dùng cáp dct4 G -buscheck -scan phone- reset all ok
VBATT Powering Up >>>>
SET VCCIO Level Done
SET BSI Load Done
Booting Phone...
CPU ID Response: A200341100
CPU Type: XG110 2.1B
Phone Booted at after First attempt...
START INFINEON BUS CHECK
Sending PBL 37888 bytes...
PBL Successfully Sent...
Sending SBL 65024 bytes...
SBL Successfully Sent...
Flash Chip Manufacturer: Spansion Electronics Corp.
Flash Chip Type: 64 Mbit (4Mb x 16) NOR
Extended Information: Mirrorbit / Multi-Bank / 1.8v
INFINEON BUS CHECK DONE
MCU: V 02.90 21-08-13 RM-962 (c) Nokia
IMEI: 359583050166794
Product Serial Number: 05411CCAU
Product Code : 059T2D1
Module Code : 0205710
Basic Production Code: 059S7H2
PPM SW Version : V 02.90 21-08-13 RM-962 (c) Nokia MR
ADSP Version : p V 02.90\n21-08-13\nRM-962\n(c) NMP\nmr
MCU SW Version : V 02.90 21-08-13 RM-962 (c) Nokia
HW Version : 3300
UEM Version : 1328
UPP Version : 8850
LCD Version : TPO:BARACOAv90 HX5081
********** SIMLOCK INFO **********
CONFIG_DATA : 0010100000000000
PROFILE_BITS : 0000000000040002
ASIC : 11
PROVIDER : Default Test Operator
Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
ST_LCD_TEST : PASSED
Make sure you have installed the
COMPLETE Flash Package for this Phone...
Goto "Settings" --> "Nokia Settings" and verify that
the Folder where you installed your Flash Files are
in the "PRODUCT PATH TO SCAN" List...
FACTORY SET TO : Full Factory Set
OK
FACTORY SET TO : User Data
OK
FACTORY SET TO : Leave Factory
OK
FACTORY SET TO : Service Center
OK
FACTORY SET TO : Software Upgrade
OK
FACTORY SET TO : Production Tune
OK
OK
OK
OK
OK
