Kết quả 1 tới 10 của 10
    Thành viên mới linhboyit's Avatar
    Mặc định e71 SECURITY_TEST : FAILED
    như tieu dề e co con e71 flash xong khong nen nguon...check bằ box nhu sau... Basic Phone Information
    MCU Version: V ICPR71_09w47.10 20-01-11 RM-346 (c) Nokia
    IMEI Plain : 356059037258304
    IMEI Spare : A356059037258300
    IMEI SV : 33560590372583064F
    Phone Model: Nokia E71
    Category : Smartphone
    Phone Type : RM-346
    Extended Phone Information
    Product Serial Number: MQK170730
    Product Code : 0561926
    Basic Production Code: 0567609
    Long Production SN : 0
    MCU SW Version : V ICPR71_09w47.10 20-01-11 RM-346 (c) Nokia
    HW Version : 0912
    RFIC Version : 17141715
    DSP Version : ICPR71_09w40
    AHNE Version : 11
    APE SW Core Version : 510.21.009
    Variant Version : 510.21.009510.21.009_v29
    APE Test Version : RM346ENO74110842.a36
    RETU Version : 16
    TAHVO Version : 22
    APE HW Version : 256
    APE ADSP SW Version : 256
    Wireless LAN ID : 9C:18:74:91:40:EA
    Bluetooth ID : 9C:18:74:90:E3:2A
    CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA VIII
    Simlock Information
    CONFIG KEY : 0000000000000000
    PROVIDER KEY : 2440700000000000
    NETWORK NAME : Nokia Default;Finland
    LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10
    SIMLOCK TABLE :
    Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
    SIMLOCK STATE : Not Locked
    SIMLOCK_TYPE : PA_SL2
    SIMLOCK_TEST : PASSED
    > Try SX4 "PM AUTH"
    > Then Write PM 1 and 309
    SECURITY_CODE : 12345
    PHONE_MODE : TEST
    DCC ID : NOT USED
    Selected VPL File:
    RM346_0561926_510.21.009_001.vpl
    Variant Details : RM-346 APAC-U VIETNAM WHITE STEEL
    Software Version : 510.21.009
    Product Type : RM-346
    Variant Version : 001
    anh e nào làm qua xin chỉ giúp...
    TP Hồ Chí Minh
    ở đây hướng dẫn quá rõ rồi nè
    Code:
    > Try SX4 "PM AUTH"
    Vào Tap PM write pm 1 & 309 là ok. Chúc thành công!
  3. ( TuệNguyễn ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    linhboyit (09-10-2013)
    SX4 Custom Keys Stand Alone Edition
    >>> : SX4 Auth Successfull
    Selected PM File: C:\AdvanceBox Turbo Flasher\Nokia\PM Files\SX4\RM-346.pm
    Start Uploading PM...
    Field : 1 Sub : 0 Byte(s): 114 - Ok
    Field : 1 Sub : 2 Byte(s): 98 - Ok
    Field : 1 Sub : 4 Byte(s): 110 - Ok
    Field : 1 Sub : 6 Byte(s): 98 - Ok
    Field : 1 Sub : 8 Byte(s): 110 - Ok
    Field : 1 Sub : 13 Byte(s): 98 - Ok
    Field : 1 Sub : 16 Byte(s): 98 - Ok
    Field : 1 Sub : 18 Byte(s): 98 - Ok
    Field : 1 Sub : 20 Byte(s): 98 - Ok
    Field : 1 Sub : 22 Byte(s): 16 - Ok
    Field : 1 Sub : 23 Byte(s): 4 - Ok
    Field : 1 Sub : 24 Byte(s): 84 - Ok
    Field : 1 Sub : 25 Byte(s): 4 - Ok
    Field : 1 Sub : 26 Byte(s): 110 - Ok
    Field : 1 Sub : 28 Byte(s): 98 - Ok
    Field : 1 Sub : 29 Byte(s): 10 - Ok
    Field : 1 Sub : 31 Byte(s): 98 - Ok
    Field : 1 Sub : 33 Byte(s): 36 - Ok
    Field : 1 Sub : 34 Byte(s): 80 - Ok
    Field : 1 Sub : 35 Byte(s): 16 - Ok
    Field : 1 Sub : 37 Byte(s): 4 - Ok
    Field : 1 Sub : 39 Byte(s): 36 - Ok
    Field : 1 Sub : 44 Byte(s): 182 - Ok
    Field : 1 Sub : 45 Byte(s): 182 - Ok
    Field : 309 Sub : 0 Byte(s): 4 - Ok
    Field : 309 Sub : 1 Byte(s): 2 - Ok
    Field : 309 Sub : 2 Byte(s): 12 - Ok
    Field : 309 Sub : 4 Byte(s): 12 - Ok
    Field : 309 Sub : 5 Byte(s): 12 - Ok
    Field : 309 Sub : 7 Byte(s): 12 - Ok
    Field : 309 Sub : 8 Byte(s): 12 - Ok
    Field : 309 Sub : 17 Byte(s): 12 - Ok
    Field : 309 Sub : 22 Byte(s): 12 - Ok
    PM Upload Done!...
    Phone Type : RM-346
    Failed to Initialize PM Area...
    ERROR: Failed to Update PM
    vang để e thử.. lai vậy.
    e thử roi nhưng vẫn không dược
    TP Hồ Chí Minh
    Trích Được post bởi linhboyit Xem bài viết
    đưa cái log write pm lên đây.
    hoặc liên hệ yh dưới chữ ký.
    V.I.P duykhanh_gsm's Avatar
    Aug 2011
    khu đèn đỏ
    sx4 mới pm 1-309 dc nhen
    not ok wire cái rpl chỉ lấy đoạn hwc & ccc rồi sx4 wire 1-309 lại
  9. ( duykhanh_gsm ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    Ku Nhỏ VF (09-10-2013)
  10. #8
    vẫn không được bác ơi... nản với e e71 nay wua'
  11. #9
    Aug 2011
    khu đèn đỏ
    lh chữ kí mod giúp vé đi
    or yh là nic xem coi thế nào
  12. ( duykhanh_gsm ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  13. #10
    Moderator nhotrung_bn's Avatar
    266-Phố Mới Thị TRấn Hồ-Thuận Thành-Bắc Ninh
    WIRL Pm song thì kích tiếp vào repair SD cho em nó thì mấy có hiệu quả
    NHOTRUNG_BN ADD: 266 Phố Mới-TTH-TT-BN
    Nhận unlock-Bẻ Khóa-Nạp Phần mềm
    Repair boot-unbrick all sam sung-sony-LG-HTC...
