Kết quả 1 tới 10 của 11
    Thành viên tích cực phamtrung's Avatar
    Mặc định n500 xin giúp
    minh vừa nhận con n500 chạy lại mình chạy phoenix rm-750 v111.20 báo ok mà giờ mở máy chỉ rung môt cái thôi.bác nao có file cao hơn cho em xin với.chay.bàng mx box thì nó ko thấy báo gì
    Thanh Trung.DT:0969906029
    D/c :yên bình.yahoo anhmai_yeuem5787
    đây là log em nó các bác xem hộ em cái
    Using device: USB ROM and HTI, FW ver: 00.50, SN: 01014DBC
    Connection status: EHCI:HUB::USB 2.00 (High-speed)
    Driver: NMWCD, ver: 7.1.32.75
    Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012)
    Waiting for USB ROM device ...
    CMT SYSTEM ASIC ID: 000000030000022600010007400C192103032108 [RAPUYAMA ver: 3.x]
    CMT EM0 ID: 00001040
    CMT EM1 ID: 00001060
    CMT PUBLIC ID: 04310000FFFB3C40B7F38BED0312E5BC7F2F4AE2
    CMT ASIC MODE ID: 00
    CMT ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706
    CMT ROM ID: 2CAC45E23BC33C8B
    Loading CMT secondary boot code
    SecondaryBoot: RAPUv21_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40
    Supported Ids: 0003192103002107, 000C192103002107, 0003192103012107, 000C192103012107, 000C192103022107, 0003192103022107, 400C192103022107, 4003192103022107, 000C192103032108, 0003192103032108, 400C192103032108, 4003192103032108, 0003192103042108, 000C192103042108
    eBB5ProtocolType: NEW
    Secondary boot loaded.
    Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
    Storage4: 00EC 0050 - 0000 0232 [Samsung ] type: FLASH,MuxOneNAND, asic:CMT
    Suggested algorithm: XSR 1.6
    Algorithm: RAPUv21_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66F5
    Update server code loaded.
    Waiting for USB device removal ...
    Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 3600C79
    FUR: Adding Asic CMT as client OK.
    CMT PAPUBKEYS HASH: F4C2F0A6BA76F178E59EBE710A8E1C85F3E122C0
    Original Imei: 35974404563641
    Original Product code: 059G7B5
    Bluetooth ID: 943AF05BE9C5
    SIMLOCK PA identifier:
    [0] PA_SIMLOC30
    Reading CMT NPC (0x190 bytes).
    Reading CMT CCC (0x1CC bytes).
    Reading CMT HWC (0xD4 bytes).
    Reading CMT R&D (0x0 bytes).
    Device connected: nmwcdc\Nokia 500 USB Phonet, PORT_ID: 1AA0312A
    Verifying communication to device OK.
    Phone type: RM-750 (Nokia N00)
    SW version: V 79u_sr1_12w20.1.2 30-07-12 RM-750 (c) Nokia
    ApeCoreSw: 111.021.0028
    Imei plain: 35974404563641-2
    Product code: 059G742
    Battery voltage: 3744 mV, current: 320 mA
    Language Pack:
    - not available.
    SIMLOCK seems to be valid
    CMLA_KEY seems to be valid
    WMDRM_PD seems to be valid
    SIMLOCK_TEST passed
    SECURITY_TEST passed
    Imei net: 359744045636412
    Version: SIMLOCK SERVER
    Counter: 0/3, 0/10
    CONFIG_DATA: 2440700000000000
    Market items is empty, please select the correct products path !
    có cao thu nào giúp em với
    Sóc Sơn - Hà Nội
    kiếm lấy cái file cùng code mà quất xem thế nào ?
    mình ko biet đa chọn mcu ppm đúng chua nữa chua chạy con này bao giờ các bác giúp em một tay chon mcu ppm cnt v..
    Thành viên tích cực hunggsm's Avatar
    bạn vào phonenix nhap code roi download file cao nhất về chạy xem nào.mà máy đó mới đầu ver của nó là bao nhiêu rồi
    Sóc Sơn - Hà Nội
    Trích Được post bởi phamtrung Xem bài viết
    hình như không biết code là j hay sao ý ? Phải ko ?
    code đao file không có v111.021 bác nào có cho em xin với
    Nov 2010
  10. ( toilatoi142001 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    phamtrung (06-10-2013)
  11. #10
    mình làm ok rồi
  1. nokia n500 liệt cảm ứng-xin giúp.
    By tychuot1980 in forum BB5
    Bài viết cuối: 09-08-2013, 09:13
  2. xin giúp N500 Imei 12345610654321-?
    By heotayxanh in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 13-07-2013, 13:30
  3. n500 cần giúp về phần mềm
    By duchanh0885 in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 14-07-2012, 15:14
  4. n500 cần giúp đỡ ?
    By rubybaby007 in forum BB5
    Bài viết cuối: 13-04-2012, 18:51
  5. máy MP4 N500 cần anh em chỉ giúp
    By trungnguyen0881 in forum Sửa chữa phần cứng
    Bài viết cuối: 15-04-2009, 08:55
