    Thành viên mới hungnv85's Avatar
    Mặc định N70 flash OK mà không lên nguồn!
    Mình dùng UFS-3 và HWK magic v1.1 để bẻ khóa. Mình fash Ok 100% vậy mà vẫn không lên nguồn .
    Quá trình flash nè, các bạn giúp mình với nha,mình không có JAR:
    Thanks
    1st BOOT : C0,0C [Rm-84]
    OMAP ID : 17100701
    OMAP MODE : 00
    OMAP PBID : AFB9893D5B1D63373EF861FF8F5C7D6DB3F2CEB6
    OMAP HASH : 2C05369F57CC3C4CF9E783E83D9B512B
    OMAP ROID : AB5E4ADB27A06946
    RAPx ID : 000000010000022600010006000C192101002200
    EM 1 ID : 00000232
    EM 2 ID : 00000341
    RAPx PBID : 0C600119BCCB4F577348D536F9F9D8A9EA99484C
    RAPx MODE : 00
    RAPx HASH : E9EFF4BFAA5393217CA6B17755FC3E14
    RAPx ROID : F28A211FCEA7B19D
    CMT 1st Boot Ok
    CMT 2nd Bt: RAP3Gv2_2nd.fg, Ver: 1.14.7
    CMT FLID0 : 00EC22FA-00000011, Sam K8S6415ETA
    CMT FLCNT : 000000000000000000000000000000000000
    CMT 2nd Boot OK
    CMT ALGO : RAP3Gv3_algo_fps8.fg, Ver: 1.12.5
    CMT Alg Boot OK
    Using Internal VPP
    Erase Area: CMT 0x00000000-0052B515
    Erase Area: CMT 0x006A0000-006BFFFF
    Erase Area: CMT 0x006DF000-006EFFFF
    Erase Area: CMT 0x00700000-007EFFFF
    CMT FLASH ERASE OK, Time: 00:47
    CMT FLASH WRITE OK, Time: 00:30
    OMAP ID : 17100701
    OMAP MODE : 00
    EM 1 ID : 00000232
    EM 2 ID : 00000341
    RAPx MODE : 00
    CMT 1st Boot Ok
    CMT 2nd Boot OK
    CMT Alg Boot OK
    APE 2nd Bt: helen3_2nd.fg, Ver: 1.29.0
    APE FLID : 00EC0036-00A500C0, Sam KAL00R00EB
    APE REALG : OMAP1610 GBBM-1.8.1 ALG
    APE FLCNT : 010000020000000600000000000000000000
    APE 2nd BootOK
    APE ALG0 : h3_sam_nand_gbbm.fg, Ver: 1.30.0
    PUB SIG 1 : 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D
    APE Alg Boot OK
    Using Internal VPP
    Erase Area: APE 0x00000000-0000FFFF
    Erase Area: APE 0x00010000-0001FFFF
    Erase Area: APE 0x00020000-000203FF
    Erase Area: APE 0x00050000-03ECFFFF
    APE FLASH ERASE OK, Time: 00:06
    APE FLASH WRITE OK, Time: 02:17
    OMAP ID : 17100701
    OMAP MODE : 00
    EM 1 ID : 00000232
    EM 2 ID : 00000341
    RAPx MODE : 00
    CMT 1st Boot Ok
    CMT 2nd Boot OK
    CMT Alg Boot OK
    APE 2nd BootOK
    PUB SIG 0 : Erased
    APE Alg Boot OK
    Using Internal VPP
    Erase Area: APE 0x01AE0000-02AFFFFF
    Erase Area: APE 0x02B00000-03ECFFFF
    PPM FLASH ERASE OK, Time: 00:04
    PPM FLASH WRITE OK, Time: 01:07
    Flashing Completed, Rebooting Mobile
    Thành viên mới pham-thanh's Avatar
    Mar 2008
    khi dưa vào cấp nguồn thì kim ampe nhảy ra sao?
