tình hình là em nó rớt đất khi đang gọi điện (khách bảo thế), kẹp nguồn hoặc gắn pin bật nguồn sang đèn phím và màn hình (trắng) rồi tắt
1. thay màn hình khác vẫn vậy
2. lắc nhẹ U và Flash, ko thay đổi
3. chạy lại pm ok luôn, dưới đây là log em nó
card found: A1B5CCE8
registered to: CycloneBox
Connect phone on selected interface...
User INI update - Ok
Core : v1.51 , FlashEngine : v1.8
Selected FlashSettings : Manual
Check FlashFiles, Please, wait...
Files Set for Flashing :
MCU : rm607__06.15.mcusw
PPM : rm607__06.15.ppm_v
CNT : rm607__06.15.image_v_059B0Z3
Flashing phone now...
Check files done...
-> SWversion check skipped : Dead mode selected
Dead Mode is Selected
Waiting for USB device...
-> If Windows say "Unrecognized device" - just reinsert battery
-> If flashing freeze - reinsert cable and try again
--- Press phone's power button or insert charger! ---
Connection opened successfully
DBG : F00A1FB300020303010100FF
CPUID : XGOLD 213
2nd boot Ok, 01
2nd ready, AA
Sending Algo
Algo sent Ok
BL : Quantum_Bootloader_2.5_M1S1
Speed accepted, use 6.500.000
FLASHID : 89008289
FLIC conf set, RST set
Boot done!
Backup enabled, will read all certificates
Reading CCC
Reading HWC
Reading NPC
IMEI : 359040042006430
PCcode : 0596365
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
RPL saved : D:\Softwares\BOX\InfinityBox BEST v1.55\Backup\Cert\359040042006430_XG213_CRT.rpl
===Flashing [MCU]===
File : rm607__06.15.mcusw
Image : rm607__06.15.mcusw_ebl_psi.fls
Cert block found, sending....
Cert sent
Found 5 region(s)
Processing Region 1/5
Erase , Start : 0x40000000 , Len : 0x00020000
Erasing, wait ...
Erase done, time : 00:00:00
Write , Start : 0x40000000 , Len : 0x00020000
Flashing , wait ...
Region flash done, time : 00:00:00
Processing Region 2/5
Erase , Start : 0x40040000 , Len : 0x00040000
Erasing, wait ...
Erase done, time : 00:00:01
Write , Start : 0x40040000 , Len : 0x00040000
Flashing , wait ...
Processing Region 3/5
Erase , Start : 0x40080000 , Len : 0x00020000
Erasing, wait ...
Write , Start : 0x40080000 , Len : 0x00020000
Flashing , wait ...
Processing Region 4/5
Erase , Start : 0x400A0000 , Len : 0x00100000
Erasing, wait ...
Erase done, time : 00:00:04
Write , Start : 0x400A0000 , Len : 0x00100000
Flashing , wait ...
Region flash done, time : 00:00:01
Processing Region 5/5
Erase , Start : 0x40400000 , Len : 0x01800000
Erasing, wait ...
Erase done, time : 00:01:51
Write , Start : 0x40400000 , Len : 0x01780000
Flashing , wait ...
Region flash done, time : 00:00:32
===Flashing [PPM]===
File : rm607__06.15.ppm_v
Image : package_v.ppm_ebl_psi.fls
Cert sent
Found 1 region(s)
Processing Region 1/1
Erase , Start : 0x41C00000 , Len : 0x00600000
Erasing, wait ...
Erase done, time : 00:00:20
Write , Start : 0x41C00000 , Len : 0x00410D78
Flashing , wait ...
Region flash done, time : 00:00:04
===Flashing [CNT]===
File : rm607__06.15.image_v_059B0Z3
Image : package_v_059B0Z3.image.fls
Cert sent
Found 2 region(s)
Processing Region 1/2
Erase , Start : 0x42200000 , Len : 0x01C60000
Erasing, wait ...
Erase done, time : 00:03:03
Write , Start : 0x42200000 , Len : 0x00D40000
Flashing , wait ...
Region flash done, time : 00:00:16
Processing Region 2/2
Erase , Start : 0x43E60000 , Len : 0x000E0000
Erasing, wait ...
Erase done, time : 00:00:05
No write data, skip
Flashing done!
Total flash time : 00:06:23
Reboot phone now...
Reading Phone Info....
Connected phone - C1-01
Software Info: V 06.15 25-11-11 RM-607 (c) Nokia
IMEI: 359040042006430
PPM version : V 06.15 25-11-11 RM-607 (c) Nokia V
Product code: 0596365
Checking...
SimLock status : SimLock is Ok
Security status : Security is Ok
Read Info Done!
Settings After Flash Defaults...
ProductTuneSet...OK!
SwUpgradeSet...OK!
Checking User Certificates...
Total - 39 certs
Data exist, skip certificate repair...
Set phone to Normal mode...
AfterFlash operations done ;D
Done!
Elapsed: 00:08:07
Phone found!
Series 40 Device detected!
read info... - Ok
