    Jan 2012
    đất tổ vua Hùng
    Mặc định E52 không lên nguồn cần giúp
    khách nói cắm tai nghe vào bị mất nguồn mình kẹp nguồn có giao động đẹp,flash ok nhưng bật nguồn chỉ rung.nhờ ae gặp qua chỉ giúp.thank all
    Cửa hàng Trang Lâm Hi-Tech sn 10-tổ 10-Mã Thượng A-Phù Ninh-Phú Thọ (đối diện khách sạn Giấy Bãi Bằng)
    Fb : Trang Lâm Hi-Tech
    ĐT : 0868.81.82.82 - 0943.25.12.86
    Jan 2012
    đất tổ vua Hùng
    Help.log flash bằng phoenix
    Flashing started
    Creating product data items list
    Product data items list created
    Backup not required
    Flashing phone
    Initializing
    Scanning image files...
    Waiting for USB device...
    Loading secondary boot code: 15168 bytes
    Secondary boot loaded
    BB Asic Index is: 00
    Asic ID is: 000000030000022600010007600C192102011104
    EM Asic ID is: 00000C34
    EM Asic ID is: 00000C30
    Public ID is: 0C500203C8600344D7723CDCBEE6A89E55950868
    Asic Mode ID: 00
    Hash: 25B977A055BE9B5DEC0C38A2A279C695
    ROM ID: 3E273BF637BE26FA
    Device type is: 05
    Device Index is: 00
    Manufacturer code: 0000
    Device ID: 0000
    Extended device ID: 0000
    Revision ID: 0000
    Device type is: 04
    Device Index is: 00
    Manufacturer code: FFFF
    Device ID: 0000
    Revision ID: 0000
    Device type is: 00
    Device Index is: 00
    Manufacturer code: 0020
    Device ID: 0040
    Revision ID: 0031
    Device type is: 00
    Device Index is: 01
    Device ID: 0001
    Revision ID: 0000
    Device type is: 03
    Device Index is: 00
    Device ID: 0040
    Revision ID: 0031
    Loading update server code: 868592 bytes
    Update server loaded
    Asic CMT: Start programming 160331 KB...
    Asic CMT: Programming data sent: 0%
    Asic CMT: Programming data sent: 10%
    Asic CMT: Programming data sent: 20%
    Asic CMT: Programming data sent: 30%
    Asic CMT: Programming data sent: 40%
    Asic CMT: Programming data sent: 50%
    Asic CMT: Programming data sent: 60%
    Asic CMT: Programming data sent: 70%
    Asic CMT: Programming data sent: 80%
    Asic CMT: Programming data sent: 90%
    Asic CMT: Programming data sent: 100%
    Programming complete
    Asic CMT: Verifying communication to device...
    Waiting for communication response: 25
    Waiting for communication response: 24
    Waiting for communication response: 23
    Waiting for communication response: 22
    Waiting for communication response: 21
    Waiting for communication response: 20
    Waiting for communication response: 19
    Waiting for communication response: 18
    Waiting for communication response: 17
    Waiting for communication response: 16
    Waiting for communication response: 15
    Waiting for communication response: 14
    Waiting for communication response: 13
    Waiting for communication response: 12
    Waiting for communication response: 11
    Waiting for communication response: 10
    Waiting for communication response: 9
    Waiting for communication response: 8
    Waiting for communication response: 7
    Waiting for communication response: 6
    Waiting for communication response: 5
    Waiting for communication response: 4
    Waiting for communication response: 3
    Error 0x8401F121 communicating to phone. Unable to verify comm.
    Warning: Unable to communicate to product after flashing
    Starting to recover the phone
    Recovering phone
    Initializing
    Phone recovery completed. Waiting for phone to boot up
    Bootup successful
    Verifying communication to product (before flash finalizing)
    Failed to verfy communication to product
    All operations completed
    Firmware updating failed.
    Jan 2012
    đất tổ vua Hùng
    flash bằng besttool thì ok nhưng vẫn vậy
    Jan 2012
    đất tổ vua Hùng
    log flash bằng besttool
    card found: A1B5CCE8
    registered to: CycloneBox
    Connect phone on selected interface...
    Core : v1.51 , FlashEngine : v1.8
    Selected FlashSettings : FullFlash
    Check FlashFiles, Please, wait...
    Files Set for Flashing :
    MCU : rm469_091.003_prd.core.fpsx
    PPM : rm469_091.003_17.01_Vietnam_prd.rofs2.fpsx
    PPM2 : rm469_091.003_C00.01_DEFAULT_prd.rofs3.fpsx
    CNT : rm469_091.003_U006.000_prd.uda.fpsx
    APE : RM469_APE_ONLY_ENO_09wk23v0.091.fpsx
    Flashing phone now...
    Check files done...
    -> SWversion check skipped : Dead mode selected
    Dead Mode is Selected
    --- Insert cable and charger or press phone's power button! ---
    Connection opened successfully
    Waiting for communication response...
    BootRom : 1st boot ok
    ASIC ID: 000000030000022600010007600C192102011104
    CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB
    EM0 ID: 00000C34
    EM1 ID: 00000C30
    PUBLIC ID: 0C500203C8600344D7723CDCBEE6A89E55950868
    ASIC MODE ID: 00
    ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695
    Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0
    Processing RAWLOADER...
