như tiêu đề.e đã thay cáp thay màn vẫn vậy.e flash lại bằng cap USb log ngon nhưng máy ko về test mode để đồng bộ đc.flash bằng cáp đa năng nhưng báo lỗi "16 PROGRAMMING_ERROR_BB5 " ae xem giúp e với ạ.thaks ae nhiu ạ
flash lai ver cao nhất thử. đưa log ae xem thử.
log flash bằng USB đây ạ
Number of Image Files: 5
Processing Image File :
rm343_510.21.009_prd.c00
CMT Type : BB5
CMT Algorithm : XSR 1.5
Secondary Sending Speed : 650000Hz
Algorithm Sending Speed : 6500000Hz
Program Sending Speed : 6500000Hz
Message Reading Speed : 98000Hz
Number of Blocks : 595
Entry Point: 0x20470D
Page Format : -1
MAX PAGE : 0x00020000
rm343_510.21.009_prd.v16
CMT Type : BB5
Number of Blocks : 223
Entry Point: 0x0169
Page Format : -1
rm343_510.21.009.09U
CMT Type : BB5
Number of Blocks : 173
Entry Point: 0x0122
Page Format : -1
RM343_ENO_0741.10_08wk42.a26.fpsx
CMT Type : BB5
Number of Blocks : 18
Entry Point: 0x0143
Page Format : -1
dawn_erase_y_drive.fpsx
CMT Type : BB5
Number of Blocks : 0
Entry Point: 0x0000
Page Format : -1
MAX PAGE : 0x00000000
AUTO SELECTED DEAD USB FLASHING...
If Phone Booting does not Start in 5 Seconds,
Then Perform Steps 1, 2, 3 and 4...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
AdvanceFBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
READING BOOTROM
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 96 (0x60) bytes returned
Number of Sub Blocks 7 (0x07)
1 SYSTEM_ASIC_ID 01
Block Length : 21 (15)
BB ASIC Index : 0 (00) CMT
ID DWORD 0 : 00000001
ID DWORD 1 : 00000226
ID DWORD 2 : 00010006
ID DWORD 3 : 400C1921
ID DWORD 4 : 01031103
2 EM_ASIC_ID 02
Block Length : 5 (05)
ID DWORD 0 : 00000296
3 EM_ASIC_ID 02
ID DWORD 0 : 00000B22
4 PUBLIC_ID 12
ID DWORD 0 : 0D400109
ID DWORD 1 : F98C0052
ID DWORD 2 : 46AC42E0
ID DWORD 3 : F34711B2
ID DWORD 4 : 778554A0
5 ASIC_MODE_ID 13
Block Length : 2 (02)
Mode Id : 00
6 ROOT_KEY_HASH 14
Block Length : 17 (11)
Hash : CA EE BB 65 D3 C4 8E 6D C7 3B 49 DC 50 63 A2 EE
7 ROM_ID 15
Block Length : 9 (09)
CRC 0 : 4B9B7510
CRC 1 : 3E691FF8
CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Patched\RAPIDOv11_2nd.fg
Secondary Loader Sent....
MessageID : C1
SubBlocks : 06
Block Length : 0B
BB ASIC Index : CMT 00
Device Type : RAM 05
Device Index : 00
Manufacturer Code : 0000 -> Flash
Device ID : 0000 -> Type not in database
Extended/Fixed ID : 0000
Revision ID : 0000
2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MMC 04
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Type : NOR 00
Device Index : 00
Manufacturer Code : 0400 -> Flash
Revision ID : 0000
4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Index : 01
Manufacturer Code : 0000 -> SPANSION
Device ID : 0001 -> Type not in database
Revision ID : 0000
5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MuxOneNAND 03
Device Index : 00
Manufacturer Code : 00EC ->
Device ID : 0040 -> Type not in database
Revision ID : 0121
6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5
Block Length : 09
Data : XSR 1.5
Flash Descriptor
Device ID : 0040
Revision ID : 0000
Size : 10000000 (256 MB)
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Patched\RAPIDOv11_XSR15_a lg.fg
SendCodeStart_NewProtocol
SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00)
FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
FUR control Ok...
TransmissionTypeRequest_DCT5_NewProtocol
TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 54 04 01 00 00 00 A5
VPP Enabled by Software
Using Internal VPP
FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4
PA PUBLIC KEY Request
PHONE_INFO_RESPONSE_BB5
PAPUB_KEYS_HASH_RESP_BB5 2A
BB Asic Index : 00
CMT PAPUBKEYS HASH:
96B8EDD55BE6A0011D2BA3B5A4D8D82F58BBFD93
START READING RPL DATA
IMEI: 357976037409984
Reading : NPC... OK!
Reading : CCC... OK!
Reading : HWC... OK!
Reading : R&D... EMPTY
NPC CERTIFICATE INFORMATION (CMT):
IMEI : 357976037409984
PRODUCT CODE : 0566412
WLAN ID : EC:9B:5B:84:4E:4A
BLUETOOTH ID : EC:9B:5B:83:63:EA
PUBLIC_ID : 0D400109F98C005246AC42E0F34711B2778554A0
PAPUB_KEYS_HASH: 96B8EDD55BE6A0011D2BA3B5A4D8D82F58BBFD93
CCC CERTIFICATE INFORMATION (CMT):
HWC CERTIFICATE INFORMATION (CMT):
RPL Backup was Successful...
Plain RPL saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\357976037409984\3579760374099 84_82438.rpl
ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-343\
ImageFilename: rm343_510.21.009_prd.c00
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
Certificate 1
ASIC Index : CMT 0
Certificate 2
ASIC Index : CMT 0
Certificate 3
ASIC Index : CMT 0
Certificate 4
ASIC Index : CMT 0
STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5...
