Kết quả 1 tới 4 của 4
    Thành viên chính thức Nam mobile's Avatar
    Mặc định c5_00 mất nguồn ae kiểm tra dùm
    DLL not found...
    BB5 Easy Service Tool v1.14.1 (c) Infinity-Box Team Ready
    Connect phone on selected interface...
    Selected FlashSettings : Manual
    Check FlashFiles, Please, wait...
    Files Set for Flashing :
    MCU : rm645_071.005_prd.core.fpsx
    PPM : rm645_071.005_16.01_Vietnam_prd.rofs2.fpsx
    PPM2 : rm645_071.005_C00.01_DEFAULT_prd.rofs3.fpsx
    CNT : rm645_071.005_U000.000_prd.uda.fpsx
    APE : RM645_ENO_10wk48v0.001.fpsx
    Flashing phone now...
    Check files done...
    -> SWversion check skipped : Dead mode selected
    Dead Mode is Selected
    Waiting for USB device...
    --- Insert cable and charger or press phone's power button! ---
    Connection opened successfully
    Waiting for communication response...
    [BB5 FLASH]: Bootrom Ok!
    ASIC ID: 000000030000022600010007600C192102031104
    EM0 ID: 00000C35
    EM1 ID: 00000C30
    PUBLIC ID: 25800019F9D80344DE5F86550E83C6C48FA2CDFE
    ASIC MODE ID: 00
    ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B
    ROM ID: E693EF0DAC22615B
    Use RAPUv11_2nd.fg Rev : 3.0 Ver : 12.2.0
    Processing RAWLOADER...
    FLIC : 00400020
    Req : XSR 1.6
    Use RAPUv11_XSR17_alg.fg Rev : 3.0 Ver : 12.2.0
    Boot Done!
    TIME : Boot time : 00:00:02
    Reopening the connection...
    Waiting for response: 30
    ADL: Check mode
    Select ASIC [C900]
    ADL: phone is in flash mode
    Backup enabled, will read all certificates...
    Reading NPC certificate...
    IMEI : 357409043134503
    Reading CCC certificate...
    Reading HWC certificate...
    Reading R&D certificate...
    Reading VARIANT certificate...
    Cert Read done!
    NPC Certificate saved...
    CCC Certificate saved...
    HWC Certificate saved...
    RPL saved : C:\Documents and Settings\Admin\Desktop\BEST infinity ****.VN HUNGPHUTHO\BEST infinity ****.VN HUNGPHUTHO\Backup\Cert\357409043134503_CRT_2nd.rpl
    ===Flashing [MCU]===
    Erase : Processing rm645_071.005_prd.core.fpsx
    Partitioning....
    Partitioning Ok...
    Erasing....
    Erasing Ok...
    TIME : Erase time : 00:00:01
    Write : Processing rm645_071.005_prd.core.fpsx
    CMT: Writing Hash CERT [ADA]
    Write CMT block error : 82106D00
    Write CMT failed on block 4
    Elapsed: 00:00:10
    Check files done...
    EM0 ID: 00000C35
    EM1 ID: 00000C30
    ASIC MODE ID: 00
    FLIC : 00400020
    Req : XSR 1.6
    Boot Done!
    ADL: Check mode
    Select ASIC [C900]
    Cert Read done!
    Partitioning....
    Partitioning Ok...
    Erasing....
    Erasing Ok...
    Elapsed: 00:00:12
    V.I.P Lão_Đại's Avatar
    hải phòng
    (CMT: Writing Hash CERT [ADA]
    Write CMT failed on block )
    Máy làm sao mất nguồn cho ít thông tin đi bạn
    Sóc Sơn - Hà Nội
    kiểm tra cặp xem có hở chân ko ?
    đã lắc lai rồi tình trạng vẫn vậy ,máy khách nói đang dùng thì bị vậy
  1. c5_00 lắp thẻ sim
    By TLmobi in forum BB5
    Bài viết cuối: 11-04-2013, 10:19
  2. xin giúp c5_00.chạy phần mềm không lên nguồn.
    By TRIEU_MAM_MOBILE in forum Phần mềm và các mã lệnh cho Nokia
    Trả lời: 19
    Bài viết cuối: 10-04-2013, 13:28
  3. c5_00 lắp thẻ sim
    Bài viết cuối: 02-02-2013, 10:19
  4. c5_00 rớt nước mất nguồn
    By 0905781785 in forum BB5
    Bài viết cuối: 03-12-2012, 20:26
  5. c5_00 không ăn míc
    By nguyen dai ll in forum BB5
    Bài viết cuối: 12-07-2012, 12:38
