C2-00 RM 704
Nạp nhầm file ngủm
MCU: RM-704 v03.99
PPM: RM-704_3.42
Image: RM-704_3.42
Xin mọi người giúp
				 C2-00 nạp nhầm file xin giúp
				C2-00 RM 704
Nạp nhầm file ngủm
MCU: RM-704 v03.99
PPM: RM-704_3.42
Image: RM-704_3.42
Xin mọi người giúp
				ngủm là sao bác....nói rõ được không....up lại file đụng nóc nhà full done mà
				best tool not ok, ATF khong nhận USB
				card found: A1B5CCE8
registered to: CycloneBox
Connect phone on selected interface...
Core : v1.51 , FlashEngine : v1.8
Selected FlashSettings : Manual
Check FlashFiles, Please, wait...
Files Set for Flashing :
MCU : rm704__03.99.mcusw
PPM : rm704__03.99.ppm_v
CNT : rm704__03.99.image_v_jblack_059C884
Flashing phone now...
Check files done...
-> SWversion check skipped : Dead mode selected
Dead Mode is Selected
Waiting for USB device...
-> If Windows say "Unrecognized device" - just reinsert battery
-> If flashing freeze - reinsert cable and try again
--- Press phone's power button or insert charger! ---
Connection opened successfully
DBG : F00A1FB300020303010100FF
CPUID : XGOLD 213
2nd boot Ok, 01
2nd ready, AA
Sending Algo
Algo sent Ok
BL : Quantum_Bootloader_10.44_M1S1
Speed accepted, use 6.500.000
FLASHID : 89008289
FLIC conf set, RST set
Boot done!
Backup enabled, will read all certificates
Reading CCC
Reading HWC
Reading NPC
IMEI 1 : 359029049786383
IMEI 2 : 359029049786391
PCcode : 059C883
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
RPL saved : C:\Users\Tri Mobile\Desktop\Infinity Best\Backup\Cert\359029049786383_359029049786391_X G213_CRT.rpl
===Flashing [MCU]===
File : rm704__03.99.mcusw
Image : rm704__03.99.mcusw_ebl_psi.fls
Cert block found, sending....
Cert sent
Found 5 region(s)
Processing Region 1/5
Erase , Start : 0x40000000 , Len : 0x00020000
Erasing, wait ...
Erase done, time : 00:00:00
Write , Start : 0x40000000 , Len : 0x00020000
Flashing , wait ...
Region flash done, time : 00:00:00
Processing Region 2/5
Erase , Start : 0x40040000 , Len : 0x00020000
Erasing, wait ...
Write , Start : 0x40040000 , Len : 0x00020000
Flashing , wait ...
Processing Region 3/5
Erase , Start : 0x40060000 , Len : 0x00100000
Erasing, wait ...
Erase Error, connection lost! Check cable/battery!
Error...
-> Check cable, flashfile, try again from this file
Elapsed: 00:00:21
				ATF
Number of Image Files: 3
Processing Image File :
rm704__03.99.mcusw
rm704__03.99.ppm_v
AUTO SELECTED DEAD USB FLASHING...
If Phone Booting does not Start in 5 Seconds,
Then Perform Steps 1, 2, 3 and 4...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
Infineon USB Boot: F00A1FB300020303010100FF
Sending PBL...
ERROR: PBL was NOT Accepted
				đập file full bằng phonenix thử coi bạn http://www.mediafire.com/download/1u...704+v03.99.rar
				không được luôn
				vào đây nhập produc code ròi load file quất phát nữa coi sao not ok chắc thay cặp
				vấn đề là PC không nhận driver ak..hi full cũng chịu..coi dùng box thử bạn
				Not ok nữa rồi, tưởng múc nhanh 40k ai zè mớ ngủ @@
