Như tiêu đề e nhận con e52 báo "phone startup failed. contact the retailer" up fw báo oke nhưng bật lên hiện nokia 1 lúc rồi tắt ngấm , chưa biết giải quyết sao , bác nào đi qua cho e ý kiến
 E52 lỗi khởi động
 E52 lỗi khởi động
				bạn copy cái lock quăn lên đây đi
				Flashing started
Creating product data items list
Product data items list created
Backup not required
Flashing phone
Initializing
Scanning image files...
Waiting for USB device...
Loading secondary boot code: 15168 bytes
Secondary boot loaded
BB Asic Index is: 00
Asic ID is: 000000030000022600010007600C192102011104
EM Asic ID is: 00001040
EM Asic ID is: 00001030
Public ID is: 2B20010E796903443A3D298CD8D3F1BC21793910
Asic Mode ID: 00
Hash: 25B977A055BE9B5DEC0C38A2A279C695
ROM ID: 3E273BF637BE26FA
Device type is: 05
Device Index is: 00
Manufacturer code: 0000
Device ID: 0000
Extended device ID: 0000
Revision ID: 0000
Device type is: 04
Device Index is: 00
Manufacturer code: FFFF
Device ID: 0000
Revision ID: 0000
Device type is: 00
Device Index is: 00
Manufacturer code: 0020
Device ID: 0040
Revision ID: 0031
Device type is: 00
Device Index is: 01
Device ID: 0001
Revision ID: 0000
Device type is: 03
Device Index is: 00
Device ID: 0040
Revision ID: 0031
Loading update server code: 868528 bytes
Update server loaded
Asic CMT: Start programming 160331 KB...
Asic CMT: Programming data sent: 0%
Asic CMT: Programming data sent: 10%
Asic CMT: Programming data sent: 20%
Asic CMT: Programming data sent: 30%
Asic CMT: Programming data sent: 40%
Asic CMT: Programming data sent: 50%
Asic CMT: Programming data sent: 60%
Asic CMT: Programming data sent: 70%
Asic CMT: Programming data sent: 80%
Asic CMT: Programming data sent: 90%
Asic CMT: Programming data sent: 100%
Programming complete
Asic CMT: Verifying communication to device...
Phone flashing completed. Waiting for phone to boot up
Bootup successful
Verifying communication to product (before flash finalizing)
Communication verified
Product code changed
Doing factorysets
Factorysets complete
Loading default data to phone
Getting Data Package
Reading product state
Starting backup/restore sub-procedure: data item pre-delay
data item pre-delay
data item pre-delay
Sub-procedure completed: Succeeded., result code: 0
Starting to backup/restore data item: ProductProfile, version: 1.1
Data Item backup/restore completed: Succeeded., result code: 0
Starting backup/restore sub-procedure: data item post-delay
Backup/restore result: 0 out of 1 items were not backed up
Default data loading complete
Stopping all operations, returning phone to default mode
All operations completed
Firmware updating succeeded.
đây bác
				xem log này thì bó tay.có box atf scan log xem như nào.tay không bắt giặc ha?
0985210545
				) e lười mua box ăn phoenix bác thông cảm , hàng no h ít k muốn mua
				úp bản ver cao hơn đi
				sr các bác mấy hnay bận k vào forum đc
máy đã up ver 091.003 - 091.004 đều not ok
bật máy vẫn hiện nokia rồi tắt ngấm
