Octoplus/Octopus Box LG Software v1.4.2 Release Notes
- Added support for the following models:- F320K - added world's first Direct Unlock, Repair IMEI, Repair Security, Repair Wi-Fi MAC Address,
- F320K - Repair BT Address, Write Security Backup, Read/Write/Repair NVM, Root Device, Read Full Flash (Dump NAND),
- F320K - Reset Screen Lock (including Reset Password, Pin, Pattern, Face, Google locks) (thanks to Mr. ..:::MAMi:::..).
- F320L - added world's first Direct Unlock, Repair IMEI, Repair Security, Repair Wi-Fi MAC Address,
- F320L - Repair BT Address, Write Security Backup, Read/Write/Repair NVM, Root Device, Read Full Flash (Dump NAND),
- F320L - Reset Screen Lock (including Reset Password, Pin, Pattern, Face, Google locks) (all operations in Test Mode).
- F320S - added world's first Direct Unlock, Repair IMEI, Repair Security, Repair Wi-Fi MAC Address,
- F320S - Repair BT Address, Write Security Backup, Read/Write/Repair NVM, Root Device, Read Full Flash (Dump NAND),
- F320S - Reset Screen Lock (including Reset Password, Pin, Pattern, Face, Google locks) (all operations in Test Mode).
- D800, D800P, D801, D801BK, D801WH, D801Z, D802, D802T, D802TR, D803, D805, D806 - added Read Full Flash (Dump NAND),
improved Direct Unlock, Repair IMEI, Repair BT, Repair Wi-Fi MAC Address, Write Security Backup, Repair Security (it is not necessary
to root the device, not necessary to enable "USB Debugging" Mode! From now, all operations are executed through Normal Mode!).
- L-06C, V900, V909, V909DW, V909DWDU - improved Unlock and Repair operations; with this update you can repair device
with any firmware from Support Area, it is not necessary to re-flash the device after repairing!
- All supported operations are described in details in Software manuals ("Cable & Manual" button in the software).
More info and discussion are HERE
			 Octoplus/Octopus Box LG Software v1.4.2 & Samsung v1.4.5 released!
