Kết quả 1 tới 10 của 10
    Thành viên chính thức truongmobile147's Avatar
    Aug 2013
    Mặc định nokia 200 cấp cứu
    e dag nhận của khách 1 cây nokia200 chạy báo lỗi mong ah nào làm qua cứu e vs e thank
    PBL Successfully Sent...
    Sending SBL...
    SBL Successfully Sent...
    Setting Transmission Speed Done...
    Flash Chip Manufacturer: Intel Electronics Corp.
    Flash Boot Successful...
    Unique Data: 60D49197A40D9408
    Original Product Code: 059J4P5
    Reading : CCC... OK!
    Reading : HWC... OK!
    Reading : NPC... OK!
    RPL Backup was Successful...
    Plain RPL saved to:
    C:\AdvanceBox Turbo Flasher\Nokia\Backup\358259047716980\3582590477169 80_14840.rpl
    Data Sections : 04
    Current File : rm761__11.95.mcusw
    Compile Name: rm761__11.95.mcusw_ebl_psi.fls
    Image Type : Main Firmware
    Data Size : 26480008 Bytes
    Sending Certificate Block
    FIRMWARE Certificate Block Sent Successfully...
    Processing Section 01
    FIRMWARE Erase Block: 0x40000000~0x4001FFFE
    Start Erasing...
    Erasing Please Wait...
    Block Erase Done...
    Preparing Data Blocks...
    Data Size: 131072 bytes
    Data Checksum: C1BC
    Uploading Data Blocks to phone...
    Block Write Successful...
    FIRMWARE Data Blocks uploaded to phone...
    Processing Section 02
    FIRMWARE Erase Block: 0x40040000~0x4005FFFE
    Start Erasing...
    Block Erase Done...
    Data Checksum: 7A7A
    Processing Section 03
    FIRMWARE Erase Block: 0x40060000~0x4015FFFE
    Start Erasing...
    Block Erase Done...
    Data Size: 1048576 bytes
    Data Checksum: 9313
    Processing Section 04
    FIRMWARE Erase Block: 0x40280000~0x41A7FFFE
    Start Erasing...
    Block Erase Done...
    Data Size: 25165824 bytes
    Data Checksum: 769C
    Processing Section 05
    FIRMWARE Erase Block: 0x43E20000~0x43E5FFFE
    Start Erasing...
    Block Erase Done...
    Data Verification Successful...
    Data Sections : 01
    Current File : rm761__11.95.ppm_v
    Compile Name: package_v.ppm_ebl_psi.fls
    Image Type : PPM Image
    Data Size : 6706364 Bytes
    PPM Certificate Block Sent Successfully...
    PPM Erase Block: 0x41A80000~0x421BFFFE
    Start Erasing...
    Block Erase Done...
    Data Size: 6703020 bytes
    Data Checksum: 0CE6
    PPM Data Blocks uploaded to phone...
    Data Sections : 01
    Current File : rm761__11.95.image_v_059J514
    Compile Name: package_v_059J514.image.fls
    Image Type : CONTENT Package
    Data Size : 16518416 Bytes
    CONTENT Certificate Block Sent Successfully...
    CONTENT Erase Block: 0x421C0000~0x43E1FFFE
    Start Erasing...
    Block Erase Done...
    Data Size: 16515072 bytes
    Data Checksum: 611D
    CONTENT Data Blocks uploaded to phone...
    CONTENT Erase Block: 0x43E60000~0x43F3FFFE
    Start Erasing...
    Block Erase Done...
    Total Flashing Time (Erase + Flashing) : 00:06:03
    (Booting time is NOT Included)
    Waiting for Phone to Start-Up..(Max 150 seconds)
    WARNING: Phone is not in the Required Mode...
    Disconnect the Phone and Power it Up Manually.
    Scanning USB Ports...
    ERROR: Active Phone Handle was NOT DETECTED
    TIP: Make sure that Phone USB Connection Mode is
    OVI Suite Mode
    or
    PC Suite Mode
    Phone is not Connected OR it is not in the
    Required Mode...
    Reboot the Phone and Enable "PC Suite" Mode
    V.I.P duykhanh_gsm's Avatar
    Aug 2011
    khu đèn đỏ
    có box thì lấy ra quất lại .k thì thì phonix
    Aug 2013
    mong ae cho ý kiến giúp e vs
    Sóc Sơn - Hà Nội
    >>>>>>>>>> Lỗi ko tìm thấy Phone để đồng bộ !
  5. ( trongtan8909 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    truongmobile147 (07-10-2013)
    Aug 2013
    thanhk bác trong tan đã chỉ giáo e thêm
    Aug 2013
    đã ok = phoenix nhưng bỏ sim vô thì thấy hai thằng bắt tay nhau ko thấy thả ,còn ko bỏ sim thì bình thường các bác à
    Thành viên tích cực hoasimtim's Avatar
    HCM
    Máy ban đầu bị sao? Chắc phải làm cứng thôi bác.
    Call: 0933 208986
    (.)(.) + Silicon = ( . )( . )
  9. #8
    Thành viên chính thức bamien_mobile's Avatar
    Nov 2010
    thay 32kg bệnh truyền kiêp cữa N200
  10. #9
    Aug 2013
    e đã thay 32kg nhưng vẫn hok dc và e đã tra khách cho nó lành các bác ạ^_^
  11. #10
    Thành viên tích cực haikute1989th's Avatar
    Jan 2011
    thanh hóa
    cái đây bị upp ấy mà có làm báo khách 50/50
  1. Trả lời: 5
    Bài viết cuối: 27-08-2013, 08:32
  2. Trả lời: 5
    Bài viết cuối: 18-12-2012, 16:58
  3. Trả lời: 25
    Bài viết cuối: 27-01-2010, 16:24
  4. Trả lời: 3
    Bài viết cuối: 03-10-2008, 16:52
  5. 13-12-2007 Second BOMB! Nokia 1200 and Nokia 1208 Unlock released!
    By Hoang Thong Mobile in forum Multi - Box
    Bài viết cuối: 14-12-2007, 09:28
