Mình nhận của khách một em 206 bi khóa mả bảo vệ mò mẩn vài giờ đồng hồ không cách nào làm được.cuối cùng mình nhờ anh google dowload về một bảng BEST mới nhất về bus một phat ok. Chia sẽ cùng anh em.
Câu theo hình là ok.
card found: A1B5CCE8
registered to: CycloneBox
Connect phone on selected interface...
Phone found!
Series 40 Device detected!
read info... - Ok
Reading Phone Info....
Connected phone - 206
Software ver : V 03.59 24-12-12 RM-872 (c) Nokia
IMEI 1 : 354125057398064
IMEI 2 : 354125057398072
PPM : V 03.59 24-12-12 RM-872 (c) Nokia MH1
CNT : Content: mh1_059Q245 V 03.59 24-12-12 RM-872 (c) Nokia
Product SN : E1B2174AH
Product code : 059Q426
Base Prd.code: 059P6H2
Module code : 0205283
Long Prod.SN : 0
Hardware info=======
HWID : 1600
Batery: 3976 mV
CMT BT: 19b5-22012
LCDVer: TPO
Lock info ===========
IMEI : 354125057398064
IMEI spNet : 3A 45 21 05 75 93 08 06
IMEI svNet : 33 45 21 05 75 93 08 06 F6
Sl Conf : 001-01-00000000000
Sl Prof : 800000000004000-B
Sl Aux : 000B0000
Hw Sig : 833E9B451312F468
Country : Test SIM (Open)
Operator : NOKIA (Open)
Lock info:
Block 1
L1:Open; L2:Open; L3:Open; L4:Open; L5:Open;
Block 2
Block 3
Block 4
Block 5
Block 6
Block 7
CRT308 Backup Created
INFINEON : SuperDongle not exist (It is Ok)
CMLA Key status : Ok
SimLock status : Ok
Security status : Ok
PA_SL30 (20 digit) phone detected...
User Code : 66888
MMC pwd : no any record found
UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery]
Done!
Core : v1.51 , FlashEngine : v1.8
Selected FlashSettings : Manual
Check FlashFiles, Please, wait...
Files Set for Flashing :
MCU : rm872__03.58.mcusw
PPM : rm872__03.58.ppm_s3
CNT : rm872__03.58.image_s3_059Q477
Flashing phone now...
Check files done...
-> SWversion check skipped : Manual mode selected
Backup CRT308 data...
Check communication with phone....
ADL req restart
Communication verify done... Preparing...
SL3 Simlock read (XGOLD) ... ok
WMDRM Key read ... Ok
CMLA Key read ... Ok
Reboot....
Connection opened successfully
DBG : F00A1FB300020303010100FF
CPUID : XGOLD 213
2nd boot Ok, 01
2nd ready, AA
Sending Algo
Algo sent Ok
BL : Quantum_Bootloader_10.53_M1S1
Speed accepted, use 6.500.000
FLASHID : 89008289
FLIC conf set, RST set
Boot done!
Backup enabled, will read all certificates
Reading CCC
Reading HWC
Reading NPC
PCcode : «Ïq¿>†
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
SimLock Data saved...
SimLock Key saved...
WMDRM_PD Data saved...
CMLA_KEY Data saved...
RPL saved : C:\Documents and Settings\Khanmobile\Desktop\USB\InfinityBox_FREE_B EST_v1.62 By JONY-DIGITAL\Backup\Cert\354125057398064_35412505739807 2_XG213.rpl
===Flashing [MCU]===
File : rm872__03.58.mcusw
Image : rm872__03.58.mcusw_ebl_psi.fls
Cert block found, sending....
Cert sent
Found 5 region(s)
Processing Region 1/5
Erase , Start : 0x40000000 , Len : 0x00020000
Erasing, wait ...
Erase done, time : 00:00:00
Write , Start : 0x40000000 , Len : 0x00020000
Flashing , wait ...
Region flash done, time : 00:00:00
Processing Region 2/5
Erase , Start : 0x40040000 , Len : 0x00020000
Erasing, wait ...
Write , Start : 0x40040000 , Len : 0x00020000
Flashing , wait ...
Processing Region 3/5
Erase , Start : 0x40060000 , Len : 0x00100000
Erasing, wait ...
Erase done, time : 00:00:05
Write , Start : 0x40060000 , Len : 0x00100000
Flashing , wait ...
Region flash done, time : 00:00:01
Processing Region 4/5
Erase , Start : 0x40280000 , Len : 0x01800000
Erasing, wait ...
Erase done, time : 00:02:12
Write , Start : 0x40280000 , Len : 0x01800000
Flashing , wait ...
Region flash done, time : 00:00:33
Processing Region 5/5
Erase , Start : 0x43E20000 , Len : 0x00040000
Erasing, wait ...
No write data, skip
===Flashing [PPM]===
File : rm872__03.58.ppm_s3
Image : package_s3.ppm_ebl_psi.fls
Cert sent
Found 1 region(s)
Processing Region 1/1
Erase , Start : 0x41A80000 , Len : 0x00680000
Erasing, wait ...
Erase done, time : 00:00:27
Write , Start : 0x41A80000 , Len : 0x005F64F4
Flashing , wait ...
Region flash done, time : 00:00:07
===Flashing [CNT]===
File : rm872__03.58.image_s3_059Q477
Image : package_s3_059Q477.image.fls
Cert sent
Found 2 region(s)
Processing Region 1/2
Erase , Start : 0x42100000 , Len : 0x01D20000
Erasing, wait ...
Erase done, time : 00:03:19
Write , Start : 0x42100000 , Len : 0x00EE0000
Flashing , wait ...
Region flash done, time : 00:00:19
Processing Region 2/2
Erase , Start : 0x43E60000 , Len : 0x000E0000
Erasing, wait ...
No write data, skip
Flashing done!
Total flash time : 00:07:14
Reboot phone now...
Software Info: V 03.58 05-12-12 RM-872 (c) Nokia
IMEI: 354125057398064
PPM version : V 03.58 05-12-12 RM-872 (c) Nokia S3
Product code: 059Q426
Checking...
SimLock status : SimLock is Ok
Security status : Security is Ok
Read Info Done!
Checking User Certificates...
Total - 42 certs
Data exist, skip certificate repair...
Battery voltage is enough for start
AfterFlash operations done ;D
Done!
Elapsed: 00:07:48
Phone found!
read info... - Ok
Phone disconected!
