Selected FlashSettings : FullFlash
Check FlashFiles, Please, wait...
Files Set for Flashing :
MCU : rm346_510.21.009_prd.c00
PPM : rm346_510.21.009_prd.v27
CNT : rm346_510.21.009.13U
Flashing phone now...
Check files done...
-> SWversion check skipped : Dead mode selected
Dead Mode is Selected
Waiting for USB device...
--- Press phone's power button or insert cable & charger! ---
Connection opened successfully
Waiting for communication response...
BootRom : 1st boot ok
ASIC ID: 000000010000022600010006400C192101031103
CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 1DC0010D707500523A0876FDABE91E80AB0661F9
ASIC MODE ID: 00
ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: 4B9B75103E691FF8
PatchRAWLoader: Patched OK
Processing RAWLOADER...
Processing UPDAPP ...
Processing PASUBTOC ...
Boot Done!
TIME : Boot time : 00:00:04
Reopening the connection...
Waiting for response: 30
Waiting for response: 29
ADL Server confirm flashmode!
ADL : ASIC CMT select Ok
===Flashing [MCU]===
Erase : Processing rm346_510.21.009_prd.c00
Found 3 areas to erase
Erasing area 0x00040000 - 0x007FFFFF, NAND, CMT
Result: 0000
Erasing area 0x00A00000 - 0x0759FFFF, NAND, CMT
Result: 0000
Erasing area 0x0F1C0000 - 0x0F8BFFFF, NAND, CMT
Result: 0000
Partition erase not allowed by loader
Partitioning : Ok [7]
TIME : Erase time : 00:00:00
Write : Processing rm346_510.21.009_prd.c00
Total 588 [588/0/0] blocks to write, writing...
CMT : Writing Hash CERT [ADA]
CMT : Writing Hash CERT [KEYS]
CMT : Writing Hash CERT [PRIMAPP]
CMT : Writing Hash CERT [RAP3NAND]
CMT : Writing Hash CERT [PASUBTOC]
CMT : Writing Hash CERT [PAPUBKEYS]
CMT : Writing Hash CERT [SOS*UPDAPP]
CMT : Writing Hash CERT [SOS*DSP0]
CMT : Writing Hash CERT [SOS*ISASW]
CMT : Writing Hash CERT [SOS*CORE]
CMT : Writing Hash CERT [SOS+ROFS]
TIME : Write time : 00:02:51
MCU Write done
===Flashing [PPM]===
Erase : Processing rm346_510.21.009_prd.v27
Found 1 areas to erase
Erasing area 0x05420000 - 0x0759FFFF, NAND, CMT
Result: 0000
Write : Processing rm346_510.21.009_prd.v27
Total 198 [198/0/0] blocks to write, writing...
CMT : Writing Hash CERT [SOS+ROFX]
TIME : Write time : 00:00:52
PPM Write done
===Flashing [CNT]===
Erase : Processing rm346_510.21.009.13U
Write : Processing rm346_510.21.009.13U
Total 122 [122/0/0] blocks to write, writing...
TIME : Write time : 00:00:33
CNT Write done
ADL : End flashing
ADL : Finalize...
Flashing done!
Total flash time : 00:04:17
Reboot phone now...
Reading Phone Info....
Connected phone - Nokia E71
Software Info: V ICPR71_09w47.10 20-01-11 RM-346 (c) Nokia
IMEI: 351940036089870
Ape Version: 510.21.009
Product code: 0566234
Checking...
SimLock status : SimLock is Ok
Security status : Security Damaged!!!!!
Read Info Done!
Settings After Flash Defaults...
Error When resetting FullFactory...
Error When setting User Data defaults...
Error When resetting Product Tune...
Error When resetting SW upgrade Default...
Resetting LifeTimer
Error check LifeTimer Data, break
Probably - will not exist, before phone start :|
Set phone to Normal mode...
AfterFlash operations done ;D
Done!
Elapsed: 00:04:46
Connect phone on selected interface...
Up 2 3 cai Fw van vay![]()
Luc đầu máy đang dùng bt nhưng chạy yếu ....nên Flash lại.
Giờ bật máy lên " Phone start-up failed. Contack the retailer"
Cần cao nhân giúp đỡ![]()