    Thành viên mới pinochio's Avatar
    Jun 2006
    trài ai (dùng UFS-3 và HWK magic v1.1) thì không lên là phải rồi,may mà không ngất luôn là tốt rùi đấy,mang qua JAF hoặc MTbox.... đi bạn ơi nhanh không có thành mô hình bây giờ
    Quê Lụa
    Bạn chạy thử với ver khác đi. nếu không đc thì mang qua box khác chạy lại
    Thành viên mới phuonglactanh's Avatar
    Mar 2008
    bạn chạy jaf là ok hà vì nó mạnh lắm chúc thành công nhé
    Thành viên tích cực Tri Khang Thinh's Avatar
    Jan 2007
    Kiếm ver cao hơn ver gốc chạy thì hy vọng lên nguồn.
    UFS thường chạy xong sẻ ko tự boot lên nguồn được -> chạy xong bạn phải bấm format 4 ngón xem có thể lên được nguồn đó. hồi nào giờ mình chạy N70 bằng UFSxBB5 crack thường là được hết đấy, thỉnh thỏang ko được phải cứu bằng box khác .
    Sevice For All Produce & All Model
    Hot Line: 0918 188 988
    Thành viên mới dzuychung_mobile's Avatar
    Apr 2007
    ufs làm sao mà chạy dc dòng này ha bạn bạn đưa wa mt hoặc jaf đi chạy 1 fát là ok liền ah
    V.I.P duclam882003's Avatar
    Jan 2007
    HoaLư_Ninh Bình
    HWK là ok giờ kiếm ver :RM-84_dp_v9.0_SW5.0705.3.0.1_APAC.exe thử nhé ?...
    TRUNG TÂM SỬA CHỮA & DẠY NGHỀ CHUYÊN NGHIỆP DUCHIEP MOBILE
    ĐT:0303.624.999*091.583.9989.Số TK:3308205007879-AGB NINH BINH
    Jan 2007
    HoaLư_Ninh Bình
    Trích Được post bởi hungnv85 Xem bài viết
    Thanks
    OMAP ID : 17100701
    OMAP MODE : 00
    EM 1 ID : 00000232
    EM 2 ID : 00000341
    RAPx MODE : 00
    CMT 1st Boot Ok
    CMT 2nd Boot OK
    CMT Alg Boot OK
    Using Internal VPP
    OMAP ID : 17100701
    OMAP MODE : 00
    EM 1 ID : 00000232
    EM 2 ID : 00000341
    RAPx MODE : 00
    CMT 1st Boot Ok
    CMT 2nd Boot OK
    CMT Alg Boot OK
    APE 2nd BootOK
    APE Alg Boot OK
    Using Internal VPP
    OMAP ID : 17100701
    OMAP MODE : 00
    EM 1 ID : 00000232
    EM 2 ID : 00000341
    RAPx MODE : 00
    CMT 1st Boot Ok
    CMT 2nd Boot OK
    CMT Alg Boot OK
    APE 2nd BootOK
    PUB SIG 0 : Erased
    APE Alg Boot OK
    Using Internal VPP
    HWK là ok giờ kiếm ver :RM-84_dp_v9.0_SW5.0705.3.0.1_APAC.exe thử nhé ?... mình đã chiến dòng này nhiều bằng HWK zin ok. cần file cứ PM nhé bạn ./.
  1. X2-00 Flash ok nhưng không lên nguồn
    By nobitamobile in forum BB5
    Bài viết cuối: 30-01-2016, 15:36
  2. Trả lời: 12
    Bài viết cuối: 10-07-2014, 17:53
  3. Trả lời: 1
    Bài viết cuối: 07-03-2014, 16:32
  4. E72 RM-530 flash done không lên nguồn!
    By tronghien207 in forum BB5
    Trả lời: 19
    Bài viết cuối: 11-01-2013, 18:23
  5. MX-key flash máy không lên nguồn
    By hieutrung in forum MX-KEY (by Alim Hape)
    Trả lời: 16
    Bài viết cuối: 04-05-2010, 21:10
