đây là log MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C087FD0B
Using device: USB ROM and HTI, FW ver: 00.50, SN: 010106DE
Connection status: EHCI:HUB::USB 2.00 (High-speed)
Driver: NMWCD, ver: 7.1.32.115
Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012)
Processing MCU file: RM-356_60.0.003_prd.core.C00
[BB5,XSR 1.5] size: 110.45 MB
Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103
Waiting for USB ROM device ...
CMT SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15]
CMT EM0 ID: 00000296
CMT EM1 ID: 00000B22
CMT PUBLIC ID: 17A00119559A0052A4B09735AE509920ADD705E2
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371
CMT ROM ID: 4B9B75103E691FF8
Loading CMT secondary boot code
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.14.0 revision: 2.0 size: 0x3B80
Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0040 - 0000 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.5
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.14.0 revision: 2.0 size: 0x8798F
Update server code loaded.
FUR: Adding Asic CMT as client OK.
CERT backup skipped due to protocol limitation.
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning....
Partitioning complete
Erase size: 158.19 MB
CMT FLASH,MuxOneNAND area [00040000-00082FFF]
CMT FLASH,MuxOneNAND area [00083400-003FFFFF]
CMT FLASH,MuxOneNAND area [00400000-007FFFFF]
CMT FLASH,MuxOneNAND area [00800000-00D5FFFF]
CMT FLASH,MuxOneNAND area [00D60000-09E5FFFF]
Formating partition ...
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT PASUBTOC block sent
Selecting first CMT PAPUB block with matching RootKey.
CMT PAPUBKEYS: 76A20187 [RAP Certificate 106 v1] sent
CMT SOS*UPDAPP block sent
CMT SOS*ENO block sent
CMT SOS*DSP0 block sent
CMT SOS*ISASW block sent
CMT SOS+CORE block sent
CMT SOS+ROFS1 block sent
Programming completed in 1 min 45.125 s
Processing PPM file: RM-356_60.0.003_prd.rofs2.V20
[BB5,XSR 1.5] size: 17.96 MB
Erase size: 31.87 MB
CMT FLASH,MuxOneNAND area [07180000-0915FFFF]
CMT SOS+ROFS2 block sent
Programming completed in 17.750 s
Processing CNT file: RM-356_60.0.001_026_000_U01.uda.fpsx
[BB5,XSR 1.5] size: 7.09 MB
Erase size: 88.75 MB
CMT FLASH,MuxOneNAND area [09E60000-0F71FFFF]
Programming completed in 8.000 s
Total time for flashing process(boot+erase+write) was 2 min 20.532 s
Waiting for USB device removal ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2719918
cứ chạy đến đây là ngưng ko open dk
