Kết quả 1 tới 10 của 12
    Thành viên chính thức huymai1103's Avatar
    Nghệ An
    Mặc định 3110C Bệnh phần mềm
    Log em nó như thế này, bác nào biết nó bị gì ạ, đã up ver chuẩn đến ver cao nhất mà vẫn không được
    MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN:
    Using device: HTI, FW ver: 00.50, SN:
    Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed)
    Driver: WinUSB, ver: 3.5.1.0
    Module ver: 1.0.0.21719(09-05-2013), Library ver: 1.0.0.14397(09-05-2013)
    CMT Data :
    SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAP3G ver: PA 1.x]
    EM0 ID: 00000232
    EM1 ID: 00000353
    PUBLIC ID: 14F0000D59317E56084C6524D4C3CF5B79AB9426
    ASIC MODE ID: 00
    ROM ID: 191EC665DFAAF68F
    eBB5ProtocolType: OLD
    Storage0: 0089 8981 - 0000 6A21 [Intel NU48F256,256 Mbits] type: FLASH,NOR, asic:CMT
    TransmissionMode: 16Bit
    TransmissionMode: DDR&TX2
    Original Imei: 35322503296595
    Original Product code: 0514949
    Bluetooth ID: 002545AA5DA2
    Không biết thì hỏi,không dấu dốt.
    Nghệ An
    Trích Được post bởi huymai1103 Xem bài viết
    CMT Data :
    EM0 ID: 00000232
    EM1 ID: 00000353
    ASIC MODE ID: 00
    Còn đây là Log flash em nó.
    Processing MCU file: rm237__07.30.mcusw
    [BB5,BB5 ALGORITHM] size: 14.49 MB
    Supported Ids: 0103192101001101, 010C192101001101
    CMT Data :
    EM0 ID: 00000232
    EM1 ID: 00000353
    ASIC MODE ID: 00
    Storing certificate [NPC, VARIANT, R&D] ...OK
    Erase size: 16.37 MB
    CMT FLASH,NOR area [00000000-000006BF]
    CMT FLASH,NOR area [000006C0-0001FFFF]
    CMT FLASH,NOR area [00020000-0007FFFF]
    CMT FLASH,NOR area [00080000-000DFFFF]
    CMT FLASH,NOR area [00100000-001FFFFF]
    CMT FLASH,NOR area [00200000-0031FFFF]
    CMT FLASH,NOR area [00320000-0105FFFF]
    CMT FLASH,NOR area [01060000-01067FFF]
    CMT FLASH,NOR area [01068000-0107FFFF]
    erased in 1 min 34.860 s
    Prog.status for Asic CMT ...
    NOR: OK
    Flash programming ...
    CMT NOLO block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT PASUBTOC block sent
    Selecting first CMT PAPUB block with matching RootKey.
    CMT PAPUBKEYS: C0E691EA [RAP Certificate 66 v2] sent
    CMT UPDAPP block sent
    CMT DSP0 block sent
    CMT MCUSW block sent
    CMT PMM_CONF block sent
    CMT SBIF_CONF block sent
    NOR: OK
    Programming completed in 51.500 s
    Processing PPM file: rm237__07.30.ppm_c
    [BB5,BB5 ALGORITHM] size: 4.35 MB
    CMT Data :
    EM0 ID: 00000232
    EM1 ID: 00000353
    ASIC MODE ID: 00
    CMT PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D
    Erase size: 4.62 MB
    CMT FLASH,NOR area [01080000-0151FFFF]
    erased in 26.954 s
    NOR: OK
    NOR: OK
    Programming completed in 12.703 s
    Processing CNT file: rm237__07.30.image_c_tr_128
    [BB5,BB5 ALGORITHM] page size: 64 K size: 3.75 MB
    NOR page size in the phone is 128 K.
    CMT Data :
    EM0 ID: 00000232
    EM1 ID: 00000353
    ASIC MODE ID: 00
    Erase size: 10.75 MB
    CMT FLASH,NOR area [01520000-01FDFFFF]
    erased in 45.188 s
    NOR: OK
    UCP page size is 128 K.
    NOR: OK
    Programming completed in 11.031 s
    Total time for flashing process(boot+erase+write) was 4 min 35.031 s
    Moderator thanhphuek's Avatar
    Feb 2010
    Eakar Đến PLeiku
    log chưa thấy biểu hiện lạ.Hiện giờ tình trạng máy sao bạn
    3110c thường hay bị mở nguồn lên sụp - contacsevic -hạn chế điện thoại - mất máy tính hay chủ đề- 3p tự tắt máy.hết
    ĐIỆN TỬ-ĐIỆN THOẠI THANH PHÚ
    tình trạng máy thế nào bạn cho ít thông tin
    gmail: Doanhtruong_090
    Agribank STK:3503205057189
    Thành viên kỳ cựu TẤN PHÚC's Avatar
    long an
    máy bị thế nào bạn ! cho ít thông tin để ae biết mà giúp
    ĐTDĐ TẤN PHÚC LONG AN hotline 0986.58.78.79
    AGRIBANK 6607205041502 - CN Tân Thạnh-Long An- CTK Trần Văn Niềm
    Chuyên Sữa: Điện Thoại ,Unlock. Chạy phần mềm, nạp Tiếng Việt
    Bắc Hòa-Tân Thạnh-Long An
    chủ thớt chạy mất rồi không thấy đâu cả
    ĐẤT TỔ ANH HÙNG
    V.I.P duykhanh_gsm's Avatar
    Aug 2011
    khu đèn đỏ
    Trích Được post bởi hiep dien thoai Xem bài viết
    vẫn thấy chủ thear đang xem bài ah
    máy chạy chưa đồng bộ dc [ nếu vẫn xài ok thì thôi kệ nó đi thear ]
    còn đang bị lỗi gì thì lock trên chưa xác định dc có thiết bị khác đổi qua chạy lại cái đi
    Mar 2012
    nam định
    có đồng bộ dk đâu..ăn may thì máy vẫn dùng bt nhưng dk 1 thời gian ngắn sẽ bị lại
    còn không thì mở nguồn lên logo rồi trắng sập
    kiểm tra lại cáp chỉnh lại bsi trên cáp và tốc độ chạy trên toll hoặc chuyển box or dùng dây usb xem sao
    HÃY HẾT LÒNG VÌ KHÁCH HÀNG
    Nghệ An
    Trích Được post bởi A & T Mobile Xem bài viết
    Chính xác, mình đã chạy 1 lần oy, Log vẫn như thế và vẫn xài bình thường,em nó bị đơ rồi giờ là cúp nguồn hẳn
    V.I.P Lão_Đại's Avatar
    hải phòng
    ( Chính xác, mình đã chạy 1 lần oy, Log vẫn như thế và vẫn xài bình thường,em nó bị đơ rồi giờ là cúp nguồn hẳn )
    Tìm ver thấp hơn đập vô not OK đập lại 7.30 là đồng bộ ngay ( Hạ thấp nhớ Downloagare nếu đồng bộ OK đỡ mất công chạy lại )
