VBATT Powering Down <<<<
VBATT Powering Up >>>>
SET VCCIO Level Done
SET BSI Load Done
Booting Phone...
CPU ID Response: A200341100
CPU Type: XG110 2.1B
Phone Booted at after First attempt...
TIME STARTS HERE
Sending PBL 19456 bytes...
PBL Successfully Sent...
Sending SBL 65024 bytes...
SBL Successfully Sent...
Flash Chip Manufacturer ID: 0x00EF
Flash Chip Type: 64 Mbit (4Mb x 16) NOR
Extended Information: Multi-Bank / 1.8v
Processing Image File: D:\fle nokia\RM-908\RM-908\rm908_003.100
Checking Flash Image...
Number of Sections: 03
IMAGE Certificate Block Sent Successfully...
Processing Section 01 of 03
IMAGE Erase Block: 0x00800000~0x00A0FFFE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Preparing Data Blocks...
Data Size: 2162688 bytes
Data Checksum: 0551
Uploading Data Blocks to phone...
IMAGE Data Blocks uploaded to phone...
Processing Section 02 of 03
IMAGE Erase Block: 0x00C60000~0x00E8123E
Start Erasing...
Block Erase Done...
Data Size: 2232896 bytes
Data Checksum: 89F6
Processing Section 03 of 03
IMAGE Erase Block: 0x00FFC000~0x00FFC03E
Start Erasing...
Block Erase Done...
Data Size: 64 bytes
Data Checksum: 0000
Start Data Verification... (Please wait)
Data Verification Successful...
Processing Image File: D:\fle nokia\RM-908\RM-908\rm908_003.10ec
Number of Sections: 01
Processing Section 01 of 01
IMAGE Erase Block: 0x00210000~0x0039A33E
Start Erasing...
Block Erase Done...
Data Size: 1614656 bytes
Data Checksum: 6B15
Processing Image File: D:\fle nokia\RM-908\RM-908\rm9080_nai03.10ec
IMAGE Erase Block: 0x00EB0000~0x00F161BE
Start Erasing...
Block Erase Done...
Data Size: 418240 bytes
Data Checksum: 7E6F
Exit Flash Mode Done...
Time Elapse : 00:01:55
You must Factory Reset the phone to enable the
ringtones and other customized settings to work
Waiting For Phone to go Online...
5, 4, 3, 2, 1...
MCU: V 03.10 29-05-13 RM-908 (c) Nokia
IMEI: 359589057613860
Product Serial Number: 0AD4927AU
Product Code : 059R4C7
Module Code : 0205453
Basic Production Code: 059T865
PPM SW Version : V 03.10 29-05-13 RM-908 (c) Nokia EC
ADSP Version : p V 03.10\n29-05-13\nRM-908\n(c) NMP\nec
MCU SW Version : V 03.10 29-05-13 RM-908 (c) Nokia
HW Version : 3000
UEM Version : 1328
UPP Version : 8850
LCD Version : WIN:BEIHAIv82 ILI9163C
********** SIMLOCK INFO **********
CONFIG_DATA : 0010100000000000
PROFILE_BITS : 0000000000040002
ASIC : 11
PROVIDER : Default Test Operator
Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
ST_LCD_TEST : PASSED
FACTORY SET TO : Full Factory Set
OK
FACTORY SET TO : User Data
OK
FACTORY SET TO : Leave Factory
OK
FACTORY SET TO : Service Center
OK
FACTORY SET TO : Software Upgrade
OK
FACTORY SET TO : Production Tune
OK
			 105 -RM 908 TIẾNG VIỆT  ok bằng ATF
 Được post bởi THIÊN UY_GSM
