Mình nhận con 1280 rớt đất mất nguồn kiểm tra màn hình còn tốt (test máy khác) trở khán vẩn còn đầy đủ, kẹp dòng có nhít nhít mih cho vào box chạy thử lúc đồng bộ thì báo the này
CPU: GenuineIntel, Sp: 5
Platform: Windows NT 6.1 (Build 7600 )
Versions: Ufs2xx.dll 3.2.4, Ufs2xx.sys 2.8.14
Executive Path:
C:\Program Files\Nokia\Phoenix
Warning, folder: C:\Wintesla\ not exist !
UFxBoot V2.2 (c) SarasSoft 2003. Id: 62 CF 1 10
UFS_USB V2.8 (c) SarasSoft 2007. Sn: 105354
HID: A649BF4D41600015, HWK: A1.04-PRO1
Features: 00000001
Licence: True
LogFile: .\_!_LOG\105354_10212013_50120_LOG.txt
If used non Auto-Ignition cable, press Power-On button
IF_SBL: XGOLD110, Ok
IF_EBL: Default_RAM_Bootloader 10.19, Mode: CC
BAUD_R: 921600
FL_ID : 2000C088, Numonyx M58WR064KU 64Mb
ShutDown Done
Rebooting Mobile
BAUD_R: 921600
MCU FLASH BUNDLE: rm647_004.200
Flash File: hw_b2_rm647_r04.200.fls
Erase Area: 0x00800000 - 0x00A0FFFE, Erased: 00:23
Write Area: 0x00800000 - 0x00A0FFFE, Written: 00:35
Erase Area: 0x00C60000 - 0x00EAFFFE, Erased: 00:26
Write Area: 0x00C60000 - 0x00E4A1FE, Written: 00:32
Erase Area: 0x00FFC000 - 0x00FFFFFE, Erased: 00:00
Write Area: 0x00FFC000 - 0x00FFC03E, Written: 00:00
PPM FLASH BUNDLE: rm647_004.20mr
Flash File: hw_b2_rm647_004.20mr.fls
Erase Area: 0x00210000 - 0x0045FFFE, Erased: 00:26
Write Area: 0x00210000 - 0x0032883E, Written: 00:19
CNT FLASH BUNDLE: rm6470_nai04.20mr
Flash File: hw_b2_rm6470_nai04.20mr.fls
Erase Area: 0x00EB0000 - 0x00F7FFFE, Erased: 00:09
Write Area: 0x00EB0000 - 0x00EFC5BE, Written: 00:05
Flashing Done: 03:12
ShutDown Done
UI Defaults Failed
Set UI Factory Defaults Failed
Set Full Factory Defaults Failed
AE xem dùm lỏi gì nhé sau lai toàn là failed vậy????????
cám ơn các bác trước nhé
