Kết quả 1 tới 10 của 10
    Thành viên mới hugomobile's Avatar
    Mặc định Flash Asha 301 ok voi best tool
    Đầu tiên cài Pc suite va driver Nokia_connectivity_cable_driver.exe
    xong tải file flash về chạy như bình thường
    Log flash
    Core : v1.78 , BB5XG FlashEngine : v8.0
    Selected FlashSettings : Manual
    Check FlashFiles, Please, wait...
    Files Set for Flashing :
    MCU : rm839__02.33.mcusw
    PPM : rm839__02.33.ppm_s3
    CNT : rm839__02.33.image_s3_059S177
    Flashing phone now...
    Rules accepted for : XGOLD Generation
    Check files done...
    -> SWversion check skipped : Dead mode selected
    Dead Mode is Selected
    Waiting for USB device...
    -> If Windows say "Unrecognized device" / Operation not start
    -> Or if Phone start charge - just reinsert battery
    -> If flashing freeze - reinsert cable/battery and try again
    --- Press phone's power button or insert usb cable! ---
    Connection opened successfully
    IF Boot Init : 0xF0
    IF Resp Len : 0x16
    IF xCPUID : XGOLD 618 [XMM6180 QUARK]
    IF uCHIPID : 401C02A14920C035
    IF Resp Data : 50A9070100030101E0001409
    Wait for user action : Insert battery
    Sending EBL Loader ...
    EBL Loader Ok
    EBL Loader ready
    Sending EBL ...
    EBL sent Ok
    EBL : QUARK_1315.400_M1S1
    QUARK EEP config Ok
    FLASHID : 20004000 , [ MuxOneNAND ]
    Boot conf set, Target Ready
    Boot done!
    Backup enabled, will read all certificates
    Reading CCC
    Reading HWC
    Reading NPC
    IMEI 1 : 355516051417943
    IMEI 2 : 355516051417950
    NPC Certificate saved...
    CCC Certificate saved...
    HWC Certificate saved...
    RPL saved : C:\InfinityBox\BEST\Backup\Cert\355516051417943_CR T_2nd.rpl
    ===Flashing [MCU]===
    Processing file : rm839__02.33.mcusw
    Region count : 8
    00 : psi_flash_unsigned.fls
    01 : slb_signed.fls
    02 : main_toc_signed.fls
    03 : rm839__02.33.mcusw_signed_mcusw.fls
    04 : swap_signed.fls
    05 : dynsw.fls
    06 : aeneas_signed.fls
    07 : fota_signed.fls
    Parse done , flashing now
    Processing image : 00 : psi_flash_unsigned.fls
    Sending Sec-Pack
    SecInfo Area : 0x0000 , SecInfo Len : 0x0800
    Erase area 0x00 , Start 0x00090000 , Len : 0x00020000
    Erase now...
    Erase done
    Load region psi_flash_unsigned.fls
    Region Start : 0x00090000 , Data Len : 0x00010FB0
    Region Load done
    psi_flash_unsigned.fls image flash done
    Processing image : 01 : slb_signed.fls
    Sending Sec-Pack
    SecInfo Area : 0x0001 , SecInfo Len : 0x0800
    Erase area 0x00 , Start 0x60000000 , Len : 0x00040000
    Erase now...
    Erase done
    Load region slb_signed.fls
    Region Start : 0x60000000 , Data Len : 0x00040000
    Region Load done
    slb_signed.fls image flash done
    Processing image : 02 : main_toc_signed.fls
    Sending Sec-Pack
    SecInfo Area : 0x0002 , SecInfo Len : 0x0800
    Erase area 0x00 , Start 0x60040000 , Len : 0x00000400
    Erase now...
    Erase done
    Load region main_toc_signed.fls
    Region Start : 0x60040000 , Data Len : 0x00000400
    Region Load done
    main_toc_signed.fls image flash done
    Processing image : 03 : rm839__02.33.mcusw_signed_mcusw.fls
    Sending Sec-Pack
    SecInfo Area : 0x0003 , SecInfo Len : 0x0800
    Erase area 0x00 , Start 0x62E00000 , Len : 0x01100000
    Erase now...
    Erase done
    Erase area 0x01 , Start 0xFFF00000 , Len : 0x00080000
    Erase now...
