    Thành viên mới raikiter00's Avatar
    Aug 2010
    Mặc định 1202 giúp nạp wr pm
    Getting MCU ID
    MCU ID: 0x2293
    First 16 bytes: AD 7E B6 1A 23 10 03 40 C6 05 E4 01 20 A2 65 14
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 04.03
    29-06-09
    RH-112
    (c) Nokia
    HW version: 1005
    PCI version:
    UEM version: 1328
    UPP version: 8851
    RFIC version: 0700
    DSP version: ICPR81_09w22_U
    LCD version: WIN:SERI:90
    NT7542
    PPM version: V 04.03
    29-06-09
    RH-112
    (c) Nokia
    MR
    ADSP SW version: no NAI version
    Production serial number: DRW320999
    Product code: 0562324
    Module code: 0204036
    Basic production code: 0558505
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO:
    Default SN type:
    IMEI plain: 352677043598563
    IMEI spare to net: 3A 25 76 07 34 95 58 06
    IMEI SV to net: 33 25 76 07 34 95 58 16 F9
    Master Code: 7347064515
    Phone type: RH-112, Software version: 04.03, Language Pack: MR
    User code: ÿ#
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RH-112.ini
    Setting local mode...
    Reading product code...
    Product Code: 0562324
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-112\
    Checking path: \Products\RH-112\
    No ini files found...
    Done!
    Phone Type:
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-112\rh112_004.030
    Phone Type:
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-112\rh112_004.03mr
    Phone Type:
    Reading IMEI...
    Reading IMEI data...
    IMEI data corrupt...
    Failed to backup imei...
    MCU: C:\Program Files\Nokia\Phoenix\Products\RH-112\rh112_004.030
    Booting phone...
    MCU ID: 0x2293
    Boot size is 0x09A8
    Boot is ready...
    Flash ID is 0x28882000
    Loader size is 0x4B38; Loader chk: df
    Loader is ready...
    MSID: 845D4B08A0DECEB5130F63B7BF
    MSID decoded: 3E4EBAE900C91995A9000000
    FAID: 6175D36078C06D6CDCAF836D
    Erasing...
    Found 5 interval(s) to erase
    Operation took 1 minutes 20 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 0 minutes 15 seconds...
    Restarting MCU...
    PPM: C:\Program Files\Nokia\Phoenix\Products\RH-112\rh112_004.03mr
    Booting phone...
    MCU ID: 0x2293
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    MSID: 8451C5AB6487E49F6F3CB62302
    MSID decoded: 3E4EBAE900C91995A8000000
    FAID: 10422B20B78A1CE91AFF8B84
    Erasing PPM...
    Found 2 interval(s) to erase
    Operation took 0 minutes 26 seconds...
    Writing...
    Restarting MCU...
    Flashing Done!
    Operation took 2 minutes 41 seconds...
    After flash processing...
    Waiting for phone to boot...
    Failed! Aborting!
    Mình chạy xong. nạp wr pm nhưng nó lại không hiện file pm để nạp. mong AE chỉ giáo
    V.I.P Lão_Đại's Avatar
    hải phòng
    (Mình chạy xong. nạp wr pm nhưng nó lại không hiện file pm để nạp. mong AE chỉ giáo )
    ( After flash processing...
    Failed! Aborting!
    Flash đã DON đâu mà đòi wr PM
    Chạy thiếu file này ( CNT Flash ) nữa nè
    P/S máy bị sao mà phải wr PM vậy bạn
    Thành viên chính thức thuykieu90's Avatar
    Jul 2013
    log lỗi mà bạn .. chạy đủ 3 flle đi ..
    Aug 2010
    máy bị mất sóng với hay khởi động lại. ban à
    Aug 2010
    CPU: GenuineIntel, Sp: 5
    Platform: Windows NT 5.1 (Build 2600 Service Pack 2)
    Versions: Ufs2xx.dll 3.2.4, Ufs2xx.sys 2.8.14
    Executive Path:
    UFxBoot V2.2 (c) SarasSoft 2003. Id: 62 CF 1 10
    UFS_USB V2.8 (c) SarasSoft 2007. Sn: 106033
    HID: E3893E7641600050, HWK: A1.04-PRO1
    Features: 00000001
    Licence: True
    LogFile: .\_!_LOG\106033_10172013_101952_LOG.txt
    1st Boot: Ok, DCT4, UPP: 2293 [] [2.3.0.1]
    2nd Boot: u3_2nd.fia, Ver: 4.79.0
    Fl0: 0x01000000-0x013FFFFF,00208828,St M58MR032
    Algorithm: u3_st_i.fia, Ver: 4.79.0
    Rebooting Mobile
    ** User Break **
    1st Boot: Ok, DCT4, UPP: 2293 [Rh-112] [2.3.0.1]
    Algorithm Ok, MSID: 845D4B08A0DECEB5130F63B7BF
    Decoded MSID: 3E4EBAE9-00C91995-A9000000
    Encoded FAID: 6175D360-78C06D6C-DCAF836D
    IMAGE: rh112_004.030
    Area1: 0x01000000-0x0100FFFF Erased, Time: 00:01
    Area2: 0x01010000-0x013AFFFF Erased, Time: 01:10
    Area3: 0x013B0000-0x013EFFFF Erased, Time: 00:05
    Area4: 0x017C0000-0x017EFFFF Out of Chip Bounds
    Area5: 0x01FC0000-0x01FEFFFF Out of Chip Bounds
    MCU Flashing Completed, Time: 00:13
    IMAGE: rh1120_nai04.03mr
    Area1: 0x01380000-0x013AFFFF Erased, Time: 00:03
    CNT Flashing Completed, Time: 00:00
    Running: Server fake reply for CUI phone.
    Contents Package Extracting Ok, Time: 00:07
    Algorithm Ok, MSID: 8451C5AB6487E49F6F3CB62302
    Decoded MSID: 3E4EBAE9-00C91995-A8000000
    Encoded FAID: 10422B20-B78A1CE9-1AFF8B84
    IMAGE: rh112_004.03mr
    Area1: 0x01240000-0x0124FFFF Erased, Time: 00:01
    Area2: 0x01250000-0x0137FFFF Erased, Time: 00:23
    PPM Flashing Completed, Time: 00:07
    Flashing Completed, Rebooting Mobile
    Write PM Canceled
    Đả chạy đủ 3 file rồi nhưng vẫn nạp wr pm ko được
    Aug 2010
    sao ko ai giúp hết vậy
