ban đầu vào mạng không dc..em Version from phone: 07.20
Version from file: 07.20
MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C087451F
Using device: HTI, FW ver: 00.50, SN: 0101515C
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012)
RPL backup already exist (C:\mobileEx\3.5\data\backup\RPL\BB5_3548310281148 3_BACK.rpl).
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAP3G ver: PA 1.x]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 180002141BA97C5641C1D97DDCF8849BC549A653
ASIC MODE ID: 00
ROM ID: 191EC665DFAAF68F
eBB5ProtocolType: OLD
Storage0: 00EC 2208 - 0000 6921 [Samsung K8F5615ETM,256 Mbits] type: FLASH,NOR, asic:CMT
TransmissionMode: 16Bit
CMT PAPUBKEYS HASH: 7C1A1F5C3DB717937F54455937AF9DA76AA2EE13
TransmissionMode: DDR&TX2
Processing MCU file: rm146__07.20.mcusw
[BB5,BB5 ALGORITHM] size: 14.56 MB
Supported Ids: 0103192101001101, 010C192101001101
Storing certificate [NPC, VARIANT, R&D] ...OK
Erase size: 16.37 MB
CMT FLASH,NOR area [00000000-000006BF]
CMT FLASH,NOR area [000006C0-0001FFFF]
CMT FLASH,NOR area [00020000-0007FFFF]
CMT FLASH,NOR area [00080000-000DFFFF]
CMT FLASH,NOR area [00100000-001FFFFF]
CMT FLASH,NOR area [00200000-0031FFFF]
CMT FLASH,NOR area [00320000-0105FFFF]
CMT FLASH,NOR area [01060000-01067FFF]
CMT FLASH,NOR area [01068000-0107FFFF]
erased in 45.375 s
Prog.status for Asic CMT ...
NOR: OK
Flash programming ...
CMT NOLO block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 7C1A1F5C [Rap Certificate 30 v1] sent
CMT UPDAPP block sent
CMT DSP0 block sent
CMT MCUSW block sent
CMT PMM_CONF block sent
CMT SBIF_CONF block sent
NOR: OK
Programming completed in 1 min 22.391 s
Processing PPM file: rm146__07.20.ppm_v
[BB5,BB5 ALGORITHM] size: 5.25 MB
Erase size: 5.50 MB
CMT FLASH,NOR area [01080000-015FFFFF]
erased in 15.890 s
NOR: OK
NOR: OK
Programming completed in 32.453 s
Processing CNT file: rm146__07.20.image_v
[BB5,BB5 ALGORITHM] page size: 64 K size: 4.69 MB
Erase size: 9.87 MB
CMT FLASH,NOR area [01600000-01FDFFFF]
erased in 29.250 s
NOR: OK
NOR: OK
Programming completed in 26.907 s
Total time for flashing process(boot+erase+write) was 3 min 58.360 s
Phone type: RM-146 (Nokia 5300)
SW version: V 07.20 23-10-08 RM-146 (c) Nokia.
Imei plain: 35483102811483-3
Product code: 0551185
Battery voltage: 4664 mV, current: 45 mA
Language Pack:
- not available.
SLPA ver[1]: PA_SL (15 digit NCK)
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 354831028114833
Version: SIMLOCK SERVER VERSION 63
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
song chạy lại máy báo như vậy
