e có cây 2700c báo máy ảnh sẵn sàng. e đã vệ sinh, nâng cao tiếp xúc, kiểm tra áp có đủ hết, thay cam, fix lại luôn mà vẫn k được. nhờ ace giúp với và đây là log của e nó
MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C087278D
Using device: HTI, FW ver: 00.50, SN: 01015035
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.21719(09-05-2013), Library ver: 1.0.0.14397(09-05-2013)
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 2080010850540256D0949DEF93C3743925160C48
ASIC MODE ID: 00
ROM ID: 273F6D55DFAAF68F
eBB5ProtocolType: OLD
Storage0: 00EC 2400 - 0000 8A31 [Samsung K5N2833ATB,512 Mbits] type: FLASH,NOR, asic:CMT
TransmissionMode: 16Bit
TransmissionMode: DDR&TX2
Original Imei: 35435004195567
Original Product code: 0581057
Bluetooth ID: E4EC10B9D63E
SIMLOCK PA identifier:
[0] PA_SL3
Phone type: RM-561 (Nokia 2700 classic)
SW version: V 09.98 06-09-10 RM-561 (c) Nokia
Imei plain: 35435004195567-6
Battery voltage: 4400 mV, current: 67 mA
Language Pack:
- not available.
Camera config: NIMMIIIIRRFF01035602, ver: XXX.XXX
warning: DCC corrupted !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 354350041955676
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
thank ace nhiều
