộp mt-box
    By trangvinh in forum MT-Box
    Trả lời: 27
    Bài viết cuối: 26-12-2012, 10:37
  4. mấy anh xem dùm em cái log N70 với
    By liencuongmobile in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 04-04-2010, 11:33
  5. Mấy anh xem dùm log n-gate qd dùm
    By minhkhoa_iphone in forum DCT4 - WD2
    Bài viết cuối: 14-12-2009, 14:42