    Erase done
    Load region rm839__02.33.mcusw_signed_mcusw.fls
    Region Start : 0x62E00000 , Data Len : 0x00F05210
    Region Load done
    rm839__02.33.mcusw_signed_mcusw.fls image flash done
    Processing image : 04 : swap_signed.fls
    Sending Sec-Pack
    SecInfo Area : 0x0004 , SecInfo Len : 0x0800
    Erase area 0x00 , Start 0x80000000 , Len : 0x00F00000
    Erase now...
    Erase done
    Load region swap_signed.fls
    Region Start : 0x80000000 , Data Len : 0x00C1B3CC
    Region Load done
    swap_signed.fls image flash done
    Processing image : 05 : dynsw.fls
    Sending Sec-Pack
    SecInfo Area : 0x0005 , SecInfo Len : 0x0800
    Erase area 0x00 , Start 0x62080000 , Len : 0x00100000
    Erase now...
    Erase done
    Load region dynsw.fls
    Region Start : 0x62080000 , Data Len : 0x00044000
    Region Load done
    dynsw.fls image flash done
    Processing image : 06 : aeneas_signed.fls
    Sending Sec-Pack
    SecInfo Area : 0x0006 , SecInfo Len : 0x0800
    Erase area 0x00 , Start 0x63F79C00 , Len : 0x00080000
    Erase now...
    Erase done
    Load region aeneas_signed.fls
    Region Start : 0x63F79C00 , Data Len : 0x00046870
    Region Load done
    aeneas_signed.fls image flash done
    Processing image : 07 : fota_signed.fls
    Sending Sec-Pack
    SecInfo Area : 0x0007 , SecInfo Len : 0x0800
    Erase area 0x00 , Start 0x61F00004 , Len : 0x0017FFFC
    Erase now...
    Erase done
    Load region fota_signed.fls
    Region Start : 0x61F00004 , Data Len : 0x00145478
    Region Load done
    fota_signed.fls image flash done
    ===Flashing [PPM]===
    Processing file : rm839__02.33.ppm_s3
    Region count : 1
    00 : package_s3.ppm_ebl_psi.fls
    Processing image : 00 : package_s3.ppm_ebl_psi.fls
    Sending Sec-Pack
    Erase area 0x00 , Start 0x80F00000 , Len : 0x00B00000
    Erase now...
    Erase done
    Load region package_s3.ppm_ebl_psi.fls
    Region Start : 0x80F00000 , Data Len : 0x0073E7C4
    Region Load done
    package_s3.ppm_ebl_psi.fls image flash done
    ===Flashing [CNT]===
    Processing file : rm839__02.33.image_s3_059S177
    Region count : 1
    00 : package_s3_059S177.image.fls
    Processing image : 00 : package_s3_059S177.image.fls
    Sending Sec-Pack
    Erase area 0x00 , Start 0xA1000000 , Len : 0x0C580000
    Erase now...
    Erase done
    Erase area 0x01 , Start 0xAE000000 , Len : 0x00300000
    Erase now...
    Erase done
    Load region package_s3_059S177.image.fls
    Region Start : 0xA1000000 , Data Len : 0x017DDA00
    Region Load done
    package_s3_059S177.image.fls image flash done
    Flashing done!
    Total flash time : 00:00:11
    Reboot phone now...
    Reading Phone Info....
    Connected phone - Nokia 301 Dual SIM
    Software Info: V 02.33 17-05-13 RM-839 (c) Nokia
    IMEI: 355516051417943
    PPM version : V 02.33 17-05-13 RM-839 (c) Nokia S3
    Product code: 059Q9D5
    Wait, when phone will be ready ...
    Checking...
    SimLock status : SimLock is Ok
    Security status : Security is Ok
    Read Info Done!
    Checking User Certificates...
    Total - 58 certs
    Data exist, skip certificate repair...
    Battery voltage is enough for start
    AfterFlash operations done ;D
    Done!
    Connect phone on selected interface...
    Elapsed: 00:00:51
    Phone found!
    Series 40 Device detected!
    read info... - Ok
  2. ( hugomobile ) đã được 2 thành viên cám ơn vì bài viết hữu ích!
    leminhhieuctvn (22-05-2019), truong_gsm (03-03-2014)
