Mình có cây 301 nhận khách trong tình trạng rơi nước. Bật chỉ rung cái rồi tắt. Đã sấy và vệ sinh sạch sẽ chạy lại pm vẫn ko được. nhờ ae giúp đỡ
đưa log lên ae tham khảo
log đây bác log đẹp mà
Number of Image Files: 3
Processing Image File :
rm839__02.33.mcusw
rm839__02.33.ppm_s3
rm839__02.33.image_s3_059S163
[]: Found 1 active devices.
[Nokia 301 USB Phonet]: Opening Connection
[Nokia 301 USB Phonet]: Port opened OK!
SW: V 02.33 17-05-13 RM-839 (c) Nokia
IMEI: 358340054291925
START FULL PM BACKUP
Please Wait...
Reading : PM 0~400... OK!
FULL PM Backup Saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\358340054291925\USB_FULL_BACK UP_V 02.33 17-05-13 RM-839 (c) Nokia_358340054291925__70220.pm
Reading Battery Value : 3809 mV
Rebooting Phone...
AUTO SELECTED DEAD USB FLASHING...
If Phone Booting does not Start in 5 Seconds,
Then Perform Steps 1, 2, and 3...
1. Remove USB Cable and Battery...
2. Connect USB Cable.
3. Connect Battery.
***** IF PHONE STARTS CHARGING OR DOES NOT BOOT *****
******* REMOVE BATTERY AND PUT IT BACK AGAIN. *******
Infineon Boot: F01650A9070100030101E02000091008D5C3480E1DB5FFFF
<<<< Connect Battery Now >>>>
Sending PBL...
PBL Successfully Sent...
Sending SBL...
SBL Successfully Sent...
Flash Chip Manufacturer: Samsung Electronics Corp.
Flash Boot Successful...
Unique Data: E02000091008D5C3-480E1DB5
Original Product Code: 059R2F0
Reading : CCC... OK!
Reading : HWC... OK!
Reading : NPC... OK!
RPL Backup was Successful...
Plain RPL saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\358340054291925\3583400542919 25_70228.rpl
Current File : rm839__02.33.mcusw
Number of Images: 8
psi_flash_unsigned.fls
slb_signed.fls
main_toc_signed.fls
rm839__02.33.mcusw_signed_mcusw.fls
swap_signed.fls s
dynsw.fls
aeneas_signed.fls s
fota_signed.fls s
Processing Data Block 0x00
Erase Block: 0x00090000~0x000A0FAE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Start Writing...
Finalizing...
Data Block Write Done...
Processing Data Block 0x01
Erase Block: 0x60000000~0x6003FFFE
Start Erasing...
Block Erase Done...
Start Writing...
Finalizing...
Processing Data Block 0x02
Erase Block: 0x60040000~0x600403FE
Start Erasing...
Block Erase Done...
Start Writing...
Finalizing...
Processing Data Block 0x03
Erase Block: 0x62E00000~0x63D0520E
Start Erasing...
Block Erase Done...
Start Writing...
Finalizing...
Erase Block: 0xFFF00000~0xFFF7FFFE
Start Erasing...
Block Erase Done...
Processing Data Block 0x04
Erase Block: 0x80000000~0x80C1B3CA
Start Erasing...
Block Erase Done...
Start Writing...
Finalizing...
Processing Data Block 0x05
Erase Block: 0x62080000~0x620C3FFE
Start Erasing...
Block Erase Done...
Start Writing...
Finalizing...
Processing Data Block 0x06
Erase Block: 0x63F79C00~0x63FC046E
Start Erasing...
Block Erase Done...
Start Writing...
Finalizing...
Processing Data Block 0x07
Erase Block: 0x61F00004~0x6204547A
Start Erasing...
Block Erase Done...
Start Writing...
Finalizing...
Current File : rm839__02.33.ppm_s3
Number of Images: 1
package_s3.ppm_ebl_psi.fls
Erase Block: 0x80F00000~0x8163E7C2
Start Erasing...
Block Erase Done...
Start Writing...
Finalizing...
Current File : rm839__02.33.image_s3_059S163
Number of Images: 1
package_s3_059S163.image.fls
Erase Block: 0xA1000000~0xA27DD9FE
Start Erasing...
Block Erase Done...
Start Writing...
Finalizing...
Erase Block: 0xAE000000~0xAE2FFFFE
Start Erasing...
Block Erase Done...
Total Flashing Time (Erase + Flashing) : 00:00:17
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 150 seconds)
Scanning USB Ports...
Basic Phone Information
MCU Version: V 02.33 17-05-13 RM-839 (c) Nokia
IMEI Plain : 358340054291925
IMEI Spare : A358340054291920
IMEI SV : 33583400542919206F
IMEI (2nd) : 358340054291933
IMEI Spare : A358340054291930
IMEI SV : 33583400542919306F
Phone Model: Nokia 301 Dual SIM
Category : Phone
Phone Type : RM-839
Extended Phone Information
Product Serial Number: 3F5FC29BH
Product Code : 059R2F0
Module Code : 0205270
Basic Production Code: 059P5R3
Long Production SN : 0
PPM SW Version : V 02.33 17-05-13 RM-839 (c) Nokia S3
ADSP Version : PMU_MAXIM8939B
MCU SW Version : V 02.33 17-05-13 RM-839 (c) Nokia
HW Version : 1200
UEM Version : 18
UPP Version : MFR:0xec,DEV:0x40,REV:0x231
RFIC Version : 152
LCD Version : TPO
Camera : 01035602006003
Content Pack Version : Content: s3_059S163 V 02.33 17-05-13 RM-839 (c) Nokia
AHNE Version : 13
RETU Version : PMU_MAXIM8939B
Bluetooth ID : 40:7A:80:A7:46:86
CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA VIII
********** SIMLOCK INFO **********
CONFIG_DATA : 0010100000000000
PROFILE_BITS : 800000000004000B
ASIC : 11
PROVIDER : Default Test Operator
LOCK COUNTERS: KEYPRESS 0/3, FBUS 0/10
Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
SIMLOCK_TYPE : PA_SIMLOC30 (20-digit NCK)
SIMLOCK_TEST : PASSED
SECURITY_TEST : PASSED
SECURITY_CODE : 12345
PHONE_MODE : TEST
Dynamic Camera Configuration
DCC ID : 01035602
DCC Ver: 006003
Status : OK
Selected VPL File:
RM839_059S163_02.33_030.vpl
Variant Details : RM-839 APAC_S3_FUCHSIA_STROKE_VN
Software Version : 02.33
Product Type : RM-839
Product Code : 059S163
Variant Version : 030
FACTORY SET TO : Full Factory Set
OK
FACTORY SET TO : User Data
OK
FACTORY SET TO : Leave Factory
OK
FACTORY SET TO : Service Center
OK
FACTORY SET TO : Software Upgrade
OK
FACTORY SET TO : Production Tune
OK
RESET LIFE TIMER TO : 0000:00
OK
1 viên thuốc lắc uem là done
lắc tứ tung rồi bác à. E nghĩ con này đứt đường BSI nhưng chả biết nó đi vào đâu. Ai có sơ đồ không cho e xin sơ đồ với
