Number of Image Files: 3
Processing Image File :
rm907__04.10.mcusw
rm907__04.10.ppm_s3
rm907__04.10.image_s3_059Q8R1
AUTO SELECTED DEAD USB FLASHING...
If Phone Booting does not Start in 5 Seconds,
Then Perform Steps 1, 2, 3 and 4...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
Infineon USB Boot: F00A1FB300020303010100FF
Sending PBL...
PBL Successfully Sent...
Sending SBL...
SBL Successfully Sent...
Setting Transmission Speed Done...
Flash Chip Manufacturer: Intel Electronics Corp.
Flash Boot Successful...
Unique Data: 02100802050A282B
Original Product Code: 059R437
Reading : CCC... OK!
Reading : HWC... OK!
Reading : NPC... OK!
RPL Backup was Successful...
Plain RPL saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\356353055805561\3563530558055 61_64221.rpl
Certificate Block Saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\356353055805561\3563530558055 61_CERTIFICATE_95361F49.bin
PM Block Saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\356353055805561\3563530558055 61_PMM_PROT_BFB90B51.bin
Security Code: 12345
Data Sections : 04
Current File : rm907__04.10.mcusw
Compile Name: rm907__04.10.mcusw_ebl_psi.fls
Image Type : Main Firmware
Data Size : 27266440 Bytes
Sending Certificate Block
FIRMWARE Certificate Block Sent Successfully...
Processing Section 01
FIRMWARE Erase Block: 0x40000000~0x4001FFFE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Preparing Data Blocks...
Data Size: 131072 bytes
Data Checksum: 4F36
Uploading Data Blocks to phone...
Block Write Successful...
FIRMWARE Data Blocks uploaded to phone...
Processing Section 02
FIRMWARE Erase Block: 0x40040000~0x4005FFFE
Start Erasing...
Block Erase Done...
Data Checksum: 7A82
Processing Section 03
FIRMWARE Erase Block: 0x40060000~0x4015FFFE
Start Erasing...
Block Erase Done...
Data Size: 1048576 bytes
Data Checksum: 715E
Processing Section 04
FIRMWARE Erase Block: 0x40280000~0x41BBFFFE
Start Erasing...
Block Erase Done...
Data Size: 25952256 bytes
Data Checksum: 5FB6
Processing Section 05
FIRMWARE Erase Block: 0x43E20000~0x43E5FFFE
Start Erasing...
Block Erase Done...
Data Verification Successful...
Data Sections : 01
Current File : rm907__04.10.ppm_s3
Compile Name: package_s3.ppm_ebl_psi.fls
Image Type : PPM Image
Data Size : 4661392 Bytes
PPM Certificate Block Sent Successfully...
PPM Erase Block: 0x41BC0000~0x421BFFFE
Start Erasing...
Block Erase Done...
Data Size: 4658048 bytes
Data Checksum: 47E2
PPM Data Blocks uploaded to phone...
Data Sections : 01
Current File : rm907__04.10.image_s3_059Q8R1
Compile Name: package_s3_059Q8R1.image.fls
Image Type : CONTENT Package
Data Size : 16518416 Bytes
CONTENT Certificate Block Sent Successfully...
CONTENT Erase Block: 0x421C0000~0x43E1FFFE
Start Erasing...
Block Erase Done...
Data Size: 16515072 bytes
Data Checksum: B56C
CONTENT Data Blocks uploaded to phone...
CONTENT Erase Block: 0x43E60000~0x43F3FFFE
Start Erasing...
Block Erase Done...
Total Flashing Time (Erase + Flashing) : 00:06:27
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 150 seconds)
Scanning USB Ports...
Basic Phone Information
MCU Version: V 04.10 16-10-12 RM-907 (c) Nokia
IMEI Plain : 356353055805561
IMEI Spare : A356353055805560
IMEI SV : 33563530558055602F
Phone Model: G 109
Category : Entry Phone
Phone Type : RM-907
Extended Phone Information
Product Serial Number: 1AA70BEBH
Product Code : 059R437
Module Code : 0205423
Basic Production Code: 059Q5P4
Long Production SN : 0
PPM SW Version : V 04.10 16-10-12 RM-907 (c) Nokia S3
MCU SW Version : V 04.10 16-10-12 RM-907 (c) Nokia
HW Version : 1001
RFIC Version : 68
LCD Version : TPO
Content Pack Version : Content: s3_059Q8R1 V 04.10 16-10-12 RM-907 (c) Nokia
Bluetooth ID : 00:02:5B:00:A5:A5
CS Type : GSM900, GSM1800
********** SIMLOCK INFO **********
CONFIG_DATA : 0010100000000000
PROFILE_BITS : 800000000004000B
ASIC : 11
PROVIDER : Default Test Operator
LOCK COUNTERS: KEYPRESS 0/3, FBUS 0/10
Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
SIMLOCK_TYPE : PA_SIMLOC30 (20-digit NCK)
SIMLOCK_TEST : PASSED
SECURITY_TEST : PASSED
SECURITY_CODE : 12345
PHONE_MODE : TEST
Selected VPL File:
RM907_059Q8R1_04.10_008.vpl
Variant Details : RM-907 APAC_S3_BLACK_STROKE_VN
Software Version : 04.10
Product Type : RM-907
Product Code : 059Q8R1
Variant Version : 008
FACTORY SET TO : Full Factory Set
OK
FACTORY SET TO : User Data
OK
FACTORY SET TO : Leave Factory
OK
FACTORY SET TO : Service Center
OK
FACTORY SET TO : Software Upgrade
OK
FACTORY SET TO : Production Tune
OK
RESET LIFE TIMER TO : 0000:00
OK
