log chek
eBB5ProtocolType: OLD
Storage0: 00EC 2400 - 0000 8A31 [Samsung K5N2833ATB,512 Mbits] type: FLASH,NOR, asic:CMT
TransmissionMode: 16Bit
TransmissionMode: DDR&TX2
Selected firmware certificate matched.
Original Imei: 35431304979195
Original Product code: 0581057
Bluetooth ID: 303855C5A33E
SIMLOCK PA identifier:
[0] PA_SL3
Phone type: RM-561 (Nokia 2700 classic)
SW version: V 09.98 06-09-10 RM-561 (c) Nokia
Imei plain: 35431304979195-6
Product code: 0579808
Battery voltage: 4705 mV, current: 25 mA
Language Pack:
- not available.
Camera config: NIMMIIIIRRFF0A021001, ver: 002.007
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 354313049791956
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
log flas
Version from phone: 09.98
Version from file: 09.98
MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C08593E1
Using device: HTI, FW ver: 00.50, SN: 01010694
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.21719(09-05-2013), Library ver: 1.0.0.14397(09-05-2013)
Reading RPL backup ...
Reading Secure Storage ...
Reading Important data ...
Reading SIMLOCK data ...
Reading CERT data ...
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 22500109667151507BC0697F7AC7C776AAA89032
ASIC MODE ID: 00
ROM ID: 273F6D55DFAAF68F
Reading CMT HWC (0xD4 bytes).
Reading CMT R&D (0x0 bytes).
Flash Imei: 35431304979195
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
SIMLOCK_DATA saved OK
SIMLOCK_KEY_DATA saved OK
SUPERDONGLE_KEY_DATA saved OK
CMLA_KEY_DATA saved OK
WMDRM_PD_DATA saved OK
RF_DATA saved OK
WARRANTY_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
LOCK120_DATA saved OK
BB_DATA saved OK
RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35431304979195_BA CK.rpl"
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Processing MCU file: rm561__09.98.mcusw
[BB5,BB5 ALGORITHM] size: 19.41 MB
Erase size: 21 MB
CMT FLASH,NOR area [00000000-000006BF]
CMT FLASH,NOR area [000006C0-0001FFFF]
CMT FLASH,NOR area [00040000-000BFFFF]
CMT FLASH,NOR area [000C0000-0013FFFF]
CMT FLASH,NOR area [00140000-0137FFFF]
CMT FLASH,NOR area [01380000-0151FFFF]
erased in 1 min 19.454 s
Prog.status for Asic CMT ...
NOR: OK
Flash programming ...
CMT NOLO block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 3EA22A1D [RAP Certificate 202 v.1] sent
CMT UPDAPP block sent
CMT DSP0 block sent
CMT MCUSW block sent
NOR: OK
Programming completed in 1 min 5.016 s
Processing PPM file: rm561__09.98.ppm_v
[BB5,BB5 ALGORITHM] size: 6.90 MB
Erase size: 8.62 MB
CMT FLASH,NOR area [01520000-01DBFFFF]
erased in 29.860 s
NOR: OK
NOR: OK
Programming completed in 22.859 s
Processing CNT file: rm561__09.98.image_v_blac
[BB5,BB5 ALGORITHM] page size: 128 K size: 13.64 MB
Erase size: 34 MB
CMT FLASH,NOR area [01DC0000-0215FFFF]
CMT FLASH,NOR area [02160000-03FBFFFF]
erased in 2 min 27.047 s
NOR: OK
NOR: OK
Programming completed in 42.219 s
Total time for flashing process(boot+erase+write) was 6 min 32.453 s
Battery voltage: 4717 mV, current: 33 mA
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
hiện tại máy lắp sim trắng màn ko sim thì dùng ok. bác nào làm qua chỉ giúp
thask all
