Kết quả 1 tới 10 của 10
    Thành viên tích cực chuyenphamobile's Avatar
    Aug 2013
    Mặc định anh em giúp mình 5530 bật nguồn lên liên hệ nơi bán hàng
    card found: A1B5CCE8
    registered to: CycloneBox
    Connect phone on selected interface...
    Core : v1.51 , FlashEngine : v1.8
    Selected FlashSettings :
    Check FlashFiles, Please, wait...
    Files Set for Flashing :
    MCU : RM-504_40.0.003_prd.core.C00
    PPM : RM-504_40.0.003_prd.rofs2.V20
    CNT : RM-504_32.0.007_007_000_U001.uda.fpsx
    Flashing phone now...
    Check files done...
    -> SWversion check skipped : Dead mode selected
    Dead Mode is Selected
    Waiting for USB device...
    --- Press phone's power button or insert cable & charger! ---
    Connection opened successfully
    Waiting for communication response...
    BootRom : 1st boot ok
    ASIC ID: 000000010000022600010006400C192101051105
    CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB
    EM0 ID: 00000296
    EM1 ID: 00000B22
    PUBLIC ID: 048001087F8B0052F267EC742F69A181AF043345
    ASIC MODE ID: 00
    ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C
    ROM ID: 4B9B75103E691FF8
    PatchRAWLoader: Patched OK
    Processing RAWLOADER...
    Processing RAP3NAND ...
    Processing PASUBTOC ...
    Processing PAPUBKEYS...
    Processing UPDAPP ...
    Boot Done!
    TIME : Boot time : 00:00:03
    Reopening the connection...
    Waiting for response: 30
    Waiting for response: 29
    ADL -> [2nd] changing...
    ADL Server confirm flashmode!
    ADL : Auth done...
    ADL : ASIC CMT select Ok
    ===Flashing [MCU]===
    Erase : Processing RM-504_40.0.003_prd.core.C00
    Found 5 areas to erase
    Erasing area 0x00040000 - 0x00082FFF, NAND, CMT
    Result: 0000
    Erasing area 0x00083400 - 0x003FFFFF, NAND, CMT
    Result: 0000
    Erasing area 0x00400000 - 0x007FFFFF, NAND, CMT
    Result: 0000
    Erasing area 0x00800000 - 0x00D5FFFF, NAND, CMT
    Result: 0000
    Erasing area 0x00D60000 - 0x09E5FFFF, NAND, CMT
    Result: 0000
    Erase partition 0x0A
    Partition erase Ok
    Partitioning : Ok [5]
    TIME : Erase time : 00:00:00
    Write : Processing RM-504_40.0.003_prd.core.C00
    Total 444 [444/0/0] blocks to write, writing...
    CMT : Writing Hash CERT [ADA]
    CMT : Writing Hash CERT [KEYS]
    CMT : Writing Hash CERT [PRIMAPP]
    CMT : Writing Hash CERT [RAP3NAND]
    CMT : Writing Hash CERT [PASUBTOC]
    CMT : Writing Hash CERT [PAPUBKEYS]
    CMT : Writing Hash CERT [SOS*UPDAPP]
    CMT : Writing Hash CERT [SOS*ENO]
    CMT : Writing Hash CERT [SOS*DSP0]
    CMT : Writing Hash CERT [SOS*ISASW]
    CMT : Writing Hash CERT [SOS+CORE]
    CMT : Writing Hash CERT [SOS+ROFS1]
    TIME : Write time : 00:00:32
    MCU Write done
    ===Flashing [PPM]===
    Erase : Processing RM-504_40.0.003_prd.rofs2.V20
    Found 1 areas to erase
    Erasing area 0x07360000 - 0x0935FFFF, NAND, CMT
    Result: 0000
    Write : Processing RM-504_40.0.003_prd.rofs2.V20
    Total 74 [74/0/0] blocks to write, writing...
    CMT : Writing Hash CERT [SOS+ROFS2]
    TIME : Write time : 00:00:05
    PPM Write done
    ===Flashing [CNT]===
    Erase : Processing RM-504_32.0.007_007_000_U001.uda.fpsx
    Erasing area 0x09E60000 - 0x0F71FFFF, NAND, CMT
    Result: 0000
    Write : Processing RM-504_32.0.007_007_000_U001.uda.fpsx
    Total 25 [25/0/0] blocks to write, writing...
    TIME : Write time : 00:00:02
    CNT Write done
    ADL : End flashing
    ADL : Finalize...
    Flashing done!
    Total flash time : 00:00:40
    Reboot phone now...
    Reading Phone Info....
    Connected phone - Nokia 5530 XpressMusic
    Software Info: V ICPR72_10w29_tube1 24-05-11 RM-504 (c) Nokia
    IMEI: 359368033502210
    Ape Version: V 40.0.003
    Product code: 0578169
    Checking...
