    Thành viên chính thức pham thanh linh's Avatar
    Aug 2014
    tiền giang
    Mặc định anh em xem hộ dùm em cái log 2730c
    tình hình là máy bị chạm nguồn đã làn hết cham, nhưng thêm bệnh nữa là mở nguồn lên nokia rồi tắt, em flash lại thử thì báo lỗi như sau.
    Processing Image File :
    rm578__10.45.mcusw
    CMT Type : BB5
    CMT Algorithm : BB5 ALGORITHM
    Secondary Sending Speed : 3250000Hz
    Algorithm Sending Speed : 6500000Hz
    Program Sending Speed : 6500000Hz
    Message Reading Speed : 98000Hz
    Number of Blocks : 1395
    Entry Point: 0x457E
    Page Format : -1
    MAX PAGE : 0x00004000
    rm578__10.45.ppm_v
    CMT Type : BB5
    Number of Blocks : 434
    Entry Point: 0x00B6
    Page Format : -1
    rm578__10.45.image_v_black_v2
    CMT Type : BB5
    Number of Blocks : 1000
    Entry Point: 0x00C8
    Page Format : -1
    AUTO SELECTED DEAD USB FLASHING...
    If Phone Booting does not Start in 5 Seconds,
    Then Perform Steps 1, 2, 3 and 4...
    1. Remove USB and Battery...
    2. Insert USB.
    3. Insert Battery. (Some phones boot automatically)
    4. Please Power on phone shortly...
    AdvanceFBox SendBootCodeEx
    InitialiseBootstrap_DCT5 DIR
    BootFlashMode_DCT5
    READING BOOTROM
    SYSTEM_ID_RESPONSE_BB5 (0xC0) - 96 (0x60) bytes returned
    Number of Sub Blocks 7 (0x07)
    1 SYSTEM_ASIC_ID 01
    Block Length : 21 (15)
    BB ASIC Index : 0 (00) CMT
    ID DWORD 0 : 00000001
    ID DWORD 1 : 00000226
    ID DWORD 2 : 00010006
    ID DWORD 3 : 030C1921
    ID DWORD 4 : 01023000
    2 EM_ASIC_ID 02
    Block Length : 5 (05)
    ID DWORD 0 : 00000296
    3 EM_ASIC_ID 02
    ID DWORD 0 : 00000B22
    4 PUBLIC_ID 12
    ID DWORD 0 : 2790010B
    ID DWORD 1 : 678F0F56
    ID DWORD 2 : 4887ED13
    ID DWORD 3 : 977F3720
    ID DWORD 4 : 7735EADE
    5 ASIC_MODE_ID 13
    Block Length : 2 (02)
    Mode Id : 00
    6 ROOT_KEY_HASH 14
    Block Length : 17 (11)
    Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23
    7 ROM_ID 15
    Block Length : 9 (09)
    CRC 0 : 273F6D55
    CRC 1 : DFAAF68F
    ADL_SERVER: PROCESSING rm578__10.45.mcusw
    ADL_SERVER: ROOT_KEY_HASH MATCH FOUND
    ADL_SERVER: CMT CERTIFICATE BLOCK FOUND
    ADL_SERVER: CMT DATA BLOCKS FOUND
    ADL_SERVER: CONSOLIDATING CMT BLOCKS
    ADL_SERVER: PASUBTOC BLOCK FOUND
    BB5 ADL Loader Start Up... (Please Wait...)
    Found Nokia BB5 ADL Loader USB Generic...
    Processing : rm578__10.45.mcusw
    Erase Block Found
    >> Erasing area 0x00000000 - 0x000006BF, Type: NOR , Subsystem: CMT
    >> Erasing area 0x000006C0 - 0x0001FFFF, Type: NOR , Subsystem: CMT
    >> Erasing area 0x00040000 - 0x000BFFFF, Type: NOR , Subsystem: CMT
    >> Erasing area 0x000C0000 - 0x0013FFFF, Type: NOR , Subsystem: CMT
    >> Erasing area 0x00140000 - 0x0155FFFF, Type: NOR , Subsystem: CMT
    >> Erasing area 0x01560000 - 0x0175FFFF, Type: NOR , Subsystem: CMT
    Erase Complete : No Error - 0 (0x00)
    Data Block Found : 1395 Blocks
    ERROR: Data Block Not Accepted (0x0000)
    Flashing FAILED
    Booting/Flashing Failed...
    Please Try Again...
    Vi phạm nội quy trangiastore's Avatar
    Nov 2014
    flash ver cao hơn xem sao?chú ý pin...
    Jul 2013
    Nghệ An
    đổi sang usb xem.
    Chưa có gì để cả.
    Aug 2014
    tiền giang
    đã chạy usb, cap đa năng r cũng báo lỗi. em chạy ver 10.45 để em chạy lại ver khác thử
    Oct 2013
    Sóc Trăng
    backup full thay flash khác done
    Đời còn dấu ?
    Thì mọi chuyện còn thay đổi.
    Aug 2014
    tiền giang
    không còn cách nao khác hả anh
    May 2010
    Thủ Đức - TP HCM
    nói thiệt chứ bạn đưa cái log flash thì có thông tin j của máy đâu để AE nhìn?. info rồi quăng log lên đi bạn. cái ATF này flash thì ngon mà nhìn cái log thì mún đập cái box, cái hwk vẩn là vô đối.
