    Moderator VanTuan-ST's Avatar
    Sóc Trăng
    Mặc định xdaAutoTool ver 4.0.3 ALL-Win
    NOTES:
    there*s no need for a how-to and full doc in this beta
    all auto apk tool and auto deodex tool applies here
    adb functionality is in progress
    still a lot of room for improvement
    REQUESTS:
    If you happen to have an idea, please post and make a clear description or screenshot of what you want to happen or do
    TO DO:
    add more options in the settings menu
    catch errors and better handling errors
    add more tabs for custom commands
    PLANS:
    my looking forward is to be able to create custom scripts and run with the tool
    also to be able to put many jar files by just adding it in settings and run custom commands for that jar
    that way it will automate whatever manual things users do in their customization of apks, rom zip, lang pack, etc
    IMPORTANT:
    ALL THE DEPENDENCIES LIKE OCX WILL PROMPT ERROR if not in your machine
    YOU MAY NOT HAVE THESE OCX YET SO I INCLUDED IT IN THE Res folder
    STEPS on FIRST RUN ONLY
    1) Go to /Res/
    2) Run FileRegister.exe to register these ocx files
    If you are using latest w7 it may probably be registering in the wrong path so register manually.
    INSTALL:
    Place the folder where there is no space yet
    C:\xdaAutoTool
    I havent handled white space yet
    - Tested on Windows 7 workstation, it should run in XP as well
    - All ocx and posibble dll references and dependecies will be in your machine if you are close to W7 X64 and had installed ms vb runtime in the past
    - All the dependency file list are inside the docs folder (docs/xdaAutoTool.xml)
    - This means i used mainly files in your Windows 7 system to run it without installation
    - Installer will come later or when issues with running is that massive
    TẠM DỊCH & SỬ DỤNG :
    1* LOAD TOOL VỀ GIẢI NÉN
    2* VÀO FOLDER xdaAutoTool_V4.0.3\Res
    3* NHẤP VÀO FILE AAA_register_ocx.bat
    HIỆN RA GÌ CỨ BẤM OK - OK (3-4 LẦN,ĐỂ COPY FILE VÀO SYSTEM32)
    XONG BƯỚC NÀY TẮT TOOL
    4* LOAD FILE apktool 2.0.9.rar VỀ GIẢI NÉN,COPY VÀO xdaAutoTool_V4.0.3\bin
    5* BẬT TOOL VÀO SETTING PHÍA TRÊN CHỌN APK TOOL
    Ô PHÍA TRÊN TRỎ ĐẾN FILE apktool_2.0.9.jar
    CHUYỂN QUA TAB DEO TOOL
    Ô TRÊN TRỎ ĐẾN FILE smali-2.0.3.jar
    Ô DƯỚI TRỎ ĐẾN FILE baksmali-2.0.3.jar
    SAVE LẠI ĐÓNG TOOL BẬT LẠI & SỬ DỤNG
    CHÚC MỌI NGƯỜI VUI VẺ
    LINK DOWNLOAD :
    TOOL xdaAutoTool ver 4.0.3
    apktool 2.0.9.rar
    Nguồn:sưu tầm!
  2. ( VanTuan-ST ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    manhdung81mobile (29-03-2014)
    Moderator Thuyết Vũ's Avatar
    Gia lai
    ai thích việt hóa bằng tay thì tải cái này về! rút APK tốt hơn
    Iphone Shop Thu Vân-sửa chữa apple Chuyên Nghiệp
    507 Nguyễn Huệ Núi Sập Thoại Sơn An Giang.YM: phong_vugl mobile: 0974444438
    Tài Khoản Vietcombank Gia Lai chủ tài khoản : Vũ Tiến Thuyết 0291002263263
    Sóc Trăng
    Video demo auto convert tv android
    [youtube]41hwAFHA2Ug[/youtube]
  5. ( VanTuan-ST ) đã được 3 thành viên cám ơn vì bài viết hữu ích!
    manhdung81mobile (29-03-2014), nanibk (29-03-2014), ThinhPhat_GSM (29-03-2014)
    Thành viên chính thức nanibk's Avatar
    Anh cho em xin tool chép apk vào máy lun đi
    Gia lai
    cái này quất Tool của anh Thành Lập thích hơn! nhanh gợn lẹ đơn giản auto 90% công việc!
  8. #6
    Thành viên chính thức hoanghiepmobile84's Avatar
    Jan 2014
    Trích Được post bởi Thuyết Vũ Xem bài viết
    bác cho em cái line đao tool đấy về và cho em cái hướng dẫn nhé
  9. #7
    Jan 2014
    tool này khó làm quá
  10. #8
    Thành viên chính thức nguyenhuan0388's Avatar
    Mar 2011
    Trích Được post bởi hoanghiepmobile84 Xem bài viết
    tool của thành lập hiện tại chưa fée phải mua bản quyền có nhu cầu lh thanhlapvn hoặc Cung cấp Tool việt hóa Android tự động và hướng dẫn Việt Hóa. | Cộng Đồng GSM Việt Nam-Đồng Hành-Hỗ trợ-Thành Công
  11. #9
    nnm
    nnm vẫn chưa có mặt trong diễn đàn
    Administrator nnm's Avatar
    Oct 2005
    freelancer
    Mình việt hóa bằng tay có hơi chậm chút cũng ko sao
    Cty TNHH Công nghệ FYMC - WWW.FYMC.COM.VN
    TK Vietcombank : 0181003368567 - Nguyễn Như Mạnh
    WWW.A-ZGSM.COM
    WWW.VIETFIRMWARE.COM
    Call - Zalo : 0934121179
