máy bật nguồn lên một tý là tắt hoac dung tý là trăng treo
em đã chạy lại pm vẫn ko đc :
Using device: USB Phonet and HTI, FW ver: 00.50, SN: 01013903
Connection status: UHCI:HUB::USB 1.10 (Full-speed)
Driver: nmwcdnsuc, ver: 7.1.32.84
Module ver: 1.0.0.21719(09-05-2013), Library ver: 1.0.0.14397(09-05-2013)
Waiting for USB ROM device ...
Device synchronized.
CPU: XGOLD 213
Sending EBL Loader...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.37
EBL version: Quantum_Bootloader_10.37_M1S1
Protocol version suggested by phone: 3
Set baud rate to: 6.50 Mbit/s
Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits]
CFI information:
Flash settings: 0/1024, size: 0x04000000
1 Block regions:
512 x 0x00020000 = 0x04000000
EBL ready !
Original IMEI:
RPL saved to "C:\mobileEx\3.5\data\backup\XGOLD__back.RPL"
Processing file: rm827__03.33.mcusw
Downloading item CODE:rm827__03.33.mcusw_ebl_psi.fls, num block: 4, size: 26 MB
Erasing area 0x40000000-0x4001FFFE ...OK
Programming completed in 0.391 s
Erasing area 0x40040000-0x4005FFFE ...OK
Programming completed in 0.390 s
Erasing area 0x40060000-0x4015FFFE ...OK
Programming completed in 1.797 s
Erasing area 0x40280000-0x41B3FFFE ...OK
Programming completed in 35.109 s
Checksum verified (0xE581)
Processing file: rm827__03.33.ppm_s3
Downloading item CUSTackage_s3.ppm_ebl_psi.fls, num block: 1, size: 4.44 MB
Erasing area 0x41BC0000-0x4202F7E6 ...OK
Programming completed in 6.672 s
Checksum verified (0x0EBC)
Processing file: rm827__03.33.image_s3_059N2B3
Downloading item CUSTackage_s3_059N2B3.image.fls, num block: 1, size: 16.13 MB
Erasing area 0x421C0000-0x43E1FFFE ...OK
Programming completed in 25.375 s
Checksum verified (0x6479)
Total time for flashing process(boot+erase+write) was 8 min 5.109 s
Waiting for USB device removal ...OK
Waiting for USB device arrival ...
Phone not found, retrying ...
Warning: Phone did not reboot to normal mode.
Market items is empty, please select the correct products path !
không đông bộ đc
ATF thì chạy không qua file CNT