    FLIC : 00400020
    Req : XSR 1.6
    Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0
    Processing PASUBTOC ...
    Processing ALG ...
    Boot Done!
    TIME : Boot time : 00:00:02
    Reopening the connection...
    Waiting for response: 30
    ADL: Check mode
    Select ASIC [C900]
    PAPUBkeys : 85F252E351E225CAFC4DFBC8041EABD2823E3500
    ADL: phone is in flash mode
    Backup enabled, will read all certificates...
    Reading NPC certificate...
    IMEI : 355216032078126
    Reading CCC certificate...
    Reading HWC certificate...
    Reading R&D certificate...
    Reading VARIANT certificate...
    Reading PARTNERC certificate...
    Reading MDM_KEYS certificate...
    Cert Read done!
    NPC Certificate saved...
    CCC Certificate saved...
    HWC Certificate saved...
    RPL saved : C:\Users\TRANGL~1\AppData\Local\Temp\Rar$EX98.040\ Backup\Cert\355216032078126_CRT.rpl
    ===Flashing [MCU]===
    Erase : Processing rm469_091.003_prd.core.fpsx
    Partitioning....
    Partitioning Ok...
    Erasing....
    Erasing Ok...
    TIME : Erase time : 00:00:00
    Write : Processing rm469_091.003_prd.core.fpsx
    CMT: Writing Hash CERT [ADA]
    CMT: Writing Hash CERT [KEYS]
    CMT: Writing Hash CERT [PRIMAPP]
    CMT: Writing Hash CERT [RAP3NAND]
    CMT: Writing Hash CERT [SOS+PMML]
    CMT: Writing Hash CERT [PASUBTOC]
    CMT: Writing Hash CERT [PAPUBKEYS]
    CMT: Writing Hash CERT [GENIO_INIT]
    CMT: Writing Hash CERT [SOS*UPDAPP]
    CMT: Writing Hash CERT [SOS*DSP0]
    CMT: Writing Hash CERT [LDSP]
    CMT: Writing Hash CERT [SOS*ISASW]
    CMT: Writing Hash CERT [SOS+CORE]
    CMT: Writing Hash CERT [SOS+ROFS1]
    Total writen 440 blocks
    TIME : Write time : 00:00:27
    MCU Write done
    ADL: Request programm status
    NAND status : 00000002 / 00000002 / 00000000
    ===Flashing [PPM]===
    Erase : Processing rm469_091.003_17.01_Vietnam_prd.rofs2.fpsx
    Erasing....
    Erasing Ok...
    Write : Processing rm469_091.003_17.01_Vietnam_prd.rofs2.fpsx
    CMT: Writing Hash CERT [SOS+ROFS2]
    Total writen 120 blocks
    TIME : Write time : 00:00:07
    PPM Write done
    ===Flashing [PPM2]===
    Erase : Processing rm469_091.003_C00.01_DEFAULT_prd.rofs3.fpsx
    Erasing....
    Erasing Ok...
    Write : Processing rm469_091.003_C00.01_DEFAULT_prd.rofs3.fpsx
    CMT: Writing Hash CERT [SOS+ROFS3]
    Total writen 35 blocks
    TIME : Write time : 00:00:02
    PPM Write done
    ===Flashing [CNT]===
    Erase : Processing rm469_091.003_U006.000_prd.uda.fpsx
    Erasing....
    Erasing Ok...
    Write : Processing rm469_091.003_U006.000_prd.uda.fpsx
    Total writen 50 blocks
    TIME : Write time : 00:00:03
    CNT Write done
    ===Flashing [APE]===
    Erase : Processing RM469_APE_ONLY_ENO_09wk23v0.091.fpsx
    Erasing....
    Erasing Ok...
    Write : Processing RM469_APE_ONLY_ENO_09wk23v0.091.fpsx
    CMT: Writing Hash CERT [SOS*ENO]
    Total writen 12 blocks
    TIME : Write time : 00:00:00
    APE Write done
    ADL: Close_Session
    Content: 000300000000020000000200000000
    ADL: Reboot
    Flashing done!
    Total flash time : 00:00:43
    Reboot phone now...
    - > AfterFlash Failed! Reason : Downgrade try or HW Error
    Anyway - try reinsert battery and PowerUp phone manualy
    Done!
    Elapsed: 00:02:38
    Jan 2012
    đất tổ vua Hùng
    phát hiện ra lỗi
    nó là gì ae nhỉ?ai có kinh nghiệm chỉ giáo giúp
    Thành viên tích cực toican's Avatar
    Jun 2011
    sóc sơn hà nội
    lỗi cặp rồi
    quangkhuong_ss@yahoo.com + wwwkhuong@gmail.com
  7. ( toican ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    trang lam (18-01-2014)
    Jan 2012
    đất tổ vua Hùng
    Trích Được post bởi toican Xem bài viết
    lỗi cặp rồi
    cũng đang nghĩ lỗi cặp.dòng này main yếu nên cũng ớn
