Code:
	Miracle Advance Android Tool V1.0 by Miracle Team www.miracleserver.com -------------------------------------------- Supports : All Android Devices  Supports conenction  Normal Mode     : Usb Debug Enabled or Recovery Mode   : Recovery Mode - you can read info and use even in recovery mode  -------------------------------------------- - One click Read full info      show all device information      Show su Binay Version     Show BusyBox Version - One Click Reboot :      Reocvery, Download     Boot-Loader,Turn off - One Click Wipe phone in adb mode - One Click Wipe phone in Fastboot mode     (all htc , chinese tabs etx) - One Click Crack pattern Lock  - One Click Read Pattern Lock  - One Click Remove Password Lock  - One Click Remove Gmail Lock  - One Click Read Gmail Id  - One Click Install Any Apk  - One Click Flash Zip file - One Click Remove pattern Lock  - One Click Get Memory Status - One Click Fix Permission - One Click Get adminstrators mode - One Click change Default Memory to    Sd or Internet ( No Root Needed ) - One Click Remove pattern Lock  - One Click Remove Battery Status - One Click Backup contacts   (sometimes Root Needed) only Android 4.x.x - One Click Backup Sms   (sometimes Root Needed) only Android 4.x.x - One Click Backup system apps    sometimes Root Needed) only Android 4.x.x - One Click Backup All Apps    sometimes Root Needed) only Android 4.x.x - One Click Restore Backup    sometimes Root Needed) only Android 4.x.x - One Click Remove Safe Mode    sometimes Root Needed) only Android 4.x.x - Key Tool ( Very useful when    toucscreen or buttons are damaged ) - Fastboot tools     one click Read full info     one click Reboot normal to fastboot mode    one click Reboot fastboot to normal mode    one click wipe device in fastboot mode    one click se/huawei bootloader unlocker by offical bootloader unlock code - Fastboot Flasher    one click Flash Boot image    one click Flash Splash Image    one click Flash Hboot Image    one click Flash Radio image    one click Flash Recovery image    one click Flash Zip file in fastboot mode - Erase Functions    one click Erase Boot     one click Erase Radio     one click Erase Boot     one click Erase all (Not erase Sdcard)
