       eMMC Test Point Connection Module
1. DO NOT USE THE PHONE"S BATTERY
2. Connect the Soldered TP Connections to ATF Box
3. Disconnect the USB Cable and Wait until the
   the ATF Software will tell you to Connect the USB.
Interface Reset OK!
eMMC Supported Voltage Range:
3.5-3.6V, 3.4-3.5V, 2.7-2.8V, 2.6-2.7V, 2.5-2.6V
2.4-2.5V, 2.3-2.4V, 2.2-2.3V, 2.1-2.2V, 2.0-2.1V
1.9-2.0V
CID : FE014E4D4D433136472770907BFA
CSD : D04F01320F5903FFFFFFFFFF8A400001
eMMC Boot Information
BOOT PARTITION    : USER AREA
PARTITION ACCESS  : R/W USER PARTITION
PERM_BOOT_CFG_PROT: DISABLED
PWR_BOOT_CFG_PROT : DISABLED
eMMC FirmW UPDATE : DISABLED
Lumia 900 Detected
eMMC Device Information
Manufacturer ID: FE
Device Type    : Embedded BGA
Application ID : 4E
Product Name   : MMC16G
Product Rev    : 2.7
Product SN     : 70907BFA
Manufactured   : January 2012
Card Specific Data
CSD_STRUCTURE     : Extended
SPEC_VERS         : Version 4.1/4.2/4.3
TAAC              : 300 ns
TRANS_SPEED       : 4000000 KHz
READ_BL_LEN       : 512 Bytes
C_SIZE            : HIGH CAPACITY
WP_GRP_ENABLE     : YES
WRITE_BL_LEN      : 512 Bytes
CONTENT_PROT_APP  : NO
PERM_WRITE_PROTECT: NO
TMP_WRITE_PROTECT : NO
Writing MBR...
Write Success!
Writing DBL...
Write Success!
Writing OSBL...
Write Success!
BOOT Images Written Successfully!
Total Elapsed Time 00:02:29
