e mới nhận của khách 1 e 105 rớt nước sấy khô bây giờ kẹp nguồn thì lên cho pi vao thì không lên ai pít giúp e với chạy thư pm thì báo VBATT Powering Down <<<<
VBATT Powering Up >>>>
SET VCCIO Level Done
SET BSI Load Done
Booting Phone...
CPU ID Response: A200341100
CPU Type: XG110 2.1B
Phone Booted at after First attempt...
TIME STARTS HERE
Sending PBL 19456 bytes...
PBL Successfully Sent...
Sending SBL 65024 bytes...
SBL Successfully Sent...
Flash Chip Manufacturer ID: 0x00EF
Flash Chip Type: 64 Mbit (4Mb x 16) NOR
Extended Information: Multi-Bank / 1.8v
Processing Image File: C:\Documents and Settings\Admin\Desktop\RM-908\rm908_003.100
Data Block Found...
Number of Sections: 03
IMAGE Certificate Block Sent Successfully...
Processing Section 01 of 03
IMAGE Erase Block: 0x00800000~0x00A0FFFE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Preparing Data Blocks...
Data Size: 2162688 bytes
Data Checksum: 0551
Uploading Data Blocks to phone...
IMAGE Data Blocks uploaded to phone...
Processing Section 02 of 03
IMAGE Erase Block: 0x00C60000~0x00EAFFFE
Start Erasing...
Block Erase Done...
Data Size: 2232896 bytes
Data Checksum: 89F6
Processing Section 03 of 03
IMAGE Erase Block: 0x00FFC000~0x00FFFFFE
Start Erasing...
Block Erase Done...
Data Size: 64 bytes
Data Checksum: 0000
Start Data Verification... (Please wait)
Data Verification Successful...
Exit Flash Mode Done...
Time Elapse : 00:01:17
You must Factory Reset the phone to enable the
ringtones and other customized settings to work
Waiting For Phone to go Online...
5, 4, 3, 2, 1...
ERROR : PHONE READ INFO FAILED