PARTITION_INFO_REQUEST_BB5 : 64012F6F00030000010000FFFFFFFF00000006000000030000 0002000800000158000000000004000000020160000005FA00 000000000800000001075A000007A800000000000B00000001 0F020000001A000000000009000000010F1C00000070000000 00000A000000010F8C000000160000DD
PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
StartErase_DCT5...
BlockLength : 0xB1 (177)
ERASE Blocks : 0x04 (4)
0 ERASE_AREA_BB5 0x12
Block Length : 0x1B (27)
BB ASIC Index : 0x00 CMT
Device Type : 0x03 MuxOneNAND
Device Index : 0x00
0 : 00040000-007FFFFF
1 : 00A00000-0759FFFF
2 : 0F1C0000-0F8BFFFF
1 FORMAT_PARTITION_BB5 0x19
Block Length : 0x2F (47)
Device Index : 0x00
Format Info ID : 0x00000000
Format Info : 000000000000000B0000000000000002000000640000000300 000001000000010000000000000000
2 FORMAT_PARTITION_BB5 0x19
Device Index : 0x00
Format Info : 00000000000000090000000000000001000000640000000400 000001000000010000000000000000
3 FORMAT_PARTITION_BB5 0x19
Device Index : 0x00
Format Info : 000000000000000A0000000000000002000000640000000300 000001000000010000000000000000
ERASE_REQUEST_BB5 : 5003120B00030000040000007FFFFF120B00030000A0000007 59FFFF120B0003000F1C00000F8BFFFF5A
FORMAT_REQUEST_BB5 : 5001192F00030000000000000000000000000B000000000000 00020000006400000003000000010000000100000000000000 003D
FORMAT_REQUEST_BB5 : 5001192F000300000000000000000000000009000000000000 00010000006400000004000000010000000100000000000000 003F
FORMAT_REQUEST_BB5 : 5001192F00030000000000000000000000000A000000000000 00020000006400000003000000010000000100000000000000 003E
Successfully Erased...
Total blocks to write : 595
>> CMT Rootkey Hash CERT : ADA
>> CMT Rootkey Hash CERT : KEYS
>> CMT Rootkey Hash CERT : PRIMAPP
>> CMT Rootkey Hash CERT : RAP3NAND
>> CMT Rootkey Hash CERT : PASUBTOC
>> CMT Rootkey Hash CERT : PAPUBKEYS [96B8EDD55BE6A0011D2BA3B5A4D8D82F58BBFD93]
>> CMT Rootkey Hash CERT : SOS*UPDAPP
>> CMT Rootkey Hash CERT : SOS*DSP0
>> CMT Rootkey Hash CERT : SOS*ISASW
>> CMT Rootkey Hash CERT : SOS*CORE
>> CMT Rootkey Hash CERT : SOS+ROFS
ImageFilename: rm343_510.21.009_prd.v16
StartErase_DCT5...
BlockLength : 0x3F (63)
ERASE Blocks : 0x02 (2)
Block Length : 0x0B (11)
Device Index : 0x00
0 : 05420000-0759FFFF
Device Index : 0x00
ERASE_REQUEST_BB5 : 5001120B000300054200000759FFFF39
Total blocks to write : 223
>> CMT Rootkey Hash CERT : SOS+ROFX
ImageFilename: rm343_510.21.009.09U
StartErase_DCT5...
BlockLength : 0x32 (50)
ERASE Blocks : 0x01 (1)
0 FORMAT_PARTITION_BB5 0x19
Device Index : 0x00
Format Info : 00000000000000080000000000000001000000640000000A00 000001000000010000000000000000
FORMAT_REQUEST_BB5 : 5001192F000300000000000000000000000008000000000000 0001000000640000000A000000010000000100000000000000 003A
Total blocks to write : 173
ImageFilename: RM343_ENO_0741.10_08wk42.a26.fpsx
StartErase_DCT5...
BlockLength : 0x10 (16)
0 ERASE_AREA_BB5 0x13
Block Length : 0x0D (13)
ERASE_REQUEST_BB5 : 5001130D00534F532A454E4F0000000000DD
Total blocks to write : 18
>> CMT Rootkey Hash CERT : SOS*ENO
ImageFilename: dawn_erase_y_drive.fpsx
StartErase_DCT5...
BlockLength : 0x0E (14)
Device Index : 0x00
0 : 0F020000-0F1BFFFF
ERASE_REQUEST_BB5 : 5001120B0003000F0200000F1BFFFFA5
No blocks to write...
ContinueFlash_DCT5 Complete
Continue Flash Complete : : No Error - 0 (0x00)
STATUS_REQUEST_BB5...
1 Sub Block ID : 15 STATUS_NAND_OK_BB5
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Num Bad Blocks : 00000001
Additional Bad : 00000001
Correctable ECC : 00000000
FlashInfo.RestartMode : 1
Flashing Done...
Total Flashing Time (Erase + Flashing) : 00:04:20
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 150 seconds)
tháo camera ra xem đồng bộ được không.
0985210545
không đc a ạ
SL1/SL2 Applet detected
* If you want to unlock this phone, please use:
Rebuild Simlocks via Simlock RPL
FACTORY SET TO : Full Factory Set
FAILED
FACTORY SET TO : User Data
FAILED
FACTORY SET TO : Leave Factory
FAILED
FACTORY SET TO : Service Center
FAILED
FACTORY SET TO : Software Upgrade
FAILED
FACTORY SET TO : Production Tune
FAILED
sao ko thấy đụng đến ic khiển màng hình nhỉ
Ic khiển là phương án khả thi bạn a
2313205056321
cảm ơn tất cả ae nhiu nha.máy đã nên ok![]()
