Kết quả 1 tới 4 của 4
    Thành viên chính thức vungtaumobifone's Avatar
    Mặc định 6300 cotes servert
    khởi động máy lên nokia rồi báo contetservet tắt máy luôn đã thay con retu mới vẫn ko dc
    ai gặp trường hợp trên chỉ dùm mình với
    BỆNH CUẢ MÁY NHƯ VÙNG SA MẠC!!!!
    KIẾN THỨC TA CHỈ LÀ HẠT CÁT...??????
    V.I.P ThanhHai_GSM's Avatar
    dùng box (mx, atf) info port cái log lên đây xem
    Thành viên tích cực TuanPhan_GSM's Avatar
    nhà
    trước tiên cứ fw rồi tính tiếp bạn ah
    cửa hàng :MT-SmartPhone số 9,Đ ích Thạnh,P Trường Thạnh-Q9
    nhận ép kính,cảm ứng, màn hình SDT:0124.345.1111
    card found: A1B5CCE8
    registered to: CycloneBox
    Connect phone on selected interface...
    Core : v1.51 , FlashEngine : v1.8
    Selected FlashSettings :
    Check FlashFiles, Please, wait...
    -> Flash Files are NOT selected!
    You can Select:
    S40 : Any, but MCU need present in filelist
    S60 : Any, but CORE/MCU need present in filelist
    S60 APE : MCU+PPM, MCU+PPM+CNT
    Selected FlashSettings : Manual
    Files Set for Flashing :
    MCU : rm217__07.30.mcusw
    PPM : rm217__07.30.ppm_r
    CNT : rm217__07.30.image_ctv_cn_black
    Flashing phone now...
    Check files done...
    -> SWversion check skipped : Dead mode selected
    Getting product info...
    Dead Mode is Selected
    Waiting for USB device...
    --- Press phone's power button or insert cable & charger! ---
    Connection opened successfully
    Waiting for communication response.
    ASIC ID: 000000010000022600010006010C192101001101
    CPU ID : RAP3Gv3 , Features : No any extended features
    RAP_PUB: 12B00003AB6A8C56736460319AFDDBF13D93C22A
    CMT_ROOT: BAF3A9C3DBFA8454937DB77F2B8852B1
    PatchRAWLoader: Patched OK
    Processing RAWLOADER...
    Processing UPDAPP...
    Processing PASUBTOC...
    TIME : Boot time : 00:00:00
    Reopening the connection...
    Waiting for response: 30
    Waiting for response: 29
    Waiting for response: 28
    Waiting for response: 27
    Waiting for response: 26
    Waiting for response: 25
    Waiting for response: 24
    ADL -> [2nd] changing...
    ADL Server confirm flashmode!
    ADL : Check data
    ADL : Data accepted
    ADL : ASIC CMT select Ok
    ===Flashing [MCU]===
    Erase : Processing rm217__07.30.mcusw
    Found 9 areas to erase
    Erasing area 0x00000000 - 0x000006BF, NOR, CMT
    Result: 0000
    Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT
    Result: 0000
    Erasing area 0x00020000 - 0x0007FFFF, NOR, CMT
    Result: 0000
    Erasing area 0x00080000 - 0x000DFFFF, NOR, CMT
    Result: 0000
    Erasing area 0x00100000 - 0x001FFFFF, NOR, CMT
    Result: 0000
    Erasing area 0x00200000 - 0x0031FFFF, NOR, CMT
    Result: 0000
    Erasing area 0x00320000 - 0x0105FFFF, NOR, CMT
    Result: 0000
    Erasing area 0x01060000 - 0x01067FFF, NOR, CMT
    Result: 0000
    Erasing area 0x01068000 - 0x0107FFFF, NOR, CMT
    Result: 0000
    TIME : Erase time : 00:00:43
    Write : Processing rm217__07.30.mcusw
    Total 944 [944/0/0] blocks to write, writing...
    CMT : Writing Hash CERT [NOLO]
    CMT : Writing Hash CERT [KEYS]
    CMT : Writing Hash CERT [PRIMAPP]
    CMT : Writing Hash CERT [PASUBTOC]
    CMT : Writing Hash CERT [PAPUBKEYS]
    CMT : Writing Hash CERT [UPDAPP]
    CMT : Writing Hash CERT [DSP0]
    CMT : Writing Hash CERT [MCUSW]
    CMT : Writing Hash CERT [PMM_CONF]
    CMT : Writing Hash CERT [SBIF_CONF]
    TIME : Write time : 00:01:25
    MCU Write done
    ===Flashing [PPM]===
    Erase : Processing rm217__07.30.ppm_r
    Found 1 areas to erase
    Erasing area 0x01080000 - 0x015FFFFF, NOR, CMT
    Result: 0000
    TIME : Erase time : 00:00:15
    Write : Processing rm217__07.30.ppm_r
    Total 329 [329/0/0] blocks to write, writing...
    TIME : Write time : 00:00:30
    PPM Write done
    ===Flashing [CNT]===
    Erase : Processing rm217__07.30.image_ctv_cn_black
    Erasing area 0x01600000 - 0x01FDFFFF, NOR, CMT
    Result: 0000
    TIME : Erase time : 00:00:05
    Checking content info...
    Resetting phone...
    Checking CNT sector PN<>FL
    PN CNT sector : 128 kb
    ConvertImage: Processing rm217__07.30.image_ctv_cn_black
    ConvertImage: Page Size is 64K, converting...
    ConvertImage: File converted
    Loader len: 248320, CHK: 36E3
    ADL -> Sending loader...
    Reset connection...
    ADL : Check data
    ADL : Data accepted
    Write : Processing rm217__07.30.image_ctv_cn_black_128
    Total 296 [296/0/0] blocks to write, writing...
    TIME : Write time : 00:00:25
    CNT Write done
    ADL : End flashing
    Flashing done!
    Total flash time : 00:03:24
    Reboot phone now...
    Reading Phone Info....
    Connected phone - Nokia 6300
    Software Info: V 07.30 07-05-09 RM-217 (c) Nokia.
    IMEI: 358288038927835
    PPM version : V 07.30 07-05-09 RM-217 (c) Nokia. R
    Product code: 0563812
    Checking...
    SimLock status : SimLock is Ok
    Security status : Security Damaged!!!!!
    Read Info Done!
    Settings After Flash Defaults...
    ProductTuneSet...OK!
    SwUpgradeSet...OK!
    Checking User Certificates...
    Total - 0 certs
    Uploading certificates...
    Writen 21 certs!
    Battery voltage is enough for start
    AfterFlash operations done ;D
    Done!
    Elapsed: 00:04:29
    Phone found!
    Series 40 Device detected!
    read info... - Ok
    Phone disconected!
    nhờ ae coi dùm
  1. Trả lời: 9
  2. Trả lời: 19
  3. Trả lời: 21
  4. 6300 đuôi sạc như 6300 xịn sạc tiếp xúc kém
    Trả lời: 21
