Kết quả 1 tới 4 của 4
    Thành viên mới NTH_mobile's Avatar
    Nov 2013
    Mặc định nokia 1616 rh-125 imel ?
    SET VCCIO Level Done
    SET BSI Load Done
    Booting Phone...
    CPU ID Response: A200341100
    CPU Type: XG110 2.1B
    Phone Booted at after First attempt...
    START INFINEON BUS CHECK
    Sending PBL 37888 bytes...
    PBL Successfully Sent...
    Sending SBL 65024 bytes...
    SBL Successfully Sent...
    Flash Chip Manufacturer: STMicroelectronics
    Flash Chip Type: M58WR064 64 Mbit (4Mb x 16) NOR
    Extended Information: Multiple Bank / Burst / 1.8v
    INFINEON BUS CHECK DONE
    MCU: V 06.20 01-12-10 RH-125 (c) Nokia
    IMEI: ????????0000000
    PPM SW Version : V 06.20 01-12-10 RH-125 (c) Nokia MR
    ADSP Version : p V 06.20\n01-12-10\nRH-125\n(c) NMP\nmr
    MCU SW Version : V 06.20 01-12-10 RH-125 (c) Nokia
    UEM Version : 1328
    UPP Version : 8850
    LCD Version : INNO:BOHAIv93 NT39121
    ********** SIMLOCK INFO **********
    CONFIG_DATA : 0000000000000000
    PROFILE_BITS : 0000000000030000
    ASIC : 11
    PROVIDER : Unknown Provider
    Unable to read SP Data..
    ST_LCD_TEST : PASSED
    Make sure you have installed the
    COMPLETE Flash Package for this Phone...
    Goto "Settings" --> "Nokia Settings" and verify that
    the Folder where you installed your Flash Files are
    in the "PRODUCT PATH TO SCAN" List...
    V.I.P duykhanh_gsm's Avatar
    Aug 2011
    khu đèn đỏ
    dòng inerfon như sl3 - thay cặp thôi
  3. ( duykhanh_gsm ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    NTH_mobile (18-02-2014)
    Nov 2013
    thank vip.dòng này xài chung cặp voi dòng nào vậy a
    Aug 2011
    khu đèn đỏ
    1280 đóng qua ok đã tes mấy cặp khác thì chưa tes
