- Added support for the following models:- D120 - added world's first Direct Unlock, Read Codes, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair EEPROM, Read info, Read Full Flash (thanks to mr. hotgsm.net).
- D120AR - added world's first Direct Unlock, Read Codes, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair EEPROM, Read info, Read Full Flash.
- D120F - added world's first Direct Unlock, Read Codes, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair EEPROM, Read info, Read Full Flash.
- D120G - added world's first Direct Unlock, Read Codes, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair EEPROM, Read info, Read Full Flash.
- D120J - added world's first Direct Unlock, Read Codes, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair EEPROM, Read info, Read Full Flash.
- D125 - added world's first Direct Unlock, Read Codes, Repair IMEI (A/B), Repair BT Address, Repair Wi-Fi Address, Read/Write EEPROM, Read info, Read Full Flash.
- D125F - added world's first Direct Unlock, Read Codes, Repair IMEI (A/B), Repair BT Address, Repair Wi-Fi Address, Read/Write EEPROM, Read info, Read Full Flash.
- D125G - added world's first Direct Unlock, Read Codes, Repair IMEI (A/B), Repair BT Address, Repair Wi-Fi Address, Read/Write EEPROM, Read info, Read Full Flash.
- D127F - added world's first Direct Unlock, Read Codes, Repair IMEI (A/B), Repair BT Address, Repair Wi-Fi Address, Read/Write EEPROM, Read info, Read Full Flash.
- D150 - added world's first Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Repair Security, Write Security Backup, Read/Write/Repai NVM, Read/Write QCN, Read Full Flash (dump NAND).
- D157 - added world's first Direct Unlock, Repair IMEI (A/B), Repair BT Address, Repair Wi-Fi Address, Read Security, Write Security Backup, Read/Write NVM, Read/Write QCN, Read Full Flash (dump NAND).
- D157F - added world's first Direct Unlock, Repair IMEI (A/B), Repair BT Address, Repair Wi-Fi Address, Read Security, Write Security Backup, Read/Write NVM, Read/Write QCN, Read Full Flash (dump NAND).
- D290 - added world's first Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read Security, Write Security Backup, Read/Write NVM, Read/Write QCN,Read Full Flash (dump NAND).
- D290G - added world's first Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read Security, Write Security Backup, Read/Write NVM, Read/Write QCN,Read Full Flash (dump NAND).
- D290N - added world's first Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read Security, Write Security Backup, Read/Write NVM, Read/Write QCN,Read Full Flash (dump NAND).
- D290TR - added world's first Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read Security, Write Security Backup, Read/Write NVM, Read/Write QCN,Read Full Flash (dump NAND).
- D295 - added world's first Direct Unlock, Repair IMEI (A/B), Repair BT Address, Repair Wi-Fi Address, Read/Repair Security, Write Security Backup, Read/Write/Repair NVM, Read/Write QCN, Read Full Flash (dump NAND).
- D295F - added world's first Direct Unlock, Repair IMEI (A/B), Repair BT Address, Repair Wi-Fi Address, Read/Repair Security, Write Security Backup, Read/Write/Repair NVM, Read/Write QCN, Read Full Flash (dump NAND).
- D213K - added world's first Direct Unlock, Read Codes, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write/Repai EEPROM, Read info, Read Full Flash.
- D213 - added Direct Unlock, Read Codes, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair EEPROM, Read info, Read Full Flash.
- D213AR - added Direct Unlock, Read Codes, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair EEPROM, Read info, Read Full Flash.
- D213C - added Direct Unlock, Read Codes, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair EEPROM, Read info, Read Full Flash.
- D213CF - added Direct Unlock, Read Codes, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair EEPROM, Read info, Read Full Flash.
- D213CJ - added Direct Unlock, Read Codes, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair EEPROM, Read info, Read Full Flash.
- D213F - added Direct Unlock, Read Codes, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair EEPROM, Read info, Read Full Flash.
- D213N - added Direct Unlock, Read Codes, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair EEPROM, Read info, Read Full Flash.
- D213TR - added Direct Unlock, Read Codes, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair EEPROM, Read info, Read Full Flash.
- D221 - added Direct Unlock, Read Codes, Repair IMEI (A/B), Repair BT Address, Repair Wi-Fi Address, Read/Write EEPROM, Read info, Read Full Flash.
- D221C - added Direct Unlock, Read Codes, Repair IMEI (A/B), Repair BT Address, Repair Wi-Fi Address, Read/Write EEPROM, Read info, Read Full Flash.
- D225 - added Direct Unlock, Read Codes, Repair IMEI (A/B), Repair BT Address, Repair Wi-Fi Address, Read/Write EEPROM, Read info, Read Full Flash.
- D227 - added Direct Unlock, Read Codes, Repair IMEI (A/B), Repair BT Address, Repair Wi-Fi Address, Read/Write EEPROM, Read info, Read Full Flash.
- D228 - added Direct Unlock, Read Codes, Repair IMEI (A/B), Repair BT Address, Repair Wi-Fi Address, Read/Write EEPROM, Read info, Read Full Flash.
- Also added world's first Read/Write QCN for the next devices:- D500, D500BK, D500BKGO1
- MS500
- D505
- D605
- P655H, P655K
- P659, P659BK, P659BKGo, P659H
- MS659
- D520, D520BK
- LS720, VM720
More info and discussion are HERE
- All supported operations are described in details in Software manual ("Cable & Manual" button in Software).
			 Octoplus/Octopus Box LG Software v1.7.2 Release Notes