    SimLock status : SimLock Damaged!!!!!
    Security status : Security is Ok
    Read Info Done!
    Settings After Flash Defaults...
    ProductTuneSet...OK!
    SwUpgradeSet...OK!
    Resetting LifeTimer
    Reset Done!
    Battery voltage is enough for start
    Set phone to Normal mode...
    AfterFlash operations done ;D
    Done!
    Elapsed: 00:01:25
    PPM2 : RM-504_40.0.003_C06_prd.rofs3.fpsx
    Check files done...
    EM0 ID: 00000296
    EM1 ID: 00000B22
    ASIC MODE ID: 00
    Boot Done!
    ADL : Auth done...
    Result: 0000
    Result: 0000
    Result: 0000
    Result: 0000
    Result: 0000
    Partition erase Ok
    TIME : Write time : 00:00:33
    MCU Write done
    Result: 0000
    PPM Write done
    ===Flashing [PPM2]===
    Erase : Processing RM-504_40.0.003_C06_prd.rofs3.fpsx
    Erasing area 0x09360000 - 0x09E5FFFF, NAND, CMT
    Result: 0000
    Write : Processing RM-504_40.0.003_C06_prd.rofs3.fpsx
    Total 27 [27/0/0] blocks to write, writing...
    CMT : Writing Hash CERT [SOS+ROFS3]
    TIME : Write time : 00:00:01
    PPM Write done
    Result: 0000
    CNT Write done
    ADL : End flashing
    ADL : Finalize...
    Flashing done!
    Total flash time : 00:00:43
    Reboot phone now...
    Checking...
    Read Info Done!
    SwUpgradeSet...OK!
    Resetting LifeTimer
    Reset Done!
    Done!
    Elapsed: 00:01:16
    Aug 2013
    máy tự nhiên đang dùng không rơi hay va đập jh hết,anh e đi qua cho xin ý kiến
    Aug 2013
    lên đi anh e còn giúp huhu
    Thành viên chính thức minhthuyen_gsm's Avatar
    Mar 2013
    bỗ vô atf phang nó cái đi anh
    Aug 2013
    Phone found!
    Series 60 Device detected!
    read info... - Ok
    Software ver : V ICPR72_10w29_tube1 24-05-11 RM-504 (c) Nokia
    IMEI : 359368033502210
    Ape Ver : V 40.0.003
    APE Var : V 40.0.003V 40.0.003
    APE ADSP: 256
    DSP Ver : ICPR72_10w26p1
    APE Test: 09wk19v0.130
    PPM :
    CNT : v 30.0.001_001_000_U001 05-03-10 vanilla RM504
    Product SN : CCK162493
    Product code : 0578169
    Base Prd.code: 0573512
    Module code : 0204038
    Long Prod.SN : 0
    Hardware info=======
    HWID : 0802
    Retu : 16
    Tahvo : 22
    Batery: 3916 mV
    APE HW: 256
    Lock info ===========
    IMEI spNet : 3A 95 63 08 33 05 22 01
    IMEI svNet : 33 95 63 08 33 05 22 11 F9
    Unable to read Lock table...
    CRT308 Backup Created
    SDD key status : Ok
    CMLA Key status : Ok
    SimLock status : Damaged!!!!!
    Security status : Ok
    PA_SL3 phone , SP_CODE_LEN : 15
    User code : Crypted
    UserDataExLevel : Low [Gallery] , FullFlash method
    Done!
    Aug 2013
    bây h hiện tượng bật nguồn lên nokia tắt luôn huhu
    Thành viên tích cực quankom's Avatar
    Oct 2012
    mang qua box khác chiến thử đi bác.
    V.I.P duykhanh_gsm's Avatar
    Aug 2011
    khu đèn đỏ
    khò con flash cho nóng lên cái rồi flash lại coi sao
    box này nhìn k wen lắm . hình như mất simlock
    Aug 2013
    Trích Được post bởi duykhanh_gsm Xem bài viết
    mình cũng đang sợ mất simlock,nhưng chưa chắc chắn lắm,hỏi anh ae xem có phỉa không,mình chạy bằng Mt-box vs bets tool bạn ah,mình không có ATF để chiến,ae xem còn cách nào khác không giúp mình với
    Aug 2013
    lên đi ae còn giúp kiếm cơm nào
  1. Trả lời: 4
    Bài viết cuối: 20-05-2014, 17:53
  2. Trả lời: 10
    Bài viết cuối: 25-04-2013, 08:10
  3. Trả lời: 18
    Bài viết cuối: 29-10-2012, 10:40
  4. Nokia 5530 Báo Liên Hệ Cửa Hàng
    By hoangthanh8x in forum BB5
    Bài viết cuối: 28-08-2012, 10:41
  5. Trả lời: 3
    Bài viết cuối: 29-03-2012, 11:34
