What's New?
ALCATEL
OT-6110 - Read Unlock Codes/Reset/Write Flash/Change Language Via Flashing/Repair Software Via Flashing.
OT-7041 - Unlock Via Reset Sim Lock Package//Reset/Write Flash/Change Language Via Flashing/Repair Software Via Flashing.(beta support).
For phones with damaged IMEI or other errors like permanent slot locked use this package.
For reset this phones please download reset package from support.
OT-7024 - Cross Flash Feature to OT-7024n OR To OT-7024w & Back.
Added reset package in support.
This will reset simlock also (factory unlock).
Reset SIM Lock Package = Factory Unlock Package.
To reset this phones please download reset package from support.
Added in support multi language firmware for OT-7024 with advanced developer functions and TRACE Mobile logs enabled.
7024_VeriTest_block_trace.exe
Tested on OT-7024w and OT-7024n.
Firmware SIMLOCK state is "Factory unlocked"
Please be sure you use this exe to flash this firmware in phone.
Improved reading unlock codes for OT-6012 and related phones.
Added aditional info like IMEI and phone version to display on read codes.
Added posibility to reset userdata, simlock(unlock) for OT-6012.
Locked firmwares like OT-6012a will work also.
For phones with damaged imei or other errors like permanent slot locked use this package.
Fixed repair procedure for Acer z120, now should be all ok.
Please follow exe instruction and read read_me from support.
Fixed repair IMEI for supported phones.
Added display battery voltage until booting or flashing.
Added "Disable check battery" checkbox in exe(if phone not support this)
Added reboot phone to meta mode button (for users what need to work with phone in this mode with other applications like maui meta e.t.c.)
Changed way of detecting phones, improved auto detection for flash mode and meta mode.
Changed way of format procedure until flash for: MT6572, MT6589, MT6582 MCU based phones.
Now simlock will be reseted also until flash.
Some bugfixed for flashing procedures.
Some bugfixes for old phones like OT-918 (flashing, unlock)
Please take note, reset packages can be used only with this or new exe versions.
Using this packages in old exe versions can not work as expected.
Is highly recommended to use this exe.
How to use reset package?
1. Download from support the related Reset Package.
2. Unrar archive to needed directory (c:\ or d:\).
3. Select correct model from list.
4. Select scatter file from firmware directory.
5. Reinsert phone battery (or power on, off phone) and click write flash.
6. When exe ask, insert usb cable (install drivers if need).
7. Wait until flash done and phone start charging.
8. Power ON phone, first start can take little more time.
DISCUSSION THREAD:
NCK Dongle Android MTK Module v2.4.4 Released - [15/04/2014]
__________________
BR
Fast Unlocking (NCK Team)
