Kết quả 1 tới 4 của 4
    Super Moderator Tempb's Avatar
    Feb 2008
    TP.HCM
    Mặc định Unlock I8190 / I8190N / I8190L / I8190T Galaxy S3 Mini bằng Z3x
    noel buồn lang thang qua tây chơi thấy vụ này hay mang về chia sẽ cùng ae
    How to Root I8190 / I8190N / I8190L / I8190T Galaxy S3 Mini -
    STEP BY STEP rooting manual for GSM-Hosting users
    I have some good news today.
    Official recovery files from CWD i found.
    What we have?
    Simple, now we hav easy and fast way for root any I8190 L, I, T, N Galaxy S3 Mini.
    Just Follow Manual now.
    1. Step
    - Download Samsung USB drivers ----> Click HERE
    - Download ODIN 3.04 from ----> Click HERE
    - Download recovery-clockwork-touch-6.0.2.7-golden.tar.md5.zip recovery image from here ------> Click HERE!
    - Download SuperSu Last version ----> Click HERE
    2. Step
    - Turn off phone, then switch to download mode:
    press together [volume down]+[home button]+[power button] (all at once),
    press [volume up] for comfirm download mode.
    - Connect usb cable, install drivers.
    3. Step
    - Run Odin 3.04, ticked 2 option F.reset times+auto reboot,
    - Extract ecovery-clockwork-touch-6.0.2.7-golden.tar.md5.zip !Select PDA and browse to where you have extracted ecovery-clockwork-touch-6.0.2.7-golden.tar.md5
    and select it
    4. Step
    - Odin should show device under 1 of ID:COM port.(if this not happends repeat from STEP 2)
    - Press START.
    - Phone should power on after flashing complete.
    5. Step - ROOTING:
    - Copy Downloaded SUperSU to externel sdcard (NOT INTERNAL ! )
    - Power off your phone, after press [Vol up] + [Power] + [Home button] (all at once)
    - Select Install zip from sdcard --->choose zip from sdcard ---> scroll to and open folder where located UPDATE-SuperSU-v1.05.zip-> choise UPDATE-SuperSU-v1.05.zip->
    comfirm - YES - Install Update UPDATE-SuperSU-v1.05.zip.
    Done ! And you are ready to go
    thanks goes to chotu.
    You can also use old method for root i8190 - prerooted firmware.
    After few days i will update thread and will add link for prerooted Firmware.
    i8190 prerooted - will be HERE.
    Stock Firmware thread for I8190 ---> Here!
    nguồn : gsmhosting
    CTY TNHH TM-DV SAIGON MOBILE
  2. ( Tempb ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    tuanwawezx (24-12-2013)
    nnm
    nnm vẫn chưa có mặt trong diễn đàn
    Administrator nnm's Avatar
    Oct 2005
    freelancer
    Lạy hồn . Tưởng Free unlock .
    Cty TNHH Công nghệ FYMC - WWW.FYMC.COM.VN
    TK Vietcombank : 0181003368567 - Nguyễn Như Mạnh
    WWW.A-ZGSM.COM
    WWW.VIETFIRMWARE.COM
    Call - Zalo : 0934121179
    Feb 2008
    TP.HCM
    Trích Được post bởi nnm Xem bài viết
    lạ đời. đầy đủ thiết bị trong tay mà vẫn cần free là sao ta?
    nnm
    Oct 2005
    freelancer
    Cái quan trọng là nhìn cái tiêu đề ko ghi bởi thiết bị nào ===> nghĩ là free .
    UL = BOX gì thì ghi box đó và post đúng chỗ .
    Vào xem bài xong phải edit tiêu đề và move vào đúng Z3x cho dễ hiểu
    WWW.A-ZGSM.COM
