    Thành viên mới quangsang26's Avatar
    Oct 2013
    Mặc định chạy phần mềm BB5 lỗi
    mình chạy con nay là con thứ 2. đến đoạn này nó toàn báo như sau. anh em ai giúp với .
    log nó đây
    Number of Image Files: 4
    Processing Image File :
    RM-684_30.0.002_prd.core.C00
    CMT Type : BB5
    CMT Algorithm : XSR 1.6
    Secondary Sending Speed : 650000Hz
    Algorithm Sending Speed : 13000000Hz
    Program Sending Speed : 13000000Hz
    Message Reading Speed : 98000Hz
    Number of Blocks : 374
    Entry Point: 0x2756AB
    Page Format : -1
    MAX PAGE : 0x00040000
    RM-684_30.0.002_C05_prd.rofs3.fpsx
    CMT Type : BB5
    Number of Blocks : 16
    Entry Point: 0x00D7
    Page Format : -1
    RM-684_30.0.002_prd.rofs2.V20
    CMT Type : BB5
    Number of Blocks : 99
    Entry Point: 0x00D7
    Page Format : -1
    RM684_30.0.002_000_000_U001.uda.fpsx
    CMT Type : BB5
    Number of Blocks : 68
    Entry Point: 0x00D7
    Page Format : -1
    []: Found 1 active devices.
    [Nokia 5800 XpressMusic USB Phonet]: Opening Connection
    [Nokia 5800 XpressMusic USB Phonet]: Port opened OK!
    SW: V ICPR72_11w10.1 15-03-11 RM-684 (c) Nokia
    IMEI: 357883040625038
    CONFIG KEY : 0000000000000000
    PROVIDER KEY : 2440700000000000
    NETWORK NAME : Nokia Default;Finland
    LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10
    SIMLOCK TABLE :
    Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
    SIMLOCK STATE : Not Locked
    START FULL PM BACKUP
    Please Wait...
    Reading : PM 0~400... OK!
    FULL PM Backup Saved to:
    C:\AdvanceBox Turbo Flasher\Nokia\Backup\357883040625038\USB_FULL_BACK UP_V ICPR72_11w10.1 15-03-11 RM-684 (c) Nokia_357883040625038_Not Locked_54336.pm
    Reading Battery Value : 3747 mV
    Rebooting Phone...
    AUTO SELECTED DEAD USB FLASHING...
    If Phone Booting does not Start in 5 Seconds,
    Then Perform Steps 1, 2, 3 and 4...
    1. Remove USB and Battery...
    2. Insert USB.
    3. Insert Battery. (Some phones boot automatically)
    4. Please Power on phone shortly...
    AdvanceFBox SendBootCodeEx
    InitialiseBootstrap_DCT5 DIR
    BootFlashMode_DCT5
    READING BOOTROM
    SYSTEM_ID_RESPONSE_BB5 (0xC0) - 96 (0x60) bytes returned
    Number of Sub Blocks 7 (0x07)
    1 SYSTEM_ASIC_ID 01
    Block Length : 21 (15)
    BB ASIC Index : 0 (00) CMT
    ID DWORD 0 : 00000001
    ID DWORD 1 : 00000226
    ID DWORD 2 : 00010006
    ID DWORD 3 : 400C1921
    ID DWORD 4 : 01051105
    2 EM_ASIC_ID 02
    Block Length : 5 (05)
    ID DWORD 0 : 00000296
    3 EM_ASIC_ID 02
    ID DWORD 0 : 00000B22
    4 PUBLIC_ID 12
    ID DWORD 0 : 0B100219
    ID DWORD 1 : 8BB20052
    ID DWORD 2 : 324B886C
    ID DWORD 3 : 10136D47
    ID DWORD 4 : 80D2B120
    5 ASIC_MODE_ID 13
    Block Length : 2 (02)
    Mode Id : 00
    6 ROOT_KEY_HASH 14
    Block Length : 17 (11)
    Hash : B8 C3 AD EC FC 99 7F CD 80 81 D3 DE AF 87 0B 8C
    7 ROM_ID 15
    Block Length : 9 (09)
    CRC 0 : 4B9B7510
    CRC 1 : 3E691FF8
    ADL_SERVER: PROCESSING RM-684_30.0.002_prd.core.C00
    ADL_SERVER: ROOT_KEY_HASH MATCH FOUND
    BB5 ADL Loader Start Up... (Please Wait...)
    ERROR: ADL Loader was not accepted
    PAPUB Key HASH is EMPTY or BLANK.
    Try "Skip ADL Check" Option or use FBUS Flashing
    Booting/Flashing Failed...
    Please Try Again...
    Thành viên tích cực Chấn Sấm Mobile's Avatar
    Feb 2014
    An Phong ,Thanh Bình ,Đồng Tháp
    chay bằng box hay usb zậy
  3. ( Chấn Sấm Mobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    quangsang26 (26-04-2014)
    Thành viên chính thức minhkhoalx's Avatar
    Dec 2010
    Nguyên cái log atf đó! Thử flash lại bằng phoenix xem sao?
    Phone: 0919523435. yahoo: tminhkhoalx@yahoo.com
  5. ( minhkhoalx ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    Oct 2013
    Sóc Trăng
    đem qua box khác flash lại you
    Đời còn dấu ?
    Thì mọi chuyện còn thay đổi.
  7. ( DTDD Hoai Bao ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  8. #5
    Thành viên tích cực Trần Gia_Store's Avatar
    Dec 2012
    Bắc Giang
    1-update box
    2-update file
    coi đc ko? không đc đưa qua cáp fpus thử
    Yahoo :trangiastore - Trí Yên - Yên Dũng - Bắc Giang
  9. ( Trần Gia_Store ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  10. #6
    Thành viên chính thức quanghoa-mobile's Avatar
    Apr 2014
    Hôm trước máy tính nhận draiv rất chậm khi flat xong máy ko tìm được draiv củng ko đồng bổ được . Mặc dù sau đó lấy cáp op lưng ra flat lại not ok. Cuối cùng đưa qua pc khác ăn ngay trong 7p50s
  11. ( quanghoa-mobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  12. #7
    Oct 2013
    chắc mình phải thử thay máy xem sao thank alll
