    Thành viên chính thức pham thanh linh's Avatar
    Aug 2014
    tiền giang
    Mặc định c2-01 flash báo lỗi xin anh em giúp
    c2-01 thay nguồn flash báo lỗi xin anh em giúp một tay..tks all,đây la log của em nó
    Processing Image File :
    rm721__11.21.mcusw
    CMT Type : BB5
    CMT Algorithm : XSR 1.6
    Secondary Sending Speed : 3250000Hz
    Algorithm Sending Speed : 6500000Hz
    Program Sending Speed : 19500000Hz
    Message Reading Speed : 98000Hz
    Number of Blocks : 158
    Entry Point: 0x0259
    Page Format : -1
    MAX PAGE : 0x00040000
    rm721__11.21.ppm_v
    CMT Type : BB5
    Number of Blocks : 31
    Entry Point: 0x011D
    Page Format : -1
    rm721__11.21.image_v_059Q2Q1_002
    CMT Type : BB5
    Number of Blocks : 74
    Entry Point: 0x0154
    Page Format : -1
    AUTO SELECTED DEAD USB FLASHING...
    If Phone Booting does not Start in 5 Seconds,
    Then Perform Steps 1, 2, 3 and 4...
    1. Remove USB and Battery...
    2. Insert USB.
    3. Insert Battery. (Some phones boot automatically)
    4. Please Power on phone shortly...
    AdvanceFBox SendBootCodeEx
    InitialiseBootstrap_DCT5 DIR
    BootFlashMode_DCT5
    READING BOOTROM
    SYSTEM_ID_RESPONSE_BB5 (0xC0) - 96 (0x60) bytes returned
    Number of Sub Blocks 7 (0x07)
    1 SYSTEM_ASIC_ID 01
    Block Length : 21 (15)
    BB ASIC Index : 0 (00) CMT
    ID DWORD 0 : 00000001
    ID DWORD 1 : 00000226
    ID DWORD 2 : 00000001
    ID DWORD 3 : 020C1921
    ID DWORD 4 : 02044100
    2 EM_ASIC_ID 02
    Block Length : 5 (05)
    ID DWORD 0 : 00001051
    3 EM_ASIC_ID 02
    ID DWORD 0 : 00001060
    4 PUBLIC_ID 12
    ID DWORD 0 : 2DB00001
    ID DWORD 1 : 1D7E1449
    ID DWORD 2 : 804D1105
    ID DWORD 3 : 09CBF491
    ID DWORD 4 : CD012A5C
    5 ASIC_MODE_ID 13
    Block Length : 2 (02)
    Mode Id : 00
    6 ROOT_KEY_HASH 14
    Block Length : 17 (11)
    Hash : 7B 04 54 00 E1 75 20 22 F9 EB 80 B0 DE A9 C6 5D
    7 ROM_ID 15
    Block Length : 9 (09)
    CRC 0 : 67E82268
    CRC 1 : F29CEA60
    CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv40_2nd.fg
    Secondary Loader Sent....
    MessageID : C1
    SubBlocks : 06
    Block Length : 0B
    BB ASIC Index : CMT 00
    Device Type : RAM 05
    Device Index : 00
    Manufacturer Code : 0000 -> Flash
    Device ID : 0000 -> Type not in database
    Extended/Fixed ID : 0000
    Revision ID : 0000
    2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Type : MMC 04
    Device Index : 00
    Revision ID : 0000
    Block Length : 0B
    Device Type : NOR 00
    Device Index : 00
    Revision ID : 0000
    4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Index : 01
    Manufacturer Code : 0000 -> SPANSION
    Device ID : 0001 -> Type not in database
    Revision ID : 0000
    5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Type : MuxOneNAND 03
    Device Index : 00
    Manufacturer Code : 00EC ->
    Device ID : 0030 -> Type not in database
    Revision ID : 0431
    6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5
    Block Length : 09
    Data : XSR 1.6
    Flash Descriptor
    Device ID : 0030
    Revision ID : 0000
    Size : 08000000 (128 MB)
    VPP Info : 0000
    Erase10s : 1E
    Block1s : 32
    BErase1s : 02
    Reserved0 : 00
    Reserved1 : 00
    Reserved2 : 00
    CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv40_XSR17_alg.fg
    Algorithm Loader Sent...
    FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
    FUR control Ok
    START READING RPL DATA
    PA PUBLIC KEY Request
    ImagePath: C:\Users\LINH\Downloads\C2-01 RM-721 v11.21 ppm_v Full\RM-721\
    ImageFilename: rm721__11.21.mcusw
    Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
    Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
    Certificate 1
    ASIC Index : CMT 0
    Certificate 2
    ASIC Index : CMT 0
    Certificate 3
    ASIC Index : CMT 0
    Certificate 4
    ASIC Index : CMT 0
    STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3
    STORE_CERTIFICATE_REQUEST_BB5 : Error
    ProcessPartitionInfo_DCT5...
    Partition Info
    Partition Blocks : 1
    1 PARTITION_INFO_BB5
    BB ASIC Index : 0x00 CMT
    Device Type : 0x03 MuxOneNAND
    Device Index : 0x00
    Partition Version : 00010000
    Spare : FFFFFFFF
    Num Partitions : 00000004
    Partition 1
    Attribute : 00000002 RO
    Start Address : 000A0000
    Partition 2
    ID : 00000008 FILESYSTEM
    Attribute : 00000001 RW
    Start Address : 02CC0000
    Partition 3
    Start Address : 077C0000
    Partition 4
    Start Address : 07B40000
    PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000 0002000A000002720000000000080000000102CC000004B000 000000000A00000001077C0000003800000000000B00000001 07B4000000180000C9
    ProcessPartitionInfo_DCT5 : Error
    Flashing Failed....
    Booting/Flashing Failed...
    Please Try Again...
    May 2014
    CẨM KHÊ-PHÚ THỌ
    chạy bằng bộ cáp đa năng đi bác.chơi usb nhiều lúc cũng tưng tửng lắm
    0985210545
    Thành viên kỳ cựu dinhtoan179™'s Avatar
    Nov 2012
    HOA BÌNH
    cái này lối cắp rôi.tháo ra lắc lại cặp đi .đảm bảo done
    Aug 2014
    tiền giang
    anh đã gặp chưa dinhtoan179
    Mar 2014
    CHỢ MỚI-AN GIANG
    Trích Được post bởi dinhtoan179 Xem bài viết
    làm như bác này coi thớt ơi
    Aug 2014
    tiền giang
    chạy bắng cáp đa năng cũng báo lỗi luôn anh
    Aug 2014
    tiền giang
    để em thử có gi báo cáo mấy anh,tks all
    Moderator LÝ NAM bạc liêu's Avatar
    Oct 2014
    bạc liêu
    Flashing Failed....
    cái này có khả năng lỗi cặp rất cao tháo cặp ra đóng lại không được thì thay cặp mới nhe
    chuyên mua bán trao đổi các loại điện thoại di động
    địa chỉ : 56 - phưởng 1 - đường cách mạng - thành phố bạc liêu
    liên hệ : 0907250035
    đóng thật chuẩn lại lần nũa không được thay cặp mới
    yh chanyenmobile_led1202
    ctk hà Văn Yên face hachanyen
    sdt zalo..0972444489
    BỘ ngoại giao trùm các 4r
